电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » EDA第四次作业
共9条 1/1 1 跳转至页
EDA第四次作业
2014-10-25 12:33:43     打赏
习题3-3
(1)IF_THEN语句
LIBRARY IEEE;
USE  IEEE.STD_LOGIC_1164.ALL;
ENTITY  MUX41A  IS
PORT  (A,B,C,D,S0,S1,S2,S3 : IN  STD_LOGIC;
                                       Y : OUT  STD_LOGIC);
END  ENTITY  MUX41A;
ARCHITECTURE  BHV  OF  MUX41A  IS
BEGIN
PROCESS(S0,S1,S2,S3,A,B,C,D)
BEGIN
IF  S0=’0’ AND NOT(S1=’0’ OR S2=’0’ OR S3=’0’)  THEN  Y<=A;
ELSIF  S1=’0’ AND NOT(S0=’0’ OR S2=’0’ OR S3=’0’)  THEN  Y<=B;
ELSIF  S2=’0’ AND NOT(S0=’0’ OR S1=’0’ OR S3=’0’)  THEN  Y<=C;
ELSIF  S3=’0’ AND NOT(S0=’0’ OR S1=’0’ OR S2=’0’)  THEN  Y<=D;
END  NULL;
END  IF;
END  PROCESS;
END  BHV;
(2)WHEN_ELSE语句
LIBRARY  IEEE;
ENTITY  MUX41A  IS
                                       Y : OUT  STD_LOGIC);
END  ENTITY  MUX41A;
BEGIN
BEGIN
Y<=A  WHEN  S0=’0’ AND NOT(S1=’0’ OR S2=’0’ OR S3=’0’)  ELSE
      B  WHEN  S1=’0’ AND NOT(S0=’0’ OR S2=’0’ OR S3=’0’)  ELSE
      C  WHEN  S2=’0’ AND NOT(S0=’0’ OR S1=’0’ OR S3=’0’)  ELSE
      D  WHEN  S3=’0’ AND NOT(S0=’0’ OR S1=’0’ OR S2=’0’)  ELSE
      NULL ;
END  PROCESS;
END   BHV;
(3)CASE 语句
LIBRARY  IEEE;
ENTITY  MUX41A  IS
                                       Y : OUT  STD_LOGIC);
END  ENTITY  MUX41A;
SIGNAL  S : STD_LOGIC_VECTOR(3  DOWNTO  0);
BEGIN
S <= S3 & S2 & S1 & S0;
PROCESS(S3,S2,S1,S0)
BEGIN
   CASE  (S)  IS
    WHEN  “1110”  =>  Y<=A;
    WHEN  “1101”  =>  Y<=B;
    WHEN  “1011”  =>  Y<=C;
    WHEN  “0111”  =>  Y<=D;
    WHEN  OTHERS  =>  NULL;
   END  CASE;
END  PROCESS;
END  BHV;
(4)WITH_SELECT语句
LIBRARY  IEEE;
ENTITY  MUX41A  IS
                                       Y : OUT  STD_LOGIC);
END  ENTITY  MUX41A;
BEGIN
BEGIN
  WITH  S  SELECT
 Y<=A  WHEN  “1110”,
         B  WHEN  “1101”,
         C  WHEN  “1011”,
         D  WHEN  “0111” ;
END  PROCESS;
END  BHV;
习题3-4
(1)半减器
LIBRARY  IEEE;
ENTITY  h_suber  IS
     PORT (     x, y : IN  STD_LOGIC;
           diff, s_out : OUT  STD_LOGIC);
END  ENTITY  h_suber;
ARCHITECTURE  fh1  OF  h_suber  IS
BEGIN
      s_out <= (NOT x ) AND  y;
      diff <= x  XOR  y;
END  ARCHITECTURE  fh1;
(2)全减器
LIBRARY  IEEE;
ENTITY  f_suber  IS
     PORT ( X,Y,sub_in : IN  STD_LOGIC;
                  diff,s_out : OUT  STD_LOGIC);
END  ENTITY  f_suber;
ARCHITECTURE  fd1  OF  f_suber  IS
COMPONENT  h_suber
   PORT  (x ,y : IN  STD_LOGIC;  s_out ,diff : OUT  STD_LOGIC);
END  COMPONENT;
SIGNAL  net1, net2, net3: STD_LOGIC;
BEGIN
   u1 : h_suber  PORT  MAP(x=>X, y=>Y, diff=>net1, s_out=>net2);
   u2 : h_suber  PORT  MAP(x=>net1, y=>sub_in, diff=>diffr, s_out=>net3);
   sub_out <= net2  OR  net3;
END  fd1;
2014-10-26 10:29:46     打赏
楼主再发帖子时  可以考虑使用帖子格式里的 插入代码功能
2014-10-26 14:33:03     打赏
(1)IF_THEN语句 LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY MUX41A IS PORT (A,B,C,D,S0,S1,S2,S3 : IN STD_LOGIC; Y : OUT STD_LOGIC); END ENTITY MUX41A; ARCHITECTURE BHV OF MUX41A IS BEGIN PROCESS(S0,S1,S2,S3,A,B,C,D) BEGIN IF S0=’0’ AND NOT(S1=’0’ OR S2=’0’ OR S3=’0’) THEN Y Y Y Y Y NULL; END CASE; END PROCESS; END BHV; (4)WITH_SELECT语句 LIBRARY IEEE; USE IEEE.STD_LOGIC_1164.ALL; ENTITY MUX41A IS PORT (A,B,C,D,S0,S1,S2,S3 : IN STD_LOGIC; Y : OUT STD_LOGIC); END ENTITY MUX41A; ARCHITECTURE BHV OF MUX41A IS SIGNAL S : STD_LOGIC_VECTOR(3 DOWNTO 0); BEGIN S X, y=Y, diff=net1, s_out=net2); u2 : h_suber PORT MAP(x=net1, y=sub_in, diff=diffr, s_out=net3); sub_out
2014-10-26 14:34:18     打赏
2014-10-26 14:35:51     打赏
2014-10-26 14:36:25     打赏
2014-10-26 15:04:09     打赏
现在大学用VHDL的不多了呀
2014-11-02 11:10:31     打赏
恩,谢谢,第五次作业提交时学会用了。
2014-11-02 20:16:08     打赏
这样的排版,你自己会去再看吗?
共9条 1/1 1 跳转至页
