3-5
解:(1)条件赋值语句
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD LOGIC UNSIGNED.ALL;
ENTITY decoder3to8 IS
port ( DIN:IN STD_LOGIC_VECTOR (2DOWNTO0);
DOUT:OUT BIT_VECTOR7(DOWNTO0));
END decoder 3to8;
ARCHITECTURE behave OF decoder 3to8 IS
BEGIN
WITH CONV_INTEGER(DIN)SELECT
DOUT<=”00000001”WHEN 0,
“00000010”WHEN 1,
“00000100”WHEN 2,
“00001000”WHEN 3,
“00010000”WHEN 4,
“00100000”WHEN 5,
“01000000”WHEN 6,
“10000000”WHEN 7,
UNAFFECTED WHEN OTHERS;
END behaved;
(2)case语句
LIBRARY IEEE;
ENTITY decoder 3to8 ;
BEGIN
CASE CONV INTEGR_INTEGER(DIN)IS
WHEN 0>=DOUT<=”00000001”;
WHEN 1>=DOUT<=”00000010”;
WHEN 2>=DOUT<=”00000100”;
WHEN 3>=DOUT<=”00001000”;
WHEN 4>=DOUT<=”00010000”;
WHEN 5>=DOUT<=”00100000”;
WHEN 6>=DOUT<=”01000000”;
WHEN 7>=DOUT<=”10000000”;
WHEN OTHERS=>NULL;
END CASE;
END PROCESS;
END behave;
(3) if_else语句
LIBRARY IEEE;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
port( DIN: IN STD_LOGIC_VECTOR(2 DOWNTO 0);
DOUT: OUT BIT_VECTOR(7 DOWNTO 0));
END decoder3to8;
ARCHITECTURE behave OF decoder3to8 IS
BEGIN
PROCESS (DIN)
BEGIN
IF CONV_INTEGER(DIN)=0 THEN DOUT<="00000001";
ELSIF CONV_INTEGER(DIN)=1 THEN DOUT<="00000010";
ELSIF CONV_INTEGER(DIN)=2 THEN DOUT<="00000100";
ELSIF CONV_INTEGER(DIN)=3 THEN DOUT<="00001000";
ELSIF CONV_INTEGER(DIN)=4 THEN DOUT<="00010000";
ELSIF CONV_INTEGER(DIN)=5 THEN DOUT<="00100000";
ELSIF CONV_INTEGER(DIN)=6 THEN DOUT<="01000000";
ELSIF CONV_INTEGER(DIN)=7 THEN DOUT<="10000000";
END IF;
END PROCESS;
END behave;
(4)移位操作符
LIBRARY IEEE;
END decoder3to8;
BEGIN
DOUT<="00000001" SLL CONV_INTEGER(DIN);
END behave;
3—14
解: LIBRARY IEEE;
ENTITY vote_7 IS
PORT( DIN: IN STD_LOGIC_VECTOR(6 DOWNTO 0);
G_4: OUT STD_LOGIC;
CNTH: OUT STD_LOGIC_VECTOR(2 DOWNTO 0));
END vote_7;
ARCHITECTURE BHV OF vote_7 IS
BEGIN
PROCESS(DIN)
VARIABLE Q: STD_LOGIC_VECTOR(2 DOWNTO 0);
BEGIN
Q:="000";
FOR n IN 0 TO 6 LOOP
IF(DIN(n)='1') THEN Q:=Q+1; END IF;
END LOOP;
CNTH<=Q;
IF Q>=4 THEN G_4<='1'; ELSE G_4<='0'; END IF;
END PROCESS;
END BHV;
