电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » 第五次作业
第五次作业
2014-10-30 22:20:51     打赏
3-5
解:(1)条件赋值语句
 LIBRARY  IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD LOGIC UNSIGNED.ALL;
ENTITY decoder3to8 IS
 port (   DIN:IN STD_LOGIC_VECTOR (2DOWNTO0);
          DOUT:OUT BIT_VECTOR7(DOWNTO0));
END decoder 3to8;
ARCHITECTURE behave OF decoder 3to8 IS
BEGIN
WITH CONV_INTEGER(DIN)SELECT
DOUT<=”00000001”WHEN 0,
        “00000010”WHEN 1,
        “00000100”WHEN 2,
        “00001000”WHEN 3,
        “00010000”WHEN 4,
        “00100000”WHEN 5,
        “01000000”WHEN 6,
        “10000000”WHEN 7,
       UNAFFECTED WHEN OTHERS
END behaved
2case语句
LIBRARY IEEE;
ENTITY decoder 3to8 ;
BEGIN
 CASE CONV INTEGR_INTEGER(DIN)IS
   WHEN 0>=DOUT<=”00000001”;
   WHEN 1>=DOUT<=”00000010”;
   WHEN 2>=DOUT<=”00000100”;
   WHEN 3>=DOUT<=”00001000”;
   WHEN 4>=DOUT<=”00010000”;
   WHEN 5>=DOUT<=”00100000”;
   WHEN 6>=DOUT<=”01000000”;
   WHEN 7>=DOUT<=”10000000”;
  WHEN OTHERS=>NULL;
  END CASE;
 END PROCESS;
END behave;
3 if_else语句
    LIBRARY IEEE;
    USE IEEE.STD_LOGIC_UNSIGNED.ALL;
      port(   DIN: IN  STD_LOGIC_VECTOR(2 DOWNTO 0);
              DOUT: OUT BIT_VECTOR(7 DOWNTO 0));
    END decoder3to8;
    ARCHITECTURE behave OF decoder3to8 IS
    BEGIN
      PROCESS (DIN)
      BEGIN
      IF    CONV_INTEGER(DIN)=0 THEN DOUT<="00000001";
      ELSIF CONV_INTEGER(DIN)=1 THEN DOUT<="00000010";
      ELSIF CONV_INTEGER(DIN)=2 THEN DOUT<="00000100";
      ELSIF CONV_INTEGER(DIN)=3 THEN DOUT<="00001000";
      ELSIF CONV_INTEGER(DIN)=4 THEN DOUT<="00010000";
      ELSIF CONV_INTEGER(DIN)=5 THEN DOUT<="00100000";
      ELSIF CONV_INTEGER(DIN)=6 THEN DOUT<="01000000";
      ELSIF CONV_INTEGER(DIN)=7 THEN DOUT<="10000000";
      END IF;
      END PROCESS;
    END behave;
4)移位操作符
    LIBRARY IEEE;
    END decoder3to8;
    BEGIN
      DOUT<="00000001" SLL CONV_INTEGER(DIN);
END behave;
3—14
解: LIBRARY  IEEE;
    ENTITY vote_7 IS
      PORT( DIN:  IN STD_LOGIC_VECTOR(6 DOWNTO 0);
            G_4: OUT STD_LOGIC;
           CNTH: OUT STD_LOGIC_VECTOR(2 DOWNTO 0));
    END vote_7;
    ARCHITECTURE BHV OF vote_7 IS
    BEGIN
        PROCESS(DIN)
        VARIABLE Q: STD_LOGIC_VECTOR(2 DOWNTO 0);
      BEGIN
        Q:="000";
        FOR n IN 0 TO 6 LOOP
          IF(DIN(n)='1') THEN Q:=Q+1; END IF;
        END LOOP;
        CNTH<=Q;
        IF Q>=4 THEN G_4<='1'; ELSE G_4<='0'; END IF;
      END PROCESS;
    END BHV;
关键词: 五次     作业
