EDA技术第4次作业
姓名:李二猛 学号:201405080011 班级:14级电信(专升本)
2014/10/26
3—3,试分别用IF_THEN语句和CASE语句的表达方式写出此电路的VHDL程序,选择控制信号s1和s0的数据类型为STD_LOGIC_VECTOR;当s1=‟0‟,s0=‟0‟;s1=‟0‟,s0=‟1‟;s1=‟1‟,s0=‟0‟和s1=‟1‟,s0=‟1‟时,分别执行y<=a、y<=b、y<=c、y<=d。
LIBRARY IEEE;
PORT (a,b,c,d: IN STD_LOGIC;
s0: IN STD_LOGIC;
s1: IN STD_LOGIC;
y: OUT STD_LOGIC);
END ENTITY mux41;
ARCHITECTURE if_mux41 OF mux41 IS
SIGNAL s0s1 : STD_LOGIC_VECTOR(1 DOWNTO 0);--定义标准逻辑位矢量数据
BEGIN
s0s1<=s1&s0;
--s1相并s0,即s1与s0并置操作
PROCESS(s0s1,a,b,c,d)
BEGIN
IF s0s1 = "00" THEN y <= a;
ELSIF s0s1 = "01" THEN y <= b
ELSIF s0s1 = "10" THEN y <= c;
ELSE y <= d;
END IF;
END PROCESS;
END ARCHITECTURE if_mux41
--解2:用CASE语句实现4选1多路选择器
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY mux41 IS
s0: IN STD_LOGIC;
s1: IN STD_LOGIC;
y: OUT STD_LOGIC);
END ENTITY mux41;
ARCHITECTURE case_mux41 OF mux41 IS
SIGNAL s0s1 : STD_LOGIC_VECTOR(1 DOWNTO 0);--定义标准逻辑位矢量数据类型
BEGIN
s0s1<=s1&s0; --s1相并s0,即s1与s0并置操作
BEGIN
CASE s0s1 IS --类似于真值表的case语句
WHEN "00" => y <= a;
WHEN "01" => y <= b
WHEN "10" => y <= c
WHEN "11" => y <= d;
WHEN OTHERS =>NULL ;
END CASE;
END PROCESS;
END ARCHITECTURE case_mux41;
3—4,给出1位全减器的VHDL描述;最终实现8位全减器。要求: 1)首先设计1位半减器,然后用例化语句将它们连接起来,图4-20中h_suber是半减器,diff是 输出差(diff=x-y),s_out是借位输出(s_out=1,x<y),sub_in是借位输入。
