3-5 用 VHDL设计一个3-8译码器,要求分别用顺序赋值语句、case语句、if_else语句或移位操作符来完成。比较这4中方式中,哪一种最节省逻辑资源。
答:
3-5 解(1):顺序赋值语句
3到8译码器设计(顺序赋值语句实现)
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENTITY decoder3to8 IS
port(DIN: IN STD_LOGIC_VECTOR(2 DOWNTO 0);
DOUT: OUT BIT_VECTOR(7 DOWNTO 0));
END decoder3to8;
ARCHITECTURE behave OF decoder3to8 IS
BEGIN
WITH CONV_INTEGER(DIN) SELECT
DOUT<="00000001" WHEN 0,
"00000010" WHEN 1,
"00001000" WHEN 3,
"00010000" WHEN 4,
"00100000" WHEN 5,
"01000000" WHEN 6,
"10000000" WHEN 7,
UNAFFECTED WHEN OTHERS;
END behave;
(2):case语句
3到8译码器设计(case语句实现)
LIBRARY IEEE;
port(DIN: IN
END decoder3to8;
BEGIN
PROCESS (DIN)
BEGIN
CASE CONV_INTEGER(DIN) IS
WHEN 0 => DOUT<="00000001";
WHEN 1 => DOUT<="00000010";
WHEN 2 => DOUT<="00000100";
WHEN 3 => DOUT<="00001000";
WHEN 4 => DOUT<="00010000";
WHEN 5 => DOUT<="00100000";
WHEN 6 => DOUT<="01000000";
WHEN 7 => DOUT<="10000000";
WHEN OTHERS => NULL;
END CASE;
END PROCESS;
END behave;
(3):if_else语句
3到8译码器设计(if_else语句实现)
LIBRARY IEEE;
port( DIN: IN STD_LOGIC_VECTOR(2 DOWNTO 0);
END decoder3to8;
BEGIN
PROCESS (DIN)
BEGIN
IF CONV_INTEGER(DIN)=0 THEN
DOUT<="00000001";
ELSIF CONV_INTEGER(DIN)=1 THEN
DOUT<="00000010";
ELSIF CONV_INTEGER(DIN)=2 THEN
DOUT<="00000100";
ELSIF CONV_INTEGER(DIN)=3 THEN
DOUT<="00001000";
ELSIF CONV_INTEGER(DIN)=4 THEN
DOUT<="00010000";
ELSIF CONV_INTEGER(DIN)=5 THEN
DOUT<="00100000";
ELSIF CONV_INTEGER(DIN)=6 THEN
DOUT<="01000000";
ELSIF CONV_INTEGER(DIN)=7 THEN
DOUT<="10000000";
END IF;
END PROCESS;
END behave;
(4):移位操作符
3到8译码器设计(移位操作实现)
LIBRARY IEEE;
END decoder3to8;
BEGIN
DOUT<="00000001" SLL
CONV_INTEGER(DIN);
END behave;
3-14 用循环语句设计一个7人投票表决器。
答:
LIBRARY IEEE;
ENTITY vote_7 IS
PORT( DIN:
IN STD_LOGIC_VECTOR(6 DOWNTO 0);
G_4: OUT STD_LOGIC;
CNTH: OUT STD_LOGIC_VECTOR(2 DOWNTO 0));
END vote_7;
ARCHITECTURE BHV OF vote_7 IS
BEGIN
PROCESS(DIN)
VARIABLE Q: STD_LOGIC_VECTOR(2 DOWNTO 0);
BEGIN
Q:="000";
FOR n IN 0 TO 6 LOOP
IF(DIN(n)='1') THEN Q:=Q+1; END IF;
END LOOP;
CNTH<=Q;
IF Q>=4 THEN G_4<='1'; ELSE
G_4<='0'; END IF;
END PROCESS;
END BHV;
