电子产品世界 » 论坛首页 » 高校专区 » 周师电子设计创新社区 » 第五次作业
第五次作业
2015-01-09 17:33:32     打赏
3-5用VHDLSHEJIYIGE3-8译码器,要求分别用赋值语句,case语句,if-else语句或移位操作符来完成。比较这4种方式中,那一种更节省逻辑资源。
本题用的是74LS138真值表:
一 顺序赋值语句1 CASE语句,2 IF-ELSE语句
1.case语句
LIBRARY IEEE;
USE IEEE.STD_LOGIC_1164.ALL;
ENTITY decoder3to8 IS
 PORT(A0,A1, A2 ,S0,S1,S2 : IN STD_LOGIC;
               Y:OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END ENTITY decoder3to8;
ARCHITECTURE BEH38 OF decoder3to8 IS
SIGNAL DATA: STD_LOGIC_VECTOR (2 DOWNTO 0);
BEGIN
  DATA<= A0&A1&A2;
 PROCESS(DATA,S0,S1,S2,)
  BEGIN
    IF S0='1' and S1='0' and S2='0') THEN
       CASE(DATA) IS
         WHEN "000"  => y <="11111110";
         WHEN "001"  => y <="11111101";
         WHEN "010"  => y <="11111011";
         WHEN "011"  => y <="11110111";
         WHEN "100"  => y <="11101111";
         WHEN "101"  => y <="11011111";
         WHEN "110"  => y <="10111111";
         WHEN "111"  => y <="01111111";
         WHEN OTHERS => y <="11111111";
      END CASE;
    END IF;
  END PROCESS;
END ARCHITECTURE BEH38;
2.If-else语句
LIBRARY IEEE;
        Y: OUT STD_LOGIC_VECTOR (7 DOWNTO 0)
BEGIN
  DATA<= A0&A1&A2;
  BEGIN
  IF (S0='1' and S1='0' and S2='0') THEN
        IF (DATA= "000") THEN  y<="11111110";
     ELSIF (DATA= "001") THEN  y<="11111101";
     ELSIF (DATA= "010") THEN  y<="11111011";
     ELSIF (DATA= "011" )THEN  y<="11110111";
     ELSIF (DATA= "100" )THEN  y<="11101111";
     ELSIF (DATA= "101" ) THEN y<="11011111";
     ELSIF (DATA= "110" ) THEN y<="10111111";
     ELSIF (DATA= "111" ) THEN y<="01111111";
  ELSE   y<="11111111";
 END IF;
END PROCESS;
三.移位操作符
LIBRARY IEEE;
USE IEEE.STD_LOGIC_UNSIGNED.ALL;
ENEITY decoder3to8 IS
 PORT (DIN : IN STD_LOGIC_VECTOR (2 DOWNTO 0);
         DOUT:OUT BIT_ VECTOR( 7 DOWNTO 0)
END decoder3to8 ;
BEGIN
  DOUT<=“11111110” SLL CONV_ INTEGER(DIN);
END  ARCHITECTURE BEH38 ;
所以四种综合看移位操作符比较节省逻辑资源。
3-14 用循环语句设计一个7人投票表决器。
LIBRARY IEEE;
ENEITY CNTC IS;
PORT (DIN : IN STD_LOGIC_VECTOR (6 DOWNTO 0);
     DOUT: OUT BIT_ VECTOR( 2 DOWNTO 0)
 Y:OUT STD_LOGIC;
END ENEITY CNTC;
ARCHITECTURE ONE OF CNTC IS
BEGIN
PROCESS (DIN)
VARIABLE Q : STD_LOGIC_VECTO(2 DOWNTO 0);
BEGIN
  Q :=”000”;
FOR n in 0 to 6 LOOP
IF (DIN(n)=’1’) THEN Q:=Q+1;
END IF;
END LOOP;
CNTC<=Q;
IF(CNTC >=‘100’)THEN Y=’1’
ELSE Y=’0’;
END PROCESS;
END ARCHITECTURE ONE;
