刷回能用的那个又提示下面的:
Starting kernel ...
[ 1.159580] sun6i_vibrator_init motor is not used in config
[ 1.381979] otg_wakelock_init: No OTG transceiver found
[ 6.019572] fs_mgr: begin to format ext4 buffer : /dev/block/mmcblk0p12
[ 6.056433] fs_mgr: finish format to ext4 :/dev/block/mmcblk0p12
[ 6.063367] fs_mgr: exec: pid 1187 exited with return code 1: Unknown error 256
[ 9.071640] fs_mgr: begin to format ext4 buffer : /dev/block/mmcblk0p12
[ 9.081417] fs_mgr: finish format to ext4 :/dev/block/mmcblk0p12
[ 9.088314] fs_mgr: exec: pid 1188 exited with return code 1: Unknown error 256
[ 12.096590] fs_mgr: begin to format ext4 buffer : /dev/block/mmcblk0p12
[ 12.106173] fs_mgr: finish format to ext4 :/dev/block/mmcblk0p12
[ 12.113061] fs_mgr: exec: pid 1189 exited with return code 1: Unknown error 256
崩溃啊~
