Wed Mar 04 14:29:47 2015
Input File : D:\PVG102-I文件\PVG102_I_V1.0_20150227\PVG102_I_V1.0_20150227.eco
Current Job : PVG102_I_V1.0_20150227.pcb
Line 6 , Section *PART*
J61 3P-2.54@3P-2.54
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "3P-2.54". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
Line 7 , Section *PART*
J52_ARM SIP2@SIP2
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SIP2". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
Line 10 , Section *NET*
J52_ARM.1 J61.1
* Part name J52_ARM not found
* Part name J61 not found
Line 12 , Section *NET*
J52_ARM.2 J61.2
方法
即可解决
