电子产品世界 » 论坛首页 » 综合技术 » PCB与EMC » pads更新原理图后,pcb文件出现* Part nameXXX not fou
共3条 1/1 1 跳转至页
pads更新原理图后,pcb文件出现* Part nameXXX not found解决方法
2015-03-04 15:54:25     打赏
** ECO In Report **
Wed Mar 04 14:29:47 2015
Input  File : D:\PVG102-I文件\PVG102_I_V1.0_20150227\PVG102_I_V1.0_20150227.eco
Current Job : PVG102_I_V1.0_20150227.pcb
Line 6 , Section *PART*
J61  3P-2.54@3P-2.54
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "3P-2.54". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
Line 7 , Section *PART*
J52_ARM  SIP2@SIP2
* Because the current design is in default layer mode and the decal is in increased layer mode, you cannot add decal "SIP2". Open Layer Setup dialog box and change the layer mode of the design to increased layers.
Line 10 , Section *NET*
J52_ARM.1  J61.1
* Part name J52_ARM not found
* Part name J61 not found
Line 12 , Section *NET*
J52_ARM.2  J61.2
方法
即可解决
关键词: PADS     Part namenot found     解
2015-04-11 15:39:11     打赏
请问高手,为什么调加测试点老是不成功。
2015-04-11 22:25:09     打赏
楼主对pads研究挺深,,不错
共3条 1/1 1 跳转至页
