module key_ctrlnum(clk, rstn, key, num); input clk, rstn; input [6:0] key; output [7:0] num; reg[6:0] key_sample; parameter number1=7'b1111111; parameter cnt_num=20'hfffff; always@(posedge clk or negedge rstn) begin if(!rstn) key_sample <= number1; else key_sample <= key; end reg[6:0] key_sample_r; always@(posedge clk or negedge rstn) begin if(!rstn) key_sample_r <= number1; else key_sample_r <= key_sample; end wire[6:0] key_an; assign key_an = key_sample_r[6:0]&(~key_sample[6:0]); reg[19:0] cnt; always@(posedge clk or negedge rstn) begin if(!rstn) cnt <= 20'h0; else if(key_an) cnt <= 20'h0; else cnt <= cnt + 1'b1; end reg[6:0] low_sw; always@(posedge clk or negedge rstn) begin if(!rstn) low_sw <= number1; else if(cnt == cnt_num) low_sw <= key; end reg[6:0] low_sw_r; always@(posedge clk or negedge rstn) begin if(!rstn) low_sw_r <= number1; else low_sw_r <= low_sw; end wire[6:0] num_ctrl; assign num_ctrl = low_sw_r&(~low_sw); reg [7:0] num; always@(posedge clk or negedge rstn) begin if(!rstn) num <= 8'b11111111; else begin case(num_ctrl) 7'b1000000: num <= 8'b11111110; 7'b0100000: num <= 8'b01100000; 7'b0010000: num <= 8'b11011000; 7'b0001000: num <= 8'b11110010; 7'b0000100: num <= 8'b01100110; 7'b0000010: num <= 8'b10110110; 7'b0000001: num <= 8'b10111110; default: num <= 8'b11111111; endcase end end endmodule
