-- Quad D-Type Flip-flop -- This example shows how a conditional signal assignment statement could be used to describe sequential logic(it is more common to use a process). -- The keyword 'unaffected' is equivalent to the 'null' statement in the sequential part of the language. -- The model would work exactly the same without the clause 'else unaffected' attached to the end of the statement. -- uses 1993 std VHDL library IEEE; use IEEE.Std_logic_1164.all; entity HCT175 is port(D : in std_logic_vector(3 downto 0); Q : out std_logic_vector(3 downto 0); CLRBAR, CLK : in std_logic); end HCT175; architecture VER1 of HCT175 is begin Q <= (others => '0') when (CLRBAR = '0') else D when rising_edge(CLK) else unaffected; end VER1;
共1条
四D触发器:74175
共1条
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
