-- Quad D-Type Flip-flop -- This example shows how a conditional signal assignment statement could be used to describe sequential logic(it is more common to use a process). -- The keyword 'unaffected' is equivalent to the 'null' statement in the sequential part of the language. -- The model would work exactly the same without the clause 'else unaffected' attached to the end of the statement. -- uses 1993 std VHDL library IEEE; use IEEE.Std_logic_1164.all; entity HCT175 is port(D : in std_logic_vector(3 downto 0); Q : out std_logic_vector(3 downto 0); CLRBAR, CLK : in std_logic); end HCT175; architecture VER1 of HCT175 is begin Q <= (others => '0') when (CLRBAR = '0') else D when rising_edge(CLK) else unaffected; end VER1;
共1条
四D触发器:74175
共1条
打赏帖 | |
【S32K146】S32DS watchdog 配置使用被打赏20分 | |
【Zephyr】使用 IAR 调试 Zephyr 镜像被打赏20分 | |
【Zephyr】MCXN947 Zephyr 开发入门适配shell被打赏20分 | |
【我要开发板】6.联合MATLAB记录数据被打赏50分 | |
【瑞萨RA2E1开发板】:使用ADC功能实现位移传感器采集方案被打赏20分 | |
【nRF7002DK】基于sht30的温湿度计被打赏20分 | |
【nRF7002DK】日志打印被打赏20分 | |
【换取手持示波器】RGB屏幕移植ARM-2D库被打赏35分 | |
【分享开发笔记,赚取电动螺丝刀】分享一下如何解决瑞萨RA2E1使用printf编译报错问题被打赏27分 | |
rtthread硬件加密-5hash加密分析被打赏10分 |
