导出gerber就可以打样了,不用转什么AD了。
转自:http://breadboardkiller.com/index.php/blog/82-exporting-gerbers-from-kicad
1. Open The Board in KiCad
2. Run DRC
Before exporting Gerbers you must always, ALWAYS (mostly), run a Design Rule Check (DRC). Before you do this, go to the Design Rules Editor (Design Rules->Design Rules) and update the global design rules.
3. Export the Gerber Files
Ok, this is a pretty convoluted and epically difficult process in KiCad so make sure you follow along carefully. First, click the plot button in the toolbar to open the Plot dialog.
- "Plot format" is set to "Gerber",
- the check boxes in the "Options" section are the same as in the image below, and
- you have the layers that you want exported selected in the "Layers" section on the left.
Layer | Default KiCad Name |
Top Silkscreen | F.SilkS |
Top Soldermask | F.Mask |
Top Copper | F.Cu |
Bottom Copper | B.Cu |
Bottom Soldermask | B.Mask |
Bottom Silkscreen | B.SilkS |
Board Outline | Edge.Cuts |
4. Export The NC Drill Files
Back in the Plot dialog, keep the same settings as above and click the "Generate Drill File" button. There are a few more options for the drill file export:
- the "Drill Map File Format" which should be "PostScript" for NC Drills format,
- the "Zeros Format" which should be set to "Keep zeros", and
- "Mirror y axis" which should be unchecked.
To export, click the "Drill Fille" button (ignoring the typo by the developers there).
5. Check The Generated Files
Almost done! Before you send you design off to the fab, make sure you check your exported gerbers and drill files in a gerber viewer. To do this, a good free gerber viewer is gerbv which can be downloaded from here. Once you've downloaded and installed gerbv, open it and click "File->Open layer(s)...". Then select the gerber files and drill file you exported from KiCad.
6. Zip The Files
Breadboard Killer and most other PCB manufacturers will prefer your files in a single zipped archive. Gerbers contain a lot of redundant information so zipping them will often reduce the size significantly. Add all of the files you exported to a zip along with a text file describing which layer is which. This will ensure that the manufacturer doesn't make any silly errors.
7. Profit
And repeat... Hope this tutorial was useful to some of you. And best of luck with your project!
