这个板子有多少个ADC不太清楚,或者可以查datasheet吧,暂时用不了辣么多,先用arduino的吧,
找出了一个遥杆,分别连接到了A1\A2和D7
老规矩记录代码,真怕什么时候mbed崩了
#include "mbed.h"
AnalogIn analog_value1(A0);
AnalogIn analog_value2(A1);
DigitalIn mybutton(D7);
DigitalOut led(LED1);
int main() {
float meas1,meas2;
int key;
printf("\nAnalogIn example\n");
while(1) {
meas1 = analog_value1.read(); // Converts and read the analog input value (value from 0.0 to 1.0)
meas1 = meas1 * 3300; // Change the value to be in the 0 to 3300 range
meas2 = analog_value2.read(); // Converts and read the analog input value (value from 0.0 to 1.0)
meas2 = meas2 * 3300; // Change the value to be in the 0 to 3300 range
key = mybutton.read();
printf("measure = %.0f mV, %.0f mV, %d\n", meas1, meas2, key);
if (meas1 > 2000) { // If the value is greater than 2V then switch the LED on
led = 1;
else {
led = 0;
wait(0.2); // 200 ms
| 为遥控小车巧添功能被打赏¥26元 | |
