电子产品世界 » 论坛首页 » 高校专区 » 漓东e学堂 » [1.13更新]16号的作业更新,不记得之前写到哪了,直接从第二次作业开始弄吧-
共8条 1/1 1 跳转至
[1.13更新]16号的作业更新,不记得之前写到哪了,直接从第二次作业开始弄吧- -
2016-01-13 14:54:29     打赏
作业二:流水灯 http://forum.eepw.com.cn/thread/279062/1#2
作业三:0~99按键计数 http://forum.eepw.com.cn/thread/279062/1#3
作业四:uart控制LED流水灯转速 http://forum.eepw.com.cn/thread/279062/1#4
作业五:定时器控制LED灯 http://forum.eepw.com.cn/thread/279062/1#5
作业六:计算机开机次数 http://forum.eepw.com.cn/thread/279062/1#7
作业七:DS18B20测温http://forum.eepw.com.cn/thread/279062/1#8
2016-01-13 14:55:49     打赏
作业二:流水灯
  * @file    GPIO/IOToggle/main.c
  * @author  MCD Application Team
  * @version V3.5.0
  * @date    08-April-2011
  * @brief   Main program body.
  * @attention
  * THE PRESENT FIRMWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS
  * WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE
  * TIME. AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY
  * DIRECT, INDIRECT OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING
  * FROM THE CONTENT OF SUCH FIRMWARE AND/OR THE USE MADE BY CUSTOMERS OF THE
  * CODING INFORMATION CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
  * <h2><center>&copy; COPYRIGHT 2011 STMicroelectronics</center></h2>
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
#include "stm32_eval.h"
GPIO_InitTypeDef GPIO_InitStructure;
void RCC_Configuration(void)
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_HSIRDY) == RESET);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_HSI);
  RCC_HSEConfig(RCC_HSE_OFF);
  RCC_LSEConfig(RCC_LSE_OFF);
  RCC_PLLConfig(RCC_PLLSource_HSI_Div2,RCC_PLLMul_9); //  72HMz
  RCC_PLLCmd(ENABLE);
  while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET);
  RCC_ADCCLKConfig(RCC_PCLK2_Div4);
  RCC_PCLK2Config(RCC_HCLK_Div1);
  RCC_PCLK1Config(RCC_HCLK_Div2);
  RCC_HCLKConfig(RCC_SYSCLK_Div1);
  RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  while(RCC_GetSYSCLKSource() != 0x08);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE);
 GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//disable JTAG
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
GPIO_ResetBits(GPIOD,GPIO_Pin_2);
void delay_us(u32 n)
u8 j;
while(n--)
for(j=0;j<10;j++);
void delay_ms(u32 n)
while(n--)
delay_us(1000);
  * @brief  Main program.
  * @param  None
  * @retval None
int main(void)
{ unsigned char flag=0;
RCC_Configuration();
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
 GPIO_Init(GPIOC, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7;
while(1)
GPIO_SetBits(GPIOC,GPIO_Pin_0);
GPIO_SetBits(GPIOC,GPIO_Pin_1);
GPIO_SetBits(GPIOC,GPIO_Pin_2);
GPIO_SetBits(GPIOC,GPIO_Pin_3);
GPIO_SetBits(GPIOC,GPIO_Pin_4);
GPIO_SetBits(GPIOC,GPIO_Pin_5);
GPIO_SetBits(GPIOC,GPIO_Pin_6);
GPIO_SetBits(GPIOC,GPIO_Pin_7);
 delay_ms(100);
    GPIO_ResetBits(GPIOC,GPIO_Pin_0);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_1);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_2);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_3);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_4);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_5);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_6);
delay_ms(100);
delay_ms(100);
GPIO_ResetBits(GPIOC,GPIO_Pin_7);
delay_ms(100);
delay_ms(100);
2016-01-13 14:59:40     打赏
作业三:0~99按键计数:
GPIO_InitTypeDef GPIO_InitStructure; // 声明一个结构体
void RCC_Configuration(void);
void GPIO_INIT(void) ;
void Function(void) ;
int main(void)
    GPIO_INIT();
    Function();
void RCC_Configuration(void)    //复位所有的RCC外围设备寄存器
    ErrorStatus HSEStartUpStatus;   //  设置错误标志量
  RCC_DeInit();                 //复位RCC模块的寄存器,复位成缺省值
 RCC_HSEConfig(RCC_HSE_ON);      //开启HSE时钟
  HSEStartUpStatus = RCC_WaitForHSEStartUp();  //获取HSE启动状态:
  if(HSEStartUpStatus==SUCCESS) //如果HSE启动成功
        FLASH_PrefetchBufferCmd(ENABLE);          //开启FLASH的预取功能
        FLASH_SetLatency(FLASH_Latency_2);      //FLASH延迟2个周期
        RCC_HCLKConfig(RCC_SYSCLK_Div1); //配置HCLK,PCLK2,PCLK1,PLL
        RCC_PLLCmd(ENABLE); //启动PLL
        while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY)==RESET);
        {}   //等待PLL启动完成
        RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);//配置系统时钟
        while(RCC_GetSYSCLKSource() != 0x08); //检查是否将HSE 9倍频后作为系统时钟
    GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);//改变管脚的映射SWJ使能选择用于事件输出的GPIO端口
    /*蜂鸣器*/
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD|RCC_APB2Periph_AFIO, ENABLE); //使能所有要用APB2的外设时钟
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;       //选中2引脚
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;        // 引脚频率50M
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;     //引脚设置推拉输出
  GPIO_Init(GPIOD, &GPIO_InitStructure);    //初始化GPIOD
void delay_us(u32 n)        //延时函数
    u8 j;
    while(n--)
            for(j=0;j<10;j++);
void  delay_ms(u32 n)       //延时函数
   while(n--)
   delay_us(1000);
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOB, ENABLE);   //使能所有要用APB2的外设时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10|GPIO_Pin_11;  //选中8,9,10,11引脚
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;   //引脚设置推拉输出
        GPIO_Init(GPIOC, &GPIO_InitStructure);  //初始化
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5|GPIO_Pin_1|GPIO_Pin_15|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14;//数码管
        GPIO_Init(GPIOB, &GPIO_InitStructure);    //初始化
void Number(int a)  //数码管显示数字
    switch(a)
        case 0 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
        case 1 : GPIO_ResetBits(GPIOB,GPIO_Pin_9|GPIO_Pin_12);break;
        case 2 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_13|GPIO_Pin_14);break;
        case 3 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14);break;
        case 4 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12);break;
        case 5 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_14);break;
        case 6 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
        case 7 : GPIO_ResetBits(GPIOB,GPIO_Pin_7|GPIO_Pin_9|GPIO_Pin_12);break;
        case 8 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);break;
        case 9 : GPIO_ResetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_14); break;
void Function(void)
        int i=0,j=0;          //i被按下的次数,n延时变量
        GPIO_SetBits(GPIOB,GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14);
        delay_ms(50); //关闭数码管
        while(1)
                GPIO_SetBits(GPIOB,GPIO_Pin_1);         //打开个位数码管
                Number(i);                                //用switch函数显示00
                delay_ms(50);
                GPIO_ResetBits(GPIOB,GPIO_Pin_1);        //关闭个位
                GPIO_SetBits(GPIOB,GPIO_Pin_15);           //打开十位
                Number(j);
                delay_ms(50);
                GPIO_ResetBits(GPIOB,GPIO_Pin_15);      //关掉十位数码管
                if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))   //判断按键是s1否被按下
                    delay_ms(50);            //延时消抖
                    if(!GPIO_ReadInputDataBit(GPIOC,GPIO_Pin_8))  //再次判断按键是s1否被按下
                        i++;                     //按键被按下,个位+1
                        if(i==10)
                            j++;
                            i=0;
                        if(j==10)
                             j=0;
                                                 i=0;
2016-01-13 15:04:02     打赏
作业四:uart控制LED流水灯转速
#include "stdbool.h"
int main(void)
    GPIO_INIT();
    Function();
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
void GPIO_INIT()
   //GPIO数码管初始化
   RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8
|GPIO_Pin_9|GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;
  //按键初始化
    u8 j;
    while(n--)
    for(j=0;j<10;j++);
    while(n--)
    delay_us(1000);
  void Function(void)
        while(1)
                delay_ms(50);
                Number(j);
                delay_ms(50);
                        i++;                     //按键被按下,个位+1
                        if(i==10)
                            j++;
                            i=0;
                        if(j==10)
                             j=0;
                                                 i=0;
  * @param  None
  * @retval None
2016-01-13 15:04:31     打赏
作业五:定时器控制LED灯
#include <stdio.h>
/** @addtogroup STM32F10x_StdPeriph_Examples
/** @addtogroup EXTI_Config
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
EXTI_InitTypeDef   EXTI_InitStructure;
NVIC_InitTypeDef   NVIC_InitStructure;
USART_InitTypeDef USART_InitStructure;
USART_ClockInitTypeDef USART_ClockInitStructure;
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
int count=0;
  RCC_DeInit();
  RCC_HSICmd(ENABLE);
  RCC_PLLCmd(ENABLE);
  SystemInit();
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO, ENABLE);
  GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
void USART_int(long BaudRate)
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_USART1,ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* PA10 USART1_Rx  */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  /* USARTx configured as follow:
        - BaudRate = 115200 baud
        - Word Length = 8 Bits
        - One Stop Bit
        - No parity
        - Hardware flow control disabled (RTS and CTS signals)
        - Receive and transmit enabled
  USART_InitStructure.USART_BaudRate = BaudRate;//??????
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;//???????8bit
  USART_InitStructure.USART_StopBits = USART_StopBits_1;//????1
  USART_InitStructure.USART_Parity = USART_Parity_No;//????
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//??????none
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;//??????????
  USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;
  USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;
  USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;
  USART_ClockInit(USART1, &USART_ClockInitStructure);
  USART_Init(USART1, &USART_InitStructure);
  USART_Cmd(USART1, ENABLE);
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
void NVIC_Configuration(void)
  /* Enable the TIM2 global Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = TIM2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
int main(void)
  /*!< At this stage the microcontroller clock setting is already configured,
       this is done through SystemInit() function which is called from startup
       file (startup_stm32f10x_xx.s) before to branch to application main.
       To reconfigure the default setting of SystemInit() function, refer to
       system_stm32f10x.c file
  /* System Clocks Configuration */
  NVIC_Configuration();
//USART_int(115200);
//  printf("config done...\r\n");
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 36000;
  TIM_TimeBaseStructure.TIM_Prescaler = 100;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_ITConfig(TIM2,TIM_IT_Update,ENABLE );
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
  while (1){
//if(flag == 1)
//  {printf("TIM2 interrupt......\r\n");
//flag = 0;
//else{GPIO_SetBits(GPIOC,GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7);}
void TIM2_IRQHandler(void) //TIM3
if (TIM_GetITStatus(TIM2, TIM_IT_Update) != RESET)
TIM_ClearITPendingBit(TIM2, TIM_IT_Update );
//  flag = ~flag;
//  if(flag){
//  GPIO_SetBits(GPIOC,GPIO_Pin_1);}
//  else {GPIO_ResetBits(GPIOC,GPIO_Pin_1);}
/*flag++;
    if(flag == 50)
        {led = ~led;
         flag = 0;}
    if(led){
    else {GPIO_ResetBits(GPIOC,GPIO_Pin_1);}*/
    count++;
        if(count==1)
    if(count==2)
    if(count==3)
    if(count==4)
    if(count==5)
    if(count==6)
    if(count==7)
    if(count==8)
    if(count==9)
    count=0;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
#ifdef __GNUC__
  /* With GCC/RAISONANCE, small printf (option LD Linker->Libraries->Small printf
     set to 'Yes') calls __io_putchar() */
#define PUTCHAR_PROTOTYPE int __io_putchar(int ch)
#else
#define PUTCHAR_PROTOTYPE int fputc(int ch, FILE *f)
#endif /* __GNUC__ */
PUTCHAR_PROTOTYPE
  /* Place your implementation of fputc here */
  /* e.g. write a character to the USART */
  USART_SendData(EVAL_COM1, (uint8_t) ch);
  /* Loop until the end of transmission */
  while (USART_GetFlagStatus(EVAL_COM1, USART_FLAG_TC) == RESET)
  return ch;
  /* Infinite loop */
  while (1)
 #endif
ND OF FILE****/
2016-01-13 16:10:09     打赏
爱学习的孩子
2016-01-18 23:30:36     打赏
作业六:计算机开机次数
sfr IAP_DATA     = 0xE2;
sfr IAP_ADDRH     = 0xE3;
sfr IAP_ADDRL     = 0xE4;
sfr IAP_CMD      = 0xE5;
sfr IAP_TRIG     = 0xE6;
sfr IAP_CONTR     = 0xE7;
#define           CMD_IDLE  0
#define           CMD_READ   1
#define           CMD_PROGRAM   2
#define           CMD_ERASE   3
#define     ENABLE_IAP0x80
#define     ENABLE_IAP0x81
#define     ENABLE_IAP0x82
#define     ENABLE_IAP0x83
IAP_ADDRESS    0x2000    //STC90C52ϵÁÐEEPROM²âÊÔÆðʼµØÖ·
void IapIdle(void)
IAP_CONTR=0;
IAP_CMD =0;
IAP_TRIG =0;
IAP_ADDRH=0x80;
IAP_ADDRL =0;
unsigned char IapReadByte(unsigned int addt)
unsigned char dat;
IAP_CONTR=ENABLE_IAP;
IAP_CMD =CMD_READ;
IAP_ADDRL=addr;
IAP_ADDRL=addr>>8
IAP_TRIG =0x46;
IAP_TRIG =0xb9;
dat = IAP_DATA;
IapIdle();
return dat;
void Iap ProgramByte(unsigned int addr,unsigned char dat )
IAP_CMD =CMD_REOGRAM;
IAP_ADDRL=addr;
IAP_ADDRH=addr>>8
IAP_DATA=date;
IAP_TRIG =0x46;
IAP_TRIG =0xb9;
IapIdle();
void Iap EraseSector(unsigned int addr )
IAP_CMD =CMD_ERASE;
IAP_ADDRL=addr;
IAP_ADDRH=addr>>8
IAP_TRIG =0x46;
IAP_TRIG =0xb9;
IapIdle();
unsigned char Num=0;
void main(void)
unsigned long i=0;
Num = Iap ReadByte(IAP_ADDRESS+20);
Num++;
Iap EraseSector(IAP_ADDRESS);
Iap ProgramByte(IAP_ADDRESS+20,Num);
for(i=0;i
LED0=0;
DelayMs(100);
LED0=1;
DelayMs(100);
while(1);
2016-01-20 10:28:20     打赏
作业七:DS18B20测温:
//ADC改变灯的颜色:
#include <stdio.h>
#define VREF 3.3
int volt;
unsigned int temp0,temp1,temp2;
 RCC_DeInit();
 RCC_HSICmd(ENABLE);
 RCC_PLLCmd(ENABLE);
   SystemInit();
       - One Stop Bit
       - No parity
 USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
   u8 j;
   while(n--)
   for(j=0;j<10;j++);
   while(n--)
   delay_us(1000);
void PWM_Config()
   uint16_t PrescalerValue = 0;
   /* TIM2 clock enable */
 /* GPIOA  enable */
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3;//PWM&RGB- PA1 PA2 PA3
     /* Compute the prescaler value */
 PrescalerValue = (uint16_t) (SystemCoreClock / 24000000) - 1;
 TIM_TimeBaseStructure.TIM_Period = 0x07FF;
 TIM_TimeBaseStructure.TIM_Prescaler = PrescalerValue;
 TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
 /* PWM1 Mode configuration: Channel2 ,PA1在通道2*/
 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
 TIM_OCInitStructure.TIM_Pulse = 0xFFFF;
 TIM_OC2Init(TIM2, &TIM_OCInitStructure);
   /* PWM1 Mode configuration: Channel3 PA2在通道3*/
 TIM_OC3Init(TIM2, &TIM_OCInitStructure);
   /* PWM1 Mode configuration: Channel4 PA3在通道4*/
 TIM_OC4Init(TIM2, &TIM_OCInitStructure);
 TIM_ARRPreloadConfig(TIM2, ENABLE);
void ADC_CONFIG(){
   ADC_InitTypeDef ADC_InitStructure;
   #if defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || defined (STM32F10X_HD_VL)
 /* ADCCLK = PCLK2/2 */
 RCC_ADCCLKConfig(RCC_PCLK2_Div2);
#else
 /* ADCCLK = PCLK2/4 */
#endif
ADC_DeInit(ADC1);
 /* Enable ADC1 and GPIOC clock */
 RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOB, ENABLE);
   /* Configure PB0 (ADC Channel14) as analog input -------------------------*/
 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;//ADC所在端口PB0
 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;//模拟输入模式
 /* ADC1 configuration ------------------------------------------------------*/
 ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
 ADC_InitStructure.ADC_ScanConvMode = ENABLE;
 ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
 ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
 ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;//ADC数据右对齐
 ADC_InitStructure.ADC_NbrOfChannel = 1;//ADC通道数为1
 ADC_Init(ADC1, &ADC_InitStructure);//初始化ADC1
 /* Enable ADC1 DMA */
 ADC_DMACmd(ADC1, ENABLE);
 /* Enable ADC1 */
 ADC_Cmd(ADC1, ENABLE);
int Get_ADC(){
    /* ADC1 regular channel configuration */
 ADC_RegularChannelConfig(ADC1, ADC_Channel_8, 1, ADC_SampleTime_55Cycles5);//通道:8 ,采样时间
   /* Enable ADC1 reset calibration register */
 ADC_ResetCalibration(ADC1);//重置ADC1的校准寄存器
 /* Check the end of ADC1 reset calibration register */
 while(ADC_GetResetCalibrationStatus(ADC1));//确认重置完毕
 /* Start ADC1 calibration */
 ADC_StartCalibration(ADC1);
 /* Check the end of ADC1 calibration */
 while(ADC_GetCalibrationStatus(ADC1));
 /* Start ADC1 Software Conversion */
 ADC_SoftwareStartConvCmd(ADC1, ENABLE);
   return ADC_GetConversionValue(ADC1);
void PWM_TEST()
   unsigned int temp0=volt,temp1=0,temp2=volt;
   printf("PWM-RGB TEST......\r\n");
  for(;(temp0>0)||(temp1<volt);temp0--,temp1++)
      TIM_SetCompare2(TIM2, temp0);//temp0:volt~0
    TIM_SetCompare3(TIM2, temp1);//temp1:0~volt
      delay_us(1000);
    for(;(temp0<volt)||(temp2>0);temp0++,temp2--)
      TIM_SetCompare2(TIM2, temp0);//temp0:0~volt
      TIM_SetCompare4(TIM2, temp2);//temp2:volt~0
      delay_us(1000);
  for(;(temp1>0)||(temp2<volt);temp1--,temp2++)
      TIM_SetCompare4(TIM2, temp2);//temp2:0~volt
      TIM_SetCompare3(TIM2, temp1);//temp1:volt~0
      delay_us(1000);
int main(void)
 float Volt=0.00;
   int ADValue = 0;
 USART_int(115200);
   ADC_CONFIG();
   Get_ADC();
   PWM_Config();
   delay_ms(1000);
   printf(" config done...\r\n");
   while(1)
       ADValue = Get_ADC();
       Volt = VREF*ADValue/4095;
       volt=Volt*1000;
       printf("===============================\r\n");
       printf("The ADC value is:%d\r\n",ADValue);
       printf("The Volt is:%f V\r\n",Volt);
       printf("The volt is:%d \r\n",volt);
       PWM_TEST();
       delay_ms(500);
 while (1)
#endif
#ifdef __GNUC__
#else
PUTCHAR_PROTOTYPE
 return ch;
 while (1)
共8条 1/1 1 跳转至
