1602 LCD 显示
这个浇花系统计划加上LCD显示,比如当前湿度等等
使用Intel Edison以及Grove Starter Kit附带的RGB Backlight LCD来实现这个非常简单
打开:Sketchbook_Starter_Kit_V2.0-master\Grove_RGB_Backlight_LCD
发现里边有各种示例
以下是Hello World的示例
/* Hello World.ino 2013 Copyright (c) Seeed Technology Inc. All right reserved. Author:Loovee 2013-9-18 Grove - Serial LCD RGB Backlight demo. This library is free software; you can redistribute it and/or modify it under the terms of the GNU Lesser General Public License as published by the Free Software Foundation; either version 2.1 of the License, or (at your option) any later version. This library is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU Lesser General Public License for more details. You should have received a copy of the GNU Lesser General Public License along with this library; if not, write to the Free Software Foundation, Inc., 51 Franklin St, Fifth Floor, Boston, MA 02110-1301 USA */ #include <Wire.h> #include "rgb_lcd.h" rgb_lcd lcd; const int colorR = 0; const int colorG = 0XFF; const int colorB = 0; void setup() { // set up the LCD's number of columns and rows: lcd.begin(16, 2); lcd.setRGB(colorR, colorG, colorB); // Print a message to the LCD. lcd.print("hello, world!"); delay(1000); } void loop() { // set the cursor to column 0, line 1 // (note: line 1 is the second row, since counting begins with 0): lcd.setCursor(0, 1); // print the number of seconds since reset: lcd.print(millis()/1000); delay(100); } /********************************************************************************************************* END FILE *********************************************************************************************************/
除了显示以外,我们需要读取湿度传感器的数据
这个很简单,就是通过模拟口读回数值进行判断
可以用电位器模拟,代码如下:
// Demo for Grove - Starter Kit V2.0 // Prints the value of the potentiometer to the serial console. // Connect the Grove - Rotary Angle Sensor to the socket marked A0 // Open the Serial Monitor in the Arduino IDE after uploading // Define the pin to which the angle sensor is connected. const int potentiometer = A0; void setup() { // Configure the serial communication line at 9600 baud (bits per second.) Serial.begin(9600); // Configure the angle sensor's pin for input. pinMode(potentiometer, INPUT); } void loop() { // Read the value of the sensor and print it to the serial console. int value = analogRead(potentiometer); Serial.println(value); // Wait 0.1 seconds between readings. delay(100); }
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 |
