除了LCD显示,读取模拟值(湿度传感器)以外,还要控制继电器
这个就更简单了,就是给高电平或者低电平就可以啦
// Demo for Grove - Starter Kit V2.0
// Uses the Grove - Button to control the Grove - Relay.
// When the button is pressed, the relay will be in the "closed" position.
// Connect the Grove - Button to the socket marked D3
// Connect the Grove - Relay to D8
// Define the pins to which the button and relay are attached.
const int buttonPin = 3;
const int relayPin = 8;
void setup()
// Configure the relay's pin for output signals.
pinMode(relayPin, OUTPUT);
// Configure the button's pin for input signals.
pinMode(buttonPin, INPUT);
void loop()
// Read the state of the button.
int buttonState = digitalRead(buttonPin);
// If the button is pressed, activate (close) the relay.
if (buttonState == 1)
digitalWrite(relayPin, HIGH);
else
digitalWrite(relayPin, LOW);
delay(10);
Web client
This sketch connects to a website (http://www.google.com)
using an Arduino Wiznet Ethernet shield.
Circuit:
* Ethernet shield attached to pins 10, 11, 12, 13
created 18 Dec 2009
modified 9 Apr 2012
by David A. Mellis
#include <SPI.h>
#include <Ethernet.h>
// Enter a MAC address for your controller below.
// Newer Ethernet shields have a MAC address printed on a sticker on the shield
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(221,200,245,242); // Google
// Initialize the Ethernet client library
// with the IP address and port of the server
// that you want to connect to (port 80 is default for HTTP):
EthernetClient client;
void setup() {
// Open serial communications and wait for port to open:
Serial.begin(9600);
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
// start the Ethernet connection:
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// no point in carrying on, so do nothing forevermore:
for(;;)
// give the Ethernet shield a second to initialize:
delay(1000);
Serial.println("connecting...");
// if you get a connection, report back via serial:
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.println("GET / HTTP/1.0");
client.println();
else {
// if you didn't get a connection to the server:
Serial.println("connection failed");
void loop()
// if there are incoming bytes available
// from the server, read them and print them:
if (client.available()) {
char c = client.read();
Serial.print(c);
// if the server's disconnected, stop the client:
if (!client.connected()) {
Serial.println();
Serial.println("disconnecting.");
client.stop();
// do nothing forevermore:
for(;;)
使用usb以太网的网络客户端
因为google被封锁,所以我将IP换成了我自己搭建的服务器IP
返回内容如下:
HTTP/1.1 200 OK Date: Fri, 09 Sep 2016 01:04:32 GMT Server: Apache/2.4.10 (Raspbian) Last-Modified: Sat, 11 Jun 2016 00:44:09 GMT ETag: "d-534f5f40499a6" Accept-Ranges: bytes Content-Length: 13 Connection: close Content-Type: text/html Hello World!
Web client
using a WiFi shield.
This example is written for a network using WPA encryption. For
WEP or WPA, change the Wifi.begin() call accordingly.
Circuit:
* WiFi shield attached
created 13 July 2010
by dlf (Metodo2 srl)
modified 31 May 2012
by Tom Igoe
#include
#include
char ssid[] = "MYWIFI"; // your network SSID (name)
char pass[] = "xxxxxx"; // your network password (use for WPA, or use as key for WEP)
int keyIndex = 0; // your network key Index number (needed only for WEP)
int status = WL_IDLE_STATUS;
// if you don't want to use DNS (and reduce your sketch size)
// use the numeric IP instead of the name for the server:
//IPAddress server(74,125,232,128); // numeric IP for Google (no DNS)
char server[] = "iot.godpub.com"; // name address for Google (using DNS)
WiFiClient client;
void setup() {
//Initialize serial and wait for port to open:
Serial.begin(9600);
while (!Serial) {
// check for the presence of the shield:
if (WiFi.status() == WL_NO_SHIELD) {
Serial.println("WiFi shield not present");
// don't continue:
while(true);
String fv = WiFi.firmwareVersion();
if( fv != "1.1.0" )
Serial.println("Please upgrade the firmware");
// attempt to connect to Wifi network:
while (status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: ");
Serial.println(ssid);
// Connect to WPA/WPA2 network. Change this line if using open or WEP network:
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
Serial.println("Connected to wifi");
printWifiStatus();
Serial.println("\nStarting connection to server...");
Serial.println("connected to server");
client.println("GET / HTTP/1.1");
client.println("Host: iot.godpub.com");
client.println("Connection: close");
client.println();
void loop() {
while (client.available()) {
Serial.write(c);
Serial.println();
Serial.println("disconnecting from server.");
client.stop();
while(true);
void printWifiStatus() {
// print the SSID of the network you're attached to:
Serial.print("SSID: ");
Serial.println(WiFi.SSID());
// print your WiFi shield's IP address:
IPAddress ip = WiFi.localIP();
Serial.print("IP Address: ");
Serial.println(ip);
// print the received signal strength:
long rssi = WiFi.RSSI();
Serial.print("signal strength (RSSI):");
Serial.print(rssi);
Serial.println(" dBm");
因为USB以太网需要连接电脑,而实际应用中,链接电脑不太现实
不能为了自动浇花配置个电脑
所以使用WIFI还是比较方便的
其中"MYWIFI"是我的无线网ID
"xxxxxx"是我的无线网密码
iot.godpub.com 是我自建的web服务器域名
串口返回的全部信息如下:
Attempting to connect to SSID: MYWIFI Connected to wifi SSID: MYWIFI IP Address: 192.168.249.243 signal strength (RSSI):-40 dBm Starting connection to server... connected to server HTTP/1.1 200 OK Date: Fri, 09 Sep 2016 01:04:32 GMT Server: Apache/2.4.10 (Raspbian) Last-Modified: Sat, 11 Jun 2016 00:44:09 GMT ETag: "d-534f5f40499a6" Accept-Ranges: bytes Content-Length: 13 Connection: close Content-Type: text/html Hello World!
网络数据发送
温湿度以及是否灌溉信息定时通过HTTP协议上报至网络。
GET请求格式大致如下:
/water.php?h=222&t=28.2&s=1
其中:
H为湿度
T为温度
s为是否执行灌溉
详见代码。
服务器端
服务器端应该实现的功能包括但不限于:
接收并存储数据到数据库
提供展示页面以表格或者其它直观的方式展示数据。
本例中我使用BANAPI M2+ 自建了LMAP网站环境。
使用PHP接收数据。
因为服务器端属于另外的范畴,本例不做深入讨论。
服务器端最简单的示例代码如下:
<?php
printf("Humidity:\t%.2f\n", $_GET['h']);
printf("Temperature:\t%.2f\n", $_GET['t']);
$status = $_GET['s']==0?"False":"True";
printf("Watered:\t%s\n", $status);
主要作用为将Edison发送的数据以一定格式显示。
可用于调试Edison发送网络数据部分。
| 有奖活动 | |
| 硬核工程师专属补给计划——填盲盒 | |
| “我踩过的那些坑”主题活动——第002期 | |
| 【EEPW在线】E起听工程师的声音! | |
| 高校联络员开始招募啦!有惊喜!! | |
| FPGA配置被打赏¥10元 | |
