好多地方推荐dialog不过在ssh下一直显示乱码,也不知道什么原因,倒是whiptail不乱码
开始做了一个假的进度条,然后做了一个菜单,设置板卡部分还需要完善
好吧,还是用代码说话吧
#!/bin/bash
# by MikuQ(i@mikuq.com) 2017-1-6
for ((i = 0 ; i <= 100 ; i+=1)); do
sleep 0.01
echo $i
done
sleep 0.5
} | whiptail --gauge "正在加载MikuDuino配置工具" 6 60 0
if [ "$(id -u)" -ne 0 ]; then
whiptail --title "错误" --msgbox "配置工具需要ROOT权限" --ok-button "离开" 10 60
echo
echo -e "\033[31m 需要ROOT权限 \033[0m"
echo
exit 1
fi
menu()
OPTION=$(whiptail --title "MikuDuino配置工具 V0.8" --menu "\n选择需要的配置项" 15 60 4 "1" "编译MikuDuino" "2" "设置开发板" "3" "安装MikuDuino" "4" "退出配置工具" --ok-button "确定" --cancel-button "离开" 3>&1 1>&2 2>&3)
exitstatus=$?
if [ $exitstatus = 0 ]; then
case $OPTION in
1) make;;
2) echo "设置";;
3) make install;;
4) echo
echo -e "\033[32m 技术参考 https://help.mikuduino.com/ \033[0m"
echo
exit 0;;
esac
else
echo
echo -e "\033[32m 技术资料 https://help.mikuduino.com/ \033[0m"
echo
fi
while true
do
menu
done
