电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » stm iap 跳转后 FLASH的SR出错!
共3条 1/1 1 跳转至页
2017-06-20 10:51:39     打赏
我在IAP跳转后出现了FLASH_FLAG_PGSERR的错误,跳转后app能正确跑了起来,但是读写内部的flash出错,出现的是FLASH_FLAG_PGSERR的错误,打印的寄存器值是:>>>>>>>>>>>>FLASH->ACR:[0x705]
>>>>>>>>>>>>FLASH->KEYR:[0x0]
>>>>>>>>>>>>FLASH->OPTKEYR:[0x0]
>>>>>>>>>>>>FLASH->SR:[0x80]
>>>>>>>>>>>>FLASH->CR:[0x80000200]
>>>>>>>>>>>>FLASH->OPTCR:[0xfffaaed]
>>>>>>>>>>>>FLASH->OPTCR1:[0x0]
我在跳转前打印的寄存器是这样的:
>>>>>>>>>>>>FLASH->ACR:[0x705]
>>>>>>>>>>>>FLASH->KEYR:[0x0]
>>>>>>>>>>>>FLASH->SR:[0x0]
>>>>>>>>>>>>FLASH->OPTCR1:[0x0]
打印前的
   UsartDeInit();
        HAL_DeInit();
        NVIC_DisableIRQ(SysTick_IRQn);
        __disable_irq();
        /* Jump to user application */
        JumpAddress = *(__IO uint32_t*)(APPLICATION_ADDRESS + 4);
        Jump_To_Application = (pFunction)JumpAddress;
        //SCB->VTOR = (uint32_t)APP_VECTOR_TABLE;
        /* Initialize user application's Stack Pointer */
        __set_MSP(*(__IO uint32_t*) APPLICATION_ADDRESS);
        Jump_To_Application();
跳转后是:
   __disable_irq();
    NVIC_SetVectorTable(NVIC_VectTab_FLASH, VECTOR_ADDRESS);
    /* USER CODE END 1 */
    /* MCU Configuration----------------------------------------------------------*/
    /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
     HAL_Init();
    /* Configure the system clock */
    SystemClock_Config();
    __enable_irq();
    /* Initialize all configured peripherals */
    MX_GPIO_Init();
    MX_DMA_Init();
    /* USER CODE BEGIN 2 */
    GPIOInit();
    UsartInit();
求大神分析一下,为啥跳转前后会导致flash的FLASH_FLAG_PGSERR错误???????????????
2017-06-20 11:10:19     打赏
原来楼主还没有搞定呢。
帮楼主加点人气,希望在这有大神能解决。
管理员
2017-06-20 22:05:37     打赏
帮楼主加点人气,希望在这有大神能解决。
共3条 1/1 1 跳转至页
