利用quartusII 13.1生成了一个nco 核,进行模块例化和tb文件编写
编译通过,没有问题,点击run rtl simulation,modelsim中仿真报错如图
![](http://bbs.elecfans.com/data/attachment/forum/201706/25/102117d7xdhyh0zn0nngv7.png.thumb.jpg)
显示在执行nco_run_msim_rtl_verilog.do文件在第41行停止了,文件中的第41行如图
![](http://bbs.elecfans.com/data/attachment/forum/201706/25/102115ci8g0iiah0n8q2pp.png.thumb.jpg)
以前在仿真FIR核时出现过类似问题,我的解决方法是改掉模块例化名,原来的模块例化名如图
![](http://bbs.elecfans.com/data/attachment/forum/201706/25/102117r5ohcrm39oc9h9r1.png.thumb.jpg)
原来编译好的IP核如图
![](http://bbs.elecfans.com/data/attachment/forum/201706/25/102115n00uu90199go4pxd.png.thumb.jpg)
改正:将模块例化名中的 "_st" 删掉,改正后的模块例化名如图
![](http://bbs.elecfans.com/data/attachment/forum/201706/25/102116jrod6amir0osaayu.png.thumb.jpg)
编译后的IP核显示如图
![](http://bbs.elecfans.com/data/attachment/forum/201706/25/102116jf8i2spofe2o2nwf.png.thumb.jpg)
再次编译点击仿真,这回却报出了另外一个错误
![](http://bbs.elecfans.com/data/attachment/forum/201706/25/102118nnvgxnxq98xnn8v8.png.thumb.jpg)
错误中提到的文件内容粘贴如下
Info: Start Nativelink Simulation process
Error: You did not generate the simulation model files or you generated the IP file using an older version of MegaCore which is not supported by RTL NativeLink Simulation
Error: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode: NONE
Nativelink TCL script failed with errorInfo: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
(procedure "get_ip_info" line 1)
invoked from within
"get_ip_info $full_file_name"
(procedure "run_eda_simulation_tool" line 195)
invoked from within
"run_eda_simulation_tool eda_opts_hash"
编写的例化代码核tb代码如下
module nco (
phi_inc_i,
clk,
reset_n,
clken,
fsin_o,
fcos_o,
out_valid);
input [31:0] phi_inc_i;
input clk;
input reset_n;
input clken;
output [17:0] fsin_o;
output [17:0] fcos_o;
output out_valid;
nco1 nco1_inst(
.phi_inc_i(phi_inc_i),
.clk(clk),
.reset_n(reset_n),
.clken(clken),
.fsin_o(fsin_o),
.fcos_o(fcos_o),
.out_valid(out_valid));
endmodule
`timescale 1ps / 1ps
module nco_vlg_tst();
wire out_valid;
wire [17:0] sin_val;
wire [17:0] cos_val;
reg [31:0] phi;
reg reset_n;
reg clken;
reg clk;
parameter CYCLE = 20000;
parameter HALF_CYCLE = 10000;
initial
begin
$dumpvars;
#0 clk = 1'b0;
#0 reset_n = 1'b0;
#0 clken = 1'b1;
#0 phi = 32'b00000101000111101011100001010010;
#(14*HALF_CYCLE) reset_n = 1'b1;
end
always
begin
#HALF_CYCLE clk = 1;
#HALF_CYCLE clk = 0;
end
integer sin_ch, sin_print;
integer cos_ch, cos_print;
initial
begin
sin_ch = $fopen ("fsin_o_ver_nco1.txt");
cos_ch = $fopen ("fcos_o_ver_nco1.txt");
end
always @(posedge clk)
begin
if(reset_n==1'b1 & out_valid==1'b1)
begin
if (sin_val[17:0] < (1<<17))
sin_print = sin_val[17:0];
else
sin_print = sin_val[17:0] - (1<<18);
if (cos_val[17:0] < (1<<17))
cos_print = cos_val[17:0];
else
cos_print = cos_val[17:0] - (1<<18);
$fdisplay (sin_ch, "%0d", sin_print);
$fdisplay (cos_ch, "%0d", cos_print);
end
end
nco i_nco1 (
.out_valid(out_valid),
.fsin_o(sin_val[17:0]),
.fcos_o(cos_val[17:0]),
.phi_inc_i(phi[31:0]),
.reset_n(reset_n),
.clken(clken),
.clk(clk)
endmodule
