电子产品世界 » 论坛首页 » 嵌入式开发 » FPGA » quartus II 13.1 nco核仿真报错,error loading d
quartus II 13.1 nco核仿真报错,error loading design,显示do文件执行到41行是停止
2017-06-26 16:27:01     打赏
情况是这样
利用quartusII 13.1生成了一个nco 核,进行模块例化和tb文件编写
编译通过,没有问题,点击run rtl simulation,modelsim中仿真报错如图
显示在执行nco_run_msim_rtl_verilog.do文件在第41行停止了,文件中的第41行如图
以前在仿真FIR核时出现过类似问题,我的解决方法是改掉模块例化名,原来的模块例化名如图
原来编译好的IP核如图
改正:将模块例化名中的  "_st"  删掉,改正后的模块例化名如图
编译后的IP核显示如图
再次编译点击仿真,这回却报出了另外一个错误
错误中提到的文件内容粘贴如下
Info: Start Nativelink Simulation process
Error: You did not generate the simulation model files or you generated the IP file using an older version of MegaCore which is not supported by RTL NativeLink Simulation
Error: Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
Error: NativeLink simulation flow was NOT successful
================The following additional information is provided to help identify the cause of error while running nativelink scripts=================
Nativelink TCL script failed with errorCode:  NONE
Nativelink TCL script failed with errorInfo:  Regenerate the IP and simulation model files using the latest version of MegaCore for RTL NativeLink Simulation flow to function correctly
    (procedure "get_ip_info" line 1)
    invoked from within
"get_ip_info $full_file_name"
    (procedure "run_eda_simulation_tool" line 195)
    invoked from within
"run_eda_simulation_tool eda_opts_hash"
编写的例化代码核tb代码如下
module nco (
        phi_inc_i,
        clk,
        reset_n,
        clken,
        fsin_o,
        fcos_o,
        out_valid);
        input        [31:0]        phi_inc_i;
        input                clk;
        input                reset_n;
        input                clken;
        output        [17:0]        fsin_o;
        output        [17:0]        fcos_o;
        output                out_valid;
        nco1        nco1_inst(
                .phi_inc_i(phi_inc_i),
                .clk(clk),
                .reset_n(reset_n),
                .clken(clken),
                .fsin_o(fsin_o),
                .fcos_o(fcos_o),
                .out_valid(out_valid));
endmodule
`timescale 1ps / 1ps
module nco_vlg_tst();
wire out_valid;
wire [17:0] sin_val;
wire [17:0] cos_val;
reg [31:0] phi;
reg reset_n;
reg clken;
reg clk;
parameter CYCLE = 20000;
parameter HALF_CYCLE = 10000;
initial
  begin
    $dumpvars;
    #0 clk = 1'b0;
    #0 reset_n = 1'b0;
    #0 clken = 1'b1;
    #0 phi = 32'b00000101000111101011100001010010;
    #(14*HALF_CYCLE) reset_n = 1'b1;
  end
always
  begin
    #HALF_CYCLE clk = 1;
    #HALF_CYCLE clk = 0;
  end
integer sin_ch, sin_print;
integer cos_ch, cos_print;
initial
  begin
    sin_ch = $fopen ("fsin_o_ver_nco1.txt");
    cos_ch = $fopen ("fcos_o_ver_nco1.txt");
  end
always @(posedge clk)
  begin
    if(reset_n==1'b1 & out_valid==1'b1)
      begin
        if (sin_val[17:0] < (1<<17))
          sin_print = sin_val[17:0];
        else
          sin_print =  sin_val[17:0] - (1<<18);
      if (cos_val[17:0] < (1<<17))
        cos_print = cos_val[17:0];
      else
        cos_print =  cos_val[17:0] - (1<<18);
    $fdisplay (sin_ch, "%0d", sin_print);
    $fdisplay (cos_ch, "%0d", cos_print);
      end
end
nco i_nco1 (
    .out_valid(out_valid),
    .fsin_o(sin_val[17:0]),
    .fcos_o(cos_val[17:0]),
    .phi_inc_i(phi[31:0]),
    .reset_n(reset_n),
    .clken(clken),
    .clk(clk)
endmodule
