Given a binary tree, return the bottom-up level order traversal of its nodes' values. (ie, from left to right, level by level from leaf to root).
For example:
Given binary tree{3,9,20,#,#,15,7},
3 / \ 9 20 / \ 15 7
return its bottom-up level order traversal as:
[ [15,7] [9,20], [3], ]
confused what"{1,#,2,3}"means? > read more on how binary tree is serialized on OJ.
OJ's Binary Tree Serialization:
The serialization of a binary tree follows a level order traversal, where '#' signifies a path terminator where no node exists below.
Here's an example:
1 / \ 2 3 / 4 \ 5
The above binary tree is serialized as"{1,2,3,#,#,4,#,#,5}".
思路:层次遍历二叉树,然后再进行逆序操作;
- class Solution {
- public:
- vector<vector<int>> levelOrderBottom(TreeNode* root)
- vector<vector<int>> res;
- if (root == NULL)
- return res;
- queue<TreeNode*> q;
- q.push(root);
- while (q.size()>0)
- vector<int> level;
- for (int i = 0, n = q.size(); i<n; i++)
- TreeNode* tmp = q.front();
- q.pop();
- level.push_back(tmp->val);
- if (tmp->left)
- q.push(tmp->left);
- if (tmp->right)
- q.push(tmp->right);
- res.push_back(level);
- reverse(res.begin(), res.end());
- return res;
 我要赚赏金 STM32
STM32 MCU
MCU 通讯及无线技术
通讯及无线技术 物联网技术
物联网技术 电子DIY
电子DIY 板卡试用
板卡试用 基础知识
基础知识 软件与操作系统
软件与操作系统 我爱生活
我爱生活 小e食堂
小e食堂
