电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 用纯C11标准写泛型例程
用纯C11标准写泛型例程
2019-02-17 18:39:42     打赏
/* This Source Code Form is subject to the terms of the Mozilla Public
 * License, v. 2.0. If a copy of the MPL was not distributed with this
 * file, You can obtain one at http://mozilla.org/MPL/2.0/. */
#include <stdint.h>
#include <iso646.h>
#include <math.h>
#include <inttypes.h>
#include <stdio.h>
#include <stdlib.h>
#include <float.h>
#include “tgmath_avr.h“
/* C11 Overload
#define def_max(a, b) (((a) >= (b)) ? (a) : (b))
#define def_min(a, b) (((a) < (b)) ? (a) : (b))
#define read_bit(_source_bits, _source_width, _n) _Generic(_source_bits, uint8_t: read_bit_ui8, \
        uint16_t: read_bit_ui16, \
        uint32_t: read_bit_ui32, \
														    			 uint64_t: read_bit_ui64, \
														    			 default: read_bit_ui64 \
														  )(_source_bits, _source_width, _n)
#define write_bit(_source_bits, _source_width, _n, _a_bit) _Generic(_source_bits, uint8_t: write_bit_ui8, \
        uint16_t: write_bit_ui16, \
																    			  uint32_t: write_bit_ui32, \
																    			  uint64_t: write_bit_ui64, \
																    			  default: write_bit_ui64 \
																   )(_source_bits, _source_width, _n, _a_bit)
#define xor_bit(_source_bits, _source_width, _n, _a_bit) _Generic(_source_bits, uint8_t: xor_bit_ui8, \
        uint16_t: xor_bit_ui16, \
																    			uint32_t: xor_bit_ui32, \
																    			uint64_t: xor_bit_ui64, \
																    			default: xor_bit_ui64 \
#define random_round(_x, _rounded_to_exp10) _Generic(_x, float: random_round_f, \
                                                         double: random_round_d, \
														 default: random_round_f \
													)(_x, _rounded_to_exp10)
#define integer_number_to_string(_input_number, _leader_character, _display_width, _numeric_string, _array_len) _Generic(_input_number, int8_t: integer_number_to_string_i8, \
        int16_t: integer_number_to_string_i16, \
																																		int32_t: integer_number_to_string_i32, \
																																		default: integer_number_to_string_i32 \
																														)(_input_number, _leader_character, _display_width, _numeric_string, _array_len)
#define floating_number_to_string(_input_number, _decimal_digits, _numeric_string, _array_len) _Generic(_input_number, float: floating_number_to_string_f, \
        double: floating_number_to_string_d, \
																									    			   default: floating_number_to_string_f \
																									   )(_input_number, _decimal_digits, _numeric_string, _array_len)
//Begin GCC Overload
#define max(_a, _b) \
        __builtin_choose_expr(__builtin_types_compatible_p(typeof(sizeof(_a) >= sizeof(_b) ? _a : _b), int8_t), max_i8(_a, _b), \
         __builtin_choose_expr(__builtin_types_compatible_p(typeof(sizeof(_a) >= sizeof(_b) ? _a : _b), uint8_t), max_ui8(_a, _b), \
          __builtin_choose_expr(__builtin_types_compatible_p(typeof(sizeof(_a) >= sizeof(_b) ? _a : _b), int16_t), max_i16(_a, _b), \
           __builtin_choose_expr(__builtin_types_compatible_p(typeof(sizeof(_a) >= sizeof(_b) ? _a : _b), uint16_t), max_ui16(_a, _b), \
            __builtin_choose_expr(__builtin_types_compatible_p(typeof(sizeof(_a) >= sizeof(_b) ? _a : _b), int32_t), max_i32(_a, _b), \
             __builtin_choose_expr(__builtin_types_compatible_p(typeof(sizeof(_a) >= sizeof(_b) ? _a : _b), uint32_t), max_ui32(_a, _b), \
              __builtin_choose_expr(__builtin_types_compatible_p(typeof(sizeof(_a) >= sizeof(_b) ? _a : _b), int64_t), max_i64(_a, _b), \
               __builtin_choose_expr(__builtin_types_compatible_p(typeof(sizeof(_a) >= sizeof(_b) ? _a : _b), uint64_t), max_ui64(_a, _b), \
        max_i64(_a, _b) \
#define read_bit(_source_bits, _source_width, _n) \
        __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint8_t), read_bit_ui8(_source_bits, _source_width, _n), \
         __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint16_t), read_bit_ui16(_source_bits, _source_width, _n), \
          __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint32_t), read_bit_ui32(_source_bits, _source_width, _n), \
           __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint64_t), read_bit_ui64(_source_bits, _source_width, _n), \
        read_bit_ui64(_source_bits, _source_width, _n) \
#define write_bit(_source_bits, _source_width, _n, _a_bit) \
        __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint8_t), write_bit_ui8(_source_bits, _source_width, _n, _a_bit), \
         __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint16_t), write_bit_ui16(_source_bits, _source_width, _n, _a_bit), \
          __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint32_t), write_bit_ui32(_source_bits, _source_width, _n, _a_bit), \
           __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint64_t), write_bit_ui64(_source_bits, _source_width, _n, _a_bit), \
        write_bit_ui64(_source_bits, _source_width, _n, _a_bit) \
#define xor_bit(_source_bits, _source_width, _n, _a_bit) \
        __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint8_t), xor_bit_ui8(_source_bits, _source_width, _n, _a_bit), \
         __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint16_t), xor_bit_ui16(_source_bits, _source_width, _n, _a_bit), \
          __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint32_t), xor_bit_ui32(_source_bits, _source_width, _n, _a_bit), \
           __builtin_choose_expr(__builtin_types_compatible_p(typeof(_source_bits), uint64_t), xor_bit_ui64(_source_bits, _source_width, _n, _a_bit), \
        xor_bit_ui64(_source_bits, _source_width, _n, _a_bit) \
#define random_round(_x, _rounded_to_exp10) \
        __builtin_choose_expr(__builtin_types_compatible_p(typeof(_x), float), random_round_f(_x, _rounded_to_exp10), \
         __builtin_choose_expr(__builtin_types_compatible_p(typeof(_x),double), random_round_d(_x, _rounded_to_exp10), \
        random_round_f(_x, _rounded_to_exp10) \
#define integer_number_to_string(_input_number, _leader_character, _display_width, _numeric_string, _array_len) \
        __builtin_choose_expr(__builtin_types_compatible_p(typeof(_input_number), int8_t), integer_number_to_string_i8(_input_number, _leader_character, _display_width, _numeric_string, _array_len), \
         __builtin_choose_expr(__builtin_types_compatible_p(typeof(_input_number), int16_t), integer_number_to_string_i16(_input_number, _leader_character, _display_width, _numeric_string, _array_len), \
          __builtin_choose_expr(__builtin_types_compatible_p(typeof(_input_number), int32_t), integer_number_to_string_i32(_input_number, _leader_character, _display_width, _numeric_string, _array_len), \
        integer_number_to_string_i32(_input_number, _leader_character, _display_width, _numeric_string, _array_len)) \
#define floating_number_to_string(_input_number, _decimal_digits, _numeric_string, _array_len) \
        __builtin_choose_expr(__builtin_types_compatible_p(typeof(_input_number), float), floating_number_to_string_f(_input_number, _decimal_digits, _numeric_string, _array_len), \
         __builtin_choose_expr(__builtin_types_compatible_p(typeof(_input_number),double), floating_number_to_string_d(_input_number, _decimal_digits, _numeric_string, _array_len), \
        floating_number_to_string_f(_input_number, _decimal_digits, _numeric_string, _array_len) \
//End GCC Overload.
inline int8_t max_i8(int8_t a, int8_t b)
	return a > b ? a : b;
inline uint8_t max_ui8(uint8_t a, uint8_t b)
inline int16_t max_i16(int16_t a, int16_t b)
inline uint16_t max_ui16(uint16_t a, uint16_t b)
inline int32_t max_i32(int32_t a, int32_t b)
inline uint32_t max_ui32(uint32_t a, uint32_t b)
inline int64_t max_i64(int64_t a, int64_t b)
inline uint64_t max_ui64(uint64_t a, uint64_t b)
uint8_t read_bit_ui8(uint8_t source_bits, uint_fast8_t source_width, uint_fast8_t n)  //Lowest order is 0
	const uint_fast8_t MAXIMUM_WIDTH_BIT = 8;
	if ((source_bits >> source_width) not_eq 0)
		return source_bits;
	if (source_width > MAXIMUM_WIDTH_BIT)
		return source_bits;
	if (n >= source_width)
		return source_bits;
	return (source_bits >> n) bitand ((uint8_t)0x01);
uint16_t read_bit_ui16(uint16_t source_bits, uint_fast8_t source_width, uint_fast8_t n)  //Lowest order is 0
	const uint_fast8_t MAXIMUM_WIDTH_BIT = 16;
		return source_bits;
		return source_bits;
		return source_bits;
	return (source_bits >> n) bitand ((uint16_t)0x01);
uint32_t read_bit_ui32(uint32_t source_bits, uint_fast8_t source_width, uint_fast8_t n)  //Lowest order is 0
	const uint_fast8_t MAXIMUM_WIDTH_BIT = 32;
		return source_bits;
		return source_bits;
		return source_bits;
	return (source_bits >> n) bitand ((uint32_t)0x01);
uint64_t read_bit_ui64(uint64_t source_bits, uint_fast8_t source_width, uint_fast8_t n)  //Lowest order is 0
	const uint_fast8_t MAXIMUM_WIDTH_BIT = 64;
		return source_bits;
		return source_bits;
		return source_bits;
	return (source_bits >> n) bitand ((uint64_t)0x01);
uint8_t write_bit_ui8(uint8_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
		return source_bits;
		return source_bits;
		return source_bits;
	if ((a_bit >> 1) not_eq 0)
		return source_bits;
	(a_bit == 0) ? (source_bits and_eq (compl(((uint8_t)0x01) << n))) : (source_bits or_eq (((uint8_t)0x01) << n));
	return source_bits;
uint16_t write_bit_ui16(uint16_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
		return source_bits;
		return source_bits;
		return source_bits;
		return source_bits;
	(a_bit == 0) ? (source_bits and_eq (compl(((uint16_t)0x01) << n))) : (source_bits or_eq (((uint16_t)0x01) << n));
	return source_bits;
uint32_t write_bit_ui32(uint32_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
		return source_bits;
		return source_bits;
		return source_bits;
		return source_bits;
	(a_bit == 0) ? (source_bits and_eq (compl(((uint32_t)0x01) << n))) : (source_bits or_eq (((uint32_t)0x01) << n));
	return source_bits;
uint64_t write_bit_ui64(uint64_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
		return source_bits;
		return source_bits;
		return source_bits;
		return source_bits;
	(a_bit == 0) ? (source_bits and_eq (compl(((uint64_t)0x01) << n))) : (source_bits or_eq (((uint64_t)0x01) << n));
	return source_bits;
uint8_t xor_bit_ui8(uint8_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
		return source_bits;
		return source_bits;
		return source_bits;
		return source_bits;
	return source_bits xor (((uint8_t)a_bit) << n);
uint16_t xor_bit_ui16(uint16_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
		return source_bits;
		return source_bits;
		return source_bits;
		return source_bits;
	return source_bits xor (((uint16_t)a_bit) << n);
uint32_t xor_bit_ui32(uint32_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
		return source_bits;
		return source_bits;
		return source_bits;
		return source_bits;
	return source_bits xor (((uint32_t)a_bit) << n);
uint64_t xor_bit_ui64(uint64_t source_bits, uint_fast8_t source_width, uint_fast8_t n, uint_fast8_t a_bit)  //Lowest order is 0
		return source_bits;
		return source_bits;
		return source_bits;
		return source_bits;
	return source_bits xor (((uint64_t)a_bit) << n);
float random_round_f(float x, int_fast8_t rounded_to_exp10)
	const uint_fast8_t MAX_SIGNIFICANT_FIGURES = FLT_DIG - 1;
	if (not isfinite(x))
		return x;
	float absolute_value = fabs(x);
	if ((floor(log10(absolute_value)) - rounded_to_exp10) >= MAX_SIGNIFICANT_FIGURES)
		return x;
	float integer_part, decimal_part;
	decimal_part = modff(absolute_value * pow(10, -rounded_to_exp10), &integer_part);
	if (decimal_part > 0.5)
		integer_part += 1;
	else
		if (decimal_part == 0.5)
			integer_part += rand() % 2;
	return copysign((integer_part + 0.1) * pow(10, rounded_to_exp10), x);
double random_round_d(double x, int_fast8_t rounded_to_exp10)
	const uint_fast8_t MAX_SIGNIFICANT_FIGURES = DBL_DIG - 1;
		return x;
	double absolute_value = fabs(x);
		return x;
	double integer_part, decimal_part;
	decimal_part = modf(absolute_value * pow(10, -rounded_to_exp10), &integer_part);
		integer_part += 1;
	else
uint_fast8_t integer_number_to_string_i8(int8_t input_number, char leader_character, uint_fast8_t display_width, char numeric_string[], uint_fast8_t array_len)  //input_number range is INT8_MAX to INT8_MIN. Returns the numeric string length.
	const uint_fast8_t INTERMEDIATE_MAX_WIDTH = 1 + (floor(log10(-INT8_MIN)) + 1);  //sign + Max significant figures
	char intermediate_string[INTERMEDIATE_MAX_WIDTH + 1];
	if (leader_character < '\x0')
		return 0;
	if (display_width >= array_len)
		return 0;
	if (array_len <= 1)
		return 0;
	int_fast8_t intermediate_len = sprintf(intermediate_string, "%-"PRIi8, input_number);
	if (intermediate_len > display_width)
		return 0;
	int_fast8_t i = 0;
	int_fast8_t n = display_width - (intermediate_len + 1);
	if (isgraph(leader_character))
		while (i <= n)
			numeric_string[i] = leader_character;
			++i;
	n = i + intermediate_len;
	int_fast8_t j = 0;
	while (i <= n)
		numeric_string[i] = intermediate_string[j];
		++i;
		++j;
	i -= 1;
	return i;  //Returns the numeric string length
uint_fast8_t integer_number_to_string_i16(int16_t input_number, char leader_character, uint_fast8_t display_width, char numeric_string[], uint_fast8_t array_len)  //input_number range is INT16_MAX to INT16_MIN. Returns the numeric string length.
	const uint_fast8_t INTERMEDIATE_MAX_WIDTH = 1 + (floor(log10(-(float)INT16_MIN)) + 1);  //sign + Max significant figures
		return 0;
		return 0;
	if (array_len <= 1)
		return 0;
	int_fast8_t intermediate_len = sprintf(intermediate_string, "%-"PRIi16, input_number);
		return 0;
	int_fast8_t i = 0;
		while (i <= n)
			++i;
	int_fast8_t j = 0;
	while (i <= n)
		++i;
		++j;
	i -= 1;
uint_fast8_t integer_number_to_string_i32(int32_t input_number, char leader_character, uint_fast8_t display_width, char numeric_string[], uint_fast8_t array_len)  //input_number range is INT32_MAX to INT32_MIN. Returns the numeric string length.
	const uint_fast8_t INTERMEDIATE_MAX_WIDTH = 1 + (floor(log10(-(double)INT32_MIN)) + 1);  //sign + Max significant figures
		return 0;
		return 0;
	if (array_len <= 1)
		return 0;
	int_fast8_t intermediate_len = sprintf(intermediate_string, "%-"PRIi32, input_number);
		return 0;
	int_fast8_t i = 0;
		while (i <= n)
			++i;
	int_fast8_t j = 0;
	while (i <= n)
		++i;
		++j;
	i -= 1;
uint_fast8_t floating_number_to_string_f(float input_number, uint_fast8_t decimal_digits, char numeric_string[], uint_fast8_t array_len)  //input_number range is (pow(10, MAX_SIGNIFICANT_FIGURES) - 1) to pow(10, -MIN_DECIMAL). Returns the numeric string length. The random roundoff, pay attention to the random number seed.
	const uint_fast8_t MIN_DECIMAL = MAX_SIGNIFICANT_FIGURES + 1;
	char temp_string[1 + (decimal_digits == 0 ? MAX_SIGNIFICANT_FIGURES : max((MAX_SIGNIFICANT_FIGURES + 1), (1 + 1 + MIN_DECIMAL))) + 1];  //a sign + (decimal_digits == 0 ? MAX_SIGNIFICANT_FIGURES : max((MAX_SIGNIFICANT_FIGURES + a decimal), (a zero + a decimal + MIN_DECIMAL))) + '\x0'
	float absolute_value;
	float num_exp10;
	if (not isfinite(input_number))
		return 0;
	if (decimal_digits > MIN_DECIMAL)
		return 0;
	absolute_value = fabs(input_number);
	num_exp10 = floor(log10(absolute_value));
	if (num_exp10 >= MAX_SIGNIFICANT_FIGURES)
	{  //Value ultra range error
		return 0;
	float num_tail_exp10 = fmax((num_exp10 + 1 - MAX_SIGNIFICANT_FIGURES), (-((int_fast8_t)decimal_digits)));  //Plus integer part
	input_number = random_round_d(absolute_value, lround(num_tail_exp10));
	int_fast8_t num_int_exp10 = lround(num_exp10);
	if (num_int_exp10 >= MAX_SIGNIFICANT_FIGURES)
		return 0;
	int_fast8_t num_int_tail_exp10 = lround(num_tail_exp10);
	if (num_int_tail_exp10 > num_int_exp10)
		num_exp10 = num_tail_exp10;
		num_int_exp10 = num_int_tail_exp10;
	uint_fast8_t num_count = num_int_exp10 - num_int_tail_exp10 + 1;
	float intermediate_number = absolute_value * pow(10, -num_exp10);
	float digital_character[num_count];
	for (int_fast8_t i = 0; i < num_count; ++i)
		intermediate_number = modff(intermediate_number, &digital_character[i]) * 10;
	int_fast8_t i = 0;
	uint_fast8_t n;
	if ((input_number < 0 ? 1 : 0) == 1)
		temp_string[i] = '-'; ++i;
	int_fast8_t j = 0;
	if (num_int_exp10 >= 0)
		n = i + num_int_exp10;
		while(i <= n)
			temp_string[i] = (char)(lround(digital_character[j]) + 0x30);  //0x30 == '0'
			++i;
			++j;
		if ((num_int_tail_exp10 < 0 ? 1 : 0) == 1)
			temp_string[i] = '.'; ++i;
		n = i + abs(num_int_tail_exp10);
		while(i < n)
			++i;
			++j;
	else
		temp_string[i] = '0'; ++i;
		n = i + (-1 - num_int_exp10);
		while(i < n)
		n = i + (num_int_exp10 - num_int_tail_exp10);
		while(i <= n)
			++i;
			++j;
	temp_string[i] = '\x0';
	n = i;
	if ((n + 1) > array_len)
		return 0;
	for (i=0; i <= n; ++i)
		numeric_string[i] = temp_string[i];
	return n;  //Returns the numeric string length
uint_fast8_t floating_number_to_string_d(double input_number, uint_fast8_t decimal_digits, char numeric_string[], uint_fast8_t array_len)  //input_number range is (pow(10, MAX_SIGNIFICANT_FIGURES) - 1) to pow(10, -MIN_DECIMAL). Returns the numeric string length. The random roundoff, pay attention to the random number seed.
	double absolute_value;
	double num_exp10;
		return 0;
		return 0;
		return 0;
	double num_tail_exp10 = fmax((num_exp10 + 1 - MAX_SIGNIFICANT_FIGURES), (-((int_fast8_t)decimal_digits)));  //Plus integer part
		return 0;
	double intermediate_number = absolute_value * pow(10, -num_exp10);
	double digital_character[num_count];
		intermediate_number = modf(intermediate_number, &digital_character[i]) * 10;
	int_fast8_t i = 0;
	uint_fast8_t n;
	int_fast8_t j = 0;
		while(i <= n)
			++i;
			++j;
		while(i < n)
			++i;
			++j;
	else
		while(i < n)
		while(i <= n)
			++i;
			++j;
	n = i;
		return 0;
这样写出来的代码,以后换16位msp430也好换32位ARM也好,都不用修改调用代码
用防御式编程,可以更容易定位错误
