出现的问题是:在whie循环中多次执行send_data()之后,sdk Terminal窗口中报错:
#define ERR_MEM -1 /* Out of memory error. */
#define ERR_CONN -13 /* Not connected. */
程序在ch27上修改,在主函数的while循环中执行以下语句:
while (1)
/* call tcp timer every 250ms */
if(TcpTmrFlag)
if(request_pcb->state == CLOSED || (request_pcb->state == SYN_SENT && request_pcb->nrtx == TCP_SYNMAXRTX))
request_pcb = tcp_new();
if (!request_pcb) {
xil_printf("txperf: Error creating PCB. Out of Memory\r\n");
return -1;
//ip_set_option(request_pcb, SOF_REUSEADDR);
err = tcp_connect(request_pcb, &ipaddress, port, tcp_connected_callback);
if (err != ERR_OK) {
xil_printf("txperf: tcp_connect returned error: %d\r\n", err);
return err;
tcp_tmr();
TcpTmrFlag = 0;
/*receive input packet from emac*/
xemacif_input(netif);
/* if connected to the server, start receive data from PL through axidma, then transmit the data to the PC software by TCP*/
if(tcp_client_connected)
send_data();
sleep(1);
以下是send_data()函数:send_data()函数主要就是tcp_write()和tcp_output()函数。
void send_data()
#if __arm__
int copy = 3;
#else
int copy = 0;
#endif
err_t err;
struct tcp_pcb *tpcb = connected_pcb;
err = tcp_write(tpcb, yuan, 15, copy);
xil_printf("txperf: Error on tcp_write: %d\r\n", err);
connected_pcb = NULL;
return;
err = tcp_output(tpcb);
xil_printf("txperf: Error on tcp_output: %d\r\n",err);
return;
tcp长时间传输数据出错
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
