既然是评测,就实际开始用吧,适逢周末,点亮板子,
板子带四个LED灯,其中除角落的D1外,另外三个以某种规律在闪动,也不知道是哪个进程控制的,
关于板卡的重起和关机似乎有了问题,
首先测试的是reboot,结果没能重起卡住了
又搞不定网卡了,先进行其它测试吧,板卡直连电脑可以协商到10M网络,
设置电脑ip为192.168.18.18
设置板卡ip为192.168.18.100
ifconfig eth0 192.168.18.100
ping 192.168.18.18 -c 4
PING 192.168.18.18 (192.168.18.18) 56(84) bytes of data.
64 bytes from 192.168.18.18: icmp_seq=1 ttl=64 time=0.840 ms
64 bytes from 192.168.18.18: icmp_seq=2 ttl=64 time=0.894 ms
64 bytes from 192.168.18.18: icmp_seq=3 ttl=64 time=0.853 ms
64 bytes from 192.168.18.18: icmp_seq=4 ttl=64 time=0.861 ms
--- 192.168.18.18 ping statistics ---
4 packets transmitted, 4 received, 0% packet loss, time 3004ms
rtt min/avg/max/mdev = 0.840/0.862/0.894/0.019 ms
USB测试用的USB读卡器,应该识别成U盘吧,不太如意,稍后再研究吧,可以了
root@myimx6ek140:~# usb 1-1: new high-speed USB device number 2 using ci_hdrc
usb-storage 1-1:1.0: USB Mass Storage device detected
scsi host0: usb-storage 1-1:1.0
scsi 0:0:0:0: Direct-Access Mass Storage Device 1.00 PQ: 0 ANSI: 0 CCS
sd 0:0:0:0: Attached scsi generic sg0 type 0
sd 0:0:0:0: [sda] 15597568 512-byte logical blocks: (7.98 GB/7.43 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
EXT4-fs (sda1): recovery complete
EXT4-fs (sda1): mounted filesystem with writeback data mode. Opts: (null)
root@myimx6ek140:~# mount /dev/sda1 /mnt
root@myimx6ek140:~# ls /mnt
bin dev home lost+found mnt proc run selinux sys usr
boot etc lib media opt root sbin srv tmp var
root@myimx6ek140:~#
换上TF卡,不是自弹插槽,第一次用
root@myimx6ek140:~# dmesg | grep mmc0
[ 1.772471] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 1.876110] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.899113] mmc0: new high speed SDHC card at address 0001
[ 1.913972] mmcblk0: mmc0:0001 SD 29.5 GiB
然后可以挂载
mount /dev/mmcblk0p1 /mnt
