经过tornado 的build出现如下的一个错误提示:
vxrm *.o *.rpo ctdt.c symTbl.c vxWorks* *.out *.pl
vxrm ..\prjComps.h ..\prjParams.h ..\prjConfig.c ..\linkSyms.c
vxrm ..\libs.nm ..\libs.size
wtxtcl D:\Tornado2.2\host\src\hutils\configGen.tcl ..\ML300seg_aa.wpj
ccppc -g -mcpu=405 -mstrict-align -ansi -nostdinc -fvolatile -fno-builtin -fno-for-scope -
P -x assembler-with-cpp -I.. -ID:\Tornado2.2\target\config\ML300seg -ID:\Tornado2.2\target
\h -ID:\Tornado2.2\target\config\comps\src -ID:\Tornado2.2\target\src\drv -DCPU=PPC405 -DP
RJ_BUILD -ID:\Tornado2.2\target\config\ML300seg\ip_csp\xsrc -DXENV_VXWORKS -g -Wall -O2 -c
D:\Tornado2.2\target\config\ML300seg\sysALib.s -o sysALib.o
ccppc -g -mcpu=405 -mstrict-align -ansi -nostdinc -DRW_MULTI_THREAD -D_REENTRANT -fvolatil
e -fno-builtin -fno-for-scope -I.. -ID:\Tornado2.2\target\config\ML300seg -ID:\Tornado2.2\
target\h -ID:\Tornado2.2\target\config\comps\src -ID:\Tornado2.2\target\src\drv -DCPU=PPC4
05 -DPRJ_BUILD -ID:\Tornado2.2\target\config\ML300seg\ip_csp\xsrc -DXENV_VXWORKS -g -Wall
-O2 -c D:\Tornado2.2\target\config\ML300seg\ip_common_v1_00_a.c
In file included from D:\Tornado2.2\target\h\vxWorks.h:181,
from D:\Tornado2.2\target\config\ML300seg\ip_common_v1_00_a.c:40:
D:\Tornado2.2\target\h\types\vxTypesBase.h:42: stddef.h: No such file or directory
make: *** [ip_common_v1_00_a.o] Error 0x1
她提示说D:\Tornado2.2\target\h\types\vxTypesBase.h:42: stddef.h: No such file or directory,不存在。我看文件明明是有的啊,大家看看怎么回事。问题出在哪里了???
共8条
高手啊,我改了之后,有了新的进展。原来的错误解决了,但是出现新的错误
In file included from D:\Tornado2.2\target\config\ML300seg\sysLib.c:126:
D:\Tornado2.2\target\config\ML300seg\sysSystemAce.c: In function `sysSystemAceMount':
D:\Tornado2.2\target\config\ML300seg\sysSystemAce.c:308: warning: passing arg 1 of `cbioDe
vVerify' from incompatible pointer type
D:\Tornado2.2\target\config\ML300seg\sysSystemAce.c:308: too many arguments to function `c
bioDevVerify'
D:\Tornado2.2\target\config\ML300seg\sysSystemAce.c:308: warning: assignment makes pointer
from integer without a cast
大侠,再给我指点,指点
bioDevVerify'
大侠,再给我指点,指点
In file included from ..\prjConfig.c:124:
D:\Tornado2.2\target\config\comps\src\net\usrNetLib.c:96: redefinition of `ipMaxUnits'
D:\Tornado2.2\target\config\comps\src\net\usrNetEndBoot.c:26: `ipMaxUnits' previously defi
ned here
D:\Tornado2.2\target\config\comps\src\net\usrNetLib.c: In function `usrNetLibInit':
D:\Tornado2.2\target\config\comps\src\net\usrNetLib.c:104: warning: implicit declaration o
f function `ifIndexLibInit'
..\prjConfig.c: In function `usrRoot':
..\prjConfig.c:460: too few arguments to function `selectInit'
..\prjConfig.c: At top level:
D:\Tornado2.2\target\config\ML300seg\net\usrNetBoot.c:40: warning: `backplaneBoot' defined
but not used
出现新的错误,呵呵,兄弟们,我是不是很弱啊,严重打击我的信心 一个提示说,变量“ipMaxUnits”重定义了,一个提示说,变量ipMaxUnits提前定义。我没找到重复定义在哪里啊 是不是有其他的原因会造成这样的提示? [align=right][color=#000066][此贴子已经被作者于2004-9-3 09:31:16编辑过][/color][/align]
ned here
but not used
共8条
| PCF8574功能模块及其使用被打赏¥20元 | |
