![]() | The MST53XXB series is a high voltage ,ultralow-power, low dropout voltage regulator. (MST53XXB系列是一个高电压,超低功耗,低压差电压调节器。) Thedevice can deliver 100mA output current with adropout voltage of 300mV and allows an inputvoltage as high as 35V. (该系列芯片输出电流100mA,输出电压300mV,输入电压35V。) The typical quiescent current is only 1.6µA. (典型的静态电流只有1.6µa。) The device is available in fixed outputvoltages of 1.8, 2.5, 3.0, 3.3, 3.6, 4.0, 4.2 and 5.0V. (该系列芯片具有1.8、2.5、3.0、3.3、3.6、4.0、4.2、5.0V固定输出电压。) The device features integrated short-circuit andthermal shutdown protection. (该系列芯片具有集成短路和热关机保护功能。) Although designed primarily as fixed voltageregulators, the device can be used with externalcomponents to obtain variable voltages. (虽然设计主要是作为固定电压调节器,但该装置可以与外部元件一起使用,以获得可变电压。) 产品特点: Low Quiescent Current(低静态电流): 1.6μA High Input Voltage(高输入电压): Up to 35V High Output Current(高输出电流): ≥200mA Low Dropout Voltage(低压差):30mV@10mA300mV@100mA600mV@200mA Fixed Output Voltages(固定输出电压): 1.8, 2.5, 3.0, 3.3, 3.6,4.0, 4.2 and 5.0V High-accuracy Output Voltage(高精度输出电压) MST 53XXB ±2% Good Transient Response(良好的瞬态响应) Integrated Short-Circuit Protection(集成短路保护) Integrated Thermal Protection(过热保护) Available Packages(软件软启动) |
