大家好!我的单片机芯片是STC12C5A60S2,我用自带的P1口采集ADC电压,结果按照下面程序串口输出的值一直为0,请教下,哪里有问题呢? 我的code 如下: #define ADC_POWER 0x80 //ADC power control bit #define ADC_FLAG 0x10 //ADC complete flag #define ADC_START 0x08 //ADC start control bit #define ADC_SPEEDLL 0x00 //540 clocks #define ADC_SPEEDL 0x20 //360 clocks #define ADC_SPEEDH 0x40 //180 clocks #define ADC_SPEEDHH 0x60 //90 clocks #define FOSC 1843200L #define BAUD 9600 INT8U ch =0; void InitUart(); void InitADC(); void Send_Byte(INT8U c) { while(!TI); //TI发送中断标志位,手动清零 TI = 0; SBUF = c; } void Delay(INT8U n) { INT8U i; while(n--) { i = 5000; while(i--); } } void main() { InitUart(); InitADC(); IE = 0xa0; while(1); } void adc_isr() interrupt 5 using 1 { ADC_CONTR&= !ADC_FLAG; //Send_Byte(ch); Send_Byte(ADC_RES); //Send_Byte(ADC_RESL); if(++ch>7)ch = 0; ADC_CONTR = ADC_POWER | ADC_SPEEDLL | ADC_START |ch; } void InitADC() { P1ASF = 0xff; ADC_RES = 0; ADC_CONTR = ADC_POWER|ADC_SPEEDLL|ADC_START|ch; Delay(2); } void InitUart() { SCON = 0x5a; TMOD = 0x20; TH1 = TL1 =-(FOSC/12/32/BAUD); TR1 = 1; } |
共4条
请教关于STC单片机STC12C5A60S2的ADC采集不到电源的问题
关键词: STC12C5A60S2 电压采集 ADC A/D
共4条
