电子产品世界 » 论坛首页 » 嵌入式开发 » STM32 » STM32L151外接晶振的问题
共5条 1/1 1 跳转至页
STM32L151外接晶振的问题
2021-01-02 22:50:11     打赏
公司有个以前做的项目,拿到前人留下的程序,想学习学习。刚上来就被时钟搞混了。
这块板子用的是STM32L151,外接3.6864MHz晶振,OSC32IN和OSC32out没接晶振。这块板子需要精确延时的。
按我理解,时钟应该是3.6864*8/2=14.7456M,但是我看代码里还是基于8M来设置的。
RCC_GetClocksFreq(&RCC_Clocks);      //获取系统时钟频率,外部晶振8.00M,倍频后系统时钟8.000*8/2=32.00M
注释是说外部晶振8M,可实际上没有接8M,只接的是3.6864MHz晶振。
对应的RCC_GetClocksFreq如下:
void RCC_GetClocksFreq(RCC_ClocksTypeDef* RCC_Clocks)
  uint32_t tmp = 0, pllmul = 0, plldiv = 0, pllsource = 0, presc = 0, msirange = 0;
  /* Get SYSCLK source -------------------------------------------------------*/
  tmp = RCC->CFGR & RCC_CFGR_SWS;
  switch (tmp)
    case 0x00:  /* MSI used as system clock */
      msirange = (RCC->ICSCR & RCC_ICSCR_MSIRANGE ) >> 13;
      RCC_Clocks->SYSCLK_Frequency = (((1 << msirange) * 64000) - (MSITable[msirange] * 24000));
      break;
    case 0x04:  /* HSI used as system clock */
      RCC_Clocks->SYSCLK_Frequency = HSI_VALUE;
      break;
    case 0x08:  /* HSE used as system clock */
      RCC_Clocks->SYSCLK_Frequency = HSE_VALUE;
      break;
    case 0x0C:  /* PLL used as system clock */
      /* Get PLL clock source and multiplication factor ----------------------*/
      pllmul = RCC->CFGR & RCC_CFGR_PLLMUL;
      plldiv = RCC->CFGR & RCC_CFGR_PLLDIV;
      pllmul = PLLMulTable[(pllmul >> 18)];
      plldiv = (plldiv >> 22) + 1;
      pllsource = RCC->CFGR & RCC_CFGR_PLLSRC;
      if (pllsource == 0x00)
        /* HSI oscillator clock selected as PLL clock entry */
        RCC_Clocks->SYSCLK_Frequency = (((HSI_VALUE) * pllmul) / plldiv);
      else
        /* HSE selected as PLL clock entry */
        RCC_Clocks->SYSCLK_Frequency = (((HSE_VALUE) * pllmul) / plldiv);
      break;
    default:
      break;
在system_stm32lxx.c里,看到倍频分频设置值跟外接8M一样,几乎没改动。
    /*  PLL configuration: PLLCLK = (HSE * 8) / 2 = 32MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLMUL |
                                        RCC_CFGR_PLLDIV));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSE | RCC_CFGR_PLLMUL8 | RCC_CFGR_PLLDIV2);
我揣测是利用的内部的HSI 8M来计算的,我在相关代码里没找到使用HSI的语句,郁闷啊。也没有发现用此晶振3.6864MHz晶振代替系统默认的8M。 哪位恳请帮理一下。新手琢磨了几天了,对RCC还是有点糊涂。
关键词: STM32L151     晶振     STM32L
2021-01-02 23:10:20     打赏
用标准库开发,使用外部时钟,将库函数stm32lxx.h里的8M改为3.6864M
2021-01-02 23:18:24     打赏
stcube 应该是最好的设计辅助软件。
2021-01-02 23:23:09     打赏
用示波器测量看看,辅助软件进行调整!
2021-01-12 22:58:06     打赏
问题还是蛮大的
共5条 1/1 1 跳转至页
