EPSON爱普生晶振公司是全球知名的最大晶体,32.768K晶振,时钟模块,且是全球最大的晶振率覆盖范围生厂商,实现从KHz至MHz全覆盖,全球共有11家工厂,晶体和IC都能自主研发生产,可以保证供货安全性,供货稳定,一致性好,性能更稳定,5年以上都不会产生频偏,停振等,EPSON无源晶振,封装全,频率覆盖广,性能稳定,独有的QMEMS工艺保证了产品的高品质和高性价比,加科电子作为专业进口晶振现货分销商,可供应EPSON旗下无源晶振,有源晶振,26MHz温补晶振,今天加科电子整理一份爱普生晶振全系列现货型号表格,方便用户查询获取。
| 型号 | 料号 | 频率(HZ) | 频差(PPM) | 尺寸(MM) |
| TSX-3225 | X1E000021052700 | 24MHZ | ±10PPM | 3.20×2.50mm |
| TSX-3225 | X1E000021069600 | 16.000000MHZ | ±10PPM | 3.20×2.50mm |
| TG-5006CJ | X1G004131003700 | 19.2MHZ | ±2PPM | 2.00×1.60mm |
| TG-5006CJ | X1G004131004200 | 32MHZ | ±2PPM | 2.00×1.60mm |
| TG-5006CJ | X1G004131001100 | 38.4MHZ | ±2PPM | 2.00×1.60mm |
| TG-5006CJ | X1G004131001000 | 26MHZ | ±2PPM | 2.00×1.60mm |
| TG-5006CJ | X1G004131000900 | 19.2MHz | ±2PPM | 2.00×1.60mm |
| TG-5006CG | X1G004211000400 | 16.368MHZ | ±2PPM | 2.50×2.00mm |
| TG-5006CE | X1G004201001700 | 26MHZ | ±2PPM | 3.20×2.50mm |
| TG-5006CE | X1G004201001000 | 26MHZ | ±2PPM | 3.20×2.50mm |
| SG7050VAN | X1G004281002400 | 200MHZ | ±30PPM | 7.00×5.00mm |
| SG7050VAN | X1G004281003300 | 156.25MHZ | ±30PPM | 7.00×5.00mm |
| SG7050VAN | X1G004281002300 | 100MHZ | ±30PPM | 7.00×5.00mm |
| SG5032CCN | X1G004471002900 | 4.915200MHZ | ±50PPM | 5.00×3.20mm |
| SG-310SEF | Q33310FE0026100 | 50MHZ | ±50PPM | 3.20×2.50mm |
| SG-310SCN | Q33310N70006800 | 50MHZ | ±25PPM | 3.20×2.50mm |
| SG-310SCN | Q33310N70016500 | 24MHZ | ±25PPM | 3.20×2.50mm |
| SG-3030LC | Q3102LC02000500 | 32.768KHZ | +5PPM~±23PPM | 3.60×2.80mm |
| SG-3030JF | Q3102JF02000100 | 32.768KHZ | +5PPM~±23PPM | 7.00×5.00mm |
| RX-8025NB | Q41802591000100 | 32.768KHZ | ±10PPM | 6.00×4.80mm |
| MC-146 | Q13MC1461001700 | 32.768KHZ | ±10PPM | 7.00×1.50mm |
| FC-135 | Q13FC1350000600 | 32.768KHZ | ±10PPM | 3.20×1.50mm |
| FC-135 | Q13FC1350000100 | 32.768KHZ | ±10PPM | 3.20×1.50mm |
| FC-135 | Q13FC1350002400 | 32.768KHZ | ±5PPM | 3.20×1.50mm |
| FC-135 | Q13FC1350000500 | 32.768KHZ | ±10PPM | 3.20×1.50mm |
| FC-12M | X1A000061002100 | 32.768KHZ | ±20PPM | 2.00×1.20mm |
| FC-12M | X1A000061001400 | 32.768KHZ | ±10PPM | 2.00×1.20mm |
| FA-238 | Q22FA2380110100 | 27MHz | ±30PPM | 3.20×2.50mm |
| FA-238 | Q22FA2380084400 | 25MHz | ±15PPM | 3.20×2.50mm |
| FA-238 | Q22FA2380181200 | 25MHz | ±30PPM | 3.20×2.50mm |
| FA-238 | Q22FA2380169900 | 25MHz | ±20PPM | 3.20×2.50mm |
| FA-238 | Q22FA2380033800 | 24MHz | ±15PPM | 3.20×2.50mm |
| FA-238 | Q22FA2380169700 | 24MHz | ±20PPM | 3.20×2.50mm |
| FA-238 | Q22FA2380120100 | 24MHz | ±20PPM | 3.20×2.50mm |
| FA-238 | Q22FA2380003500 | 20MHZ | ±30PPM | 3.20×2.50mm |
| FA-238 | Q22FA2380026300 | 16MHz | ±15PPM | 3.20×2.50mm |
| FA-238 | Q22FA2380191100 | 16MHz | ±50PPM | 3.20×2.50mm |
| FA-20H | Q24FA20H0019600 | 32MHZ | ±10PPM | 2.50×2.00mm |
| FA-20H | Q24FA20H0005900 | 16MHZ | ±10PPM | 2.50×2.00mm |
| FA-128 | Q22FA1280001300 | 24MHZ | ±30PPM | 2.00×1.60mm |
| FA-118T | X1E000251006500 | 32MHZ | ±10PPM | 1.60×1.20mm |
| FA-118T | X1E000251004600 | 24MHZ | ±10PPM | 1.60×1.20mm |
| RX-8025T | X1B000281000500 | 32.768KHZ | ±5PPM | 10.1×7.40mm |
| SG-210STF | X1G004171004900 | 54MHZ | ±50PPM | 2.50×2.00mm |
| FA-118T | X1E000251006400 | 26MHZ | ±10PPM | 1.60×1.20mm |
| FA-118T | X1E000251001400 | 26MHZ | ±10PPM | 1.60×1.20mm |
| FA-118T | X1E000251005900 | 32MHZ | ±10PPM | 1.60×1.20mm |
| FA-20H | Q24FA20H0038400 | 30MHZ | ±10PPM | 2.50×2.00mm |
| FA-20H | Q24FA20H0014700 | 27MHZ | ±10PPM | 2.50×2.00mm |
| MC-146 | Q13MC1462000400 | 32.768KHZ | ±20PPM | 7.00×1.50mm |
| SG7050CCN | X1G004501002011 | 6MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CCN | X1G004501001511 | 8MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CCN | X1G004501004011 | 7.3728MHZ | ±50PPM | 7.0X5.0mm |
| RX-8025T | X1B000281000400 | 32.768KHZ | ±5PPM | 6.3X4.8mm |
| SG-210STF | X1G004171001900 | 12.288MHZ | ±50PPM | 2.5X2.0mm |
| SG-8018CA | SG-8018CA 27MHZ TJHPA | 27MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 18.432MHZ TJHPA | 18.432MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 14.318MHZ TJHPA | 14.318MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 2.457MHZ TJHPA | 2.457MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 20MHZ TJHPA | 20MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 100MHZ TJHPA | 100MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 66.666MHZ TJHPA | 66.666MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 40MHZ TJHPA | 40MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 16MHZ TJHPA | 16MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 32MHZ TJHPA | 32MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 8MHZ TJHPA | 8MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 25MHZ TJHPA | 25MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 24MHZ TJHPA | 24MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CA | SG-8018CA 12MHZ TJHPA | 12MHZ | ±50PPM | 7.0X5.0mm |
| SG-8018CE | SG-8018CE 16.625MHZ TJHPA | 16.625MHZ | ±50PPM | 3.2x2.5mm |
| SG-8018CE | SG-8018CE 35MHZ TJHPA | 35MHZ | ±50PPM | 3.2x2.5mm |
| SG-8018CE | SG-8018CE 64MHZ TJHPA | 64MHZ | ±50PPM | 3.2x2.5mm |
| SG-8018CE | SG-8018CE 25MHZ TJHPA | 25MHZ | ±50PPM | 3.2x2.5mm |
| SG-8018CE | SG-8018CE 19.922944MHZ TJHPA | 19.922944MHZ | ±50PPM | 3.2x2.5mm |
| RX8130CE | X1B000311000100 | 32.768KHZ | +5PPM~±23PPM | 3.2x2.5mm |
| RX8900CE | X1B000301000200 | 32.768KHZ | ±5PPM | 3.2x2.5mm |
| RX-8025SA | Q41802551000200 | 32.768KHZ | ±5PPM | 10.1x7.4mm |
| FA-238V | Q22FA23V0028500 | 12MHZ | ±10PPM | 3.2X2.5mm |
| FA-238V | Q22FA23V0050100 | 12MHZ | ±15PPM | 3.2X2.5mm |
| RX-8035LC | X1B000182000312 | 32.768KHZ | ±5PPM | 3.6x2.8mm |
| RX-8035SA | X1B000172000312 | 32.768KHZ | ±5PPM | 10.1x7.4mm |
| RX8900CE | X1B000301000212 | 32.768KHZ | ±5PPM | 3.2x2.5mm |
| SG-210STF | X1G004171001500 | 8MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171000900 | 4MHZ | ±50PPM | 2.5X2.0mm |
| TG-5006CJ | X1G004131001112 | 38.4MHZ | ±2PPM | 2.0X1.6mm |
| TG-5006CJ | X1G004131003712 | 19.2MHz | ±2PPM | 2.0X1.6mm |
| FC-135R | X1A000141000600 | 32.768KHZ | ±20PPM | 3.2X1.5mm |
| SG-210STF | X1G004171005212 | 8.192MHZ | ±50PPM | 2.5X2.0mm |
| SG5032CAN | X1G004451006300 | 7.3728MHZ | ±20PPM | 5.0x3.2mm |
| FA-238A | X1E000341039311 | 24MHZ | ±15PPM | 3.2X2.5mm |
| SG5032EAN | X1G004271002411 | 200MHZ | ±30PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451001212 | 40MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451001312 | 10MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451006512 | 8.192MHZ | ±50PPM | 5.0X3.2mm |
| TG-5006CG | X1G004211002300 | 19.2MHz | ±2PPM | 2.5X2.0mm |
| TG-5006CG | X1G004211000099 | 50MHZ | ±2PPM | 2.5X2.0mm |
| TG-5006CG | X1G004211001112 | 38.4MHZ | ±2PPM | 2.5X2.0mm |
| TG-5006CG | X1G004211000812 | 16.369MHZ | ±2PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0063012 | 13.56MHZ | ±20PPM | 2.5X2.0mm |
| SG5032CCN | X1G004471000400 | 20MHZ | ±50PPM | 5.0X3.2mm |
| SG3225VAN | X1G004241007911 | 50MHZ | ±50PPM | 3.2X2.5mm |
| SG3225VAN | X1G004241001011 | 148.5MHZ | ±50PPM | 3.2X2.5mm |
| SG3225VAN | X1G004241000111 | 125MHZ | ±50PPM | 3.2X2.5mm |
| SG3225VAN | X1G004241001411 | 156.25MHZ | ±50PPM | 3.2X2.5mm |
| SG3225VAN | X1G004241000411 | 100MHZ | ±50PPM | 3.2X2.5mm |
| SG3225VAN | X1G004241000511 | 200MHZ | ±50PPM | 3.2X2.5mm |
| MC-306 | Q13MC3062000300 | 32.768KHZ | ±20PPM | 8.0X3.8mm |
| FC-12M | X1A000061000200 | 32.768KHZ | ±20PPM | 2.0X1.2mm |
| SG7050VAN | X1G004281003312 | 156.25MHZ | ±30PPM | 7.0x5.0mm |
| SG7050VAN | X1G004281002812 | 74.25MHZ | ±30PPM | 7.0x5.0mm |
| SG7050VAN | X1G004281002012 | 125MHZ | ±30PPM | 7.0x5.0mm |
| SG7050VAN | X1G004281001011 | 148.5MHZ | ±50PPM | 7.0x5.0mm |
| SG7050VAN | X1G004281000411 | 100MHZ | ±50PPM | 7.0x5.0mm |
| SG7050VAN | X1G004281000511 | 200MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501000600 | 20MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501000912 | 33MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501001512 | 8MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501000812 | 25MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501000412 | 48MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501000612 | 20MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CCN | X1G004501001012 | 40MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CCN | X1G004501000512 | 11.0592MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CCN | X1G004501003212 | 12.288MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501005212 | 22.1184MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501004912 | 16.384MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CCN | X1G004501001812 | 3.579545MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501003912 | 4.096MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CCN | X1G004501003512 | 24.576MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501002112 | 12MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501003612 | 27MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501001712 | 24MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CCN | X1G004501002612 | 14.7456MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501002412 | 32MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501002512 | 30MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501003112 | 10MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501003312 | 18.432MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501000312 | 16MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CCN | X1G004501000300 | 16MHZ | ±50PPM | 7.0x5.0mm |
| SG7050EAN | X1G004291003312 | 156.25MHZ | ±30PPM | 7.0x5.0mm |
| SG7050EAN | X1G004291003112 | 150MHZ | ±30PPM | 7.0x5.0mm |
| SG7050EAN | X1G004291002912 | 148.5MHZ | ±30PPM | 7.0x5.0mm |
| SG7050EAN | X1G004291002812 | 74.25MHZ | ±30PPM | 7.0x5.0mm |
| SG7050EAN | X1G004291003212 | 155.52MHZ | ±30PPM | 7.0x5.0mm |
| SG7050EAN | X1G004291002412 | 200MHZ | ±30PPM | 7.0x5.0mm |
| SG7050EAN | X1G004291002312 | 100MHZ | ±30PPM | 7.0x5.0mm |
| SG7050EAN | X1G004291002112 | 125.00625MHZ | ±30PPM | 7.0x5.0mm |
| FC1610AN | X1A000121000500 | 32.768KHZ | ±20PPM | 1.6X1.0mm |
| FC-135R | X1A000141000200 | 32.768KHZ | ±20PPM | 3.2x1.5mm |
| FC-135 | Q13FC1350004900 | 32.768kHz | ±20PPM | 3.2x1.5mm |
| FA-128 | Q22FA1280022712 | 37.4MHZ | ±10PPM | 2.0X1.6mm |
| FA-128 | Q22FA1280006412 | 37.4MHZ | ±10PPM | 2.0X1.6mm |
| FA-128 | Q22FA1280050612 | 38.4MHZ | ±10PPM | 2.0X1.6mm |
| FA-128 | Q22FA1280010012 | 38.4MHZ | ±10PPM | 2.0X1.6mm |
| FA-128 | Q22FA1280000712 | 38.4MHZ | ±15PPM | 2.0X1.6mm |
| SG-310SCF | Q33310F70054812 | 7.3728MHZ | ±25PPM | 3.2X2.5mm |
| SG-310SCN | Q33310N70002411 | 50MHZ | ±100PPM | 3.2X2.5mm |
| SG-310SCN | Q33310N70004111 | 48MHZ | ±25PPM | 3.2X2.5mm |
| SG-310SCN | Q33310N70002711 | 25MHZ | ±25PPM | 3.2X2.5mm |
| SG-310SEF | Q33310FE0025811 | 27MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SEF | Q33310FE0025611 | 37.125MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SEF | Q33310FE0025211 | 24MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SEF | Q33310FE0024411 | 25MHZ | ±50PPM | 3.2X2.5mm |
| SG7050CAN | X1G004481008112 | 6MHZ | ±50PPM | 7.0x5.0mm |
| SG7050CAN | X1G004481007412 | 4.096MHZ | ±50PPM | 7.0x5.0mm |
| FA-20H | Q24FA20H0023212 | 16MHZ | ±10PPM | 2.5X2.0mm |
| FA-128 | Q22FA1280023400 | 16MHZ | ±10PPM | 2.0X1.6mm |
| TSX-3225 | X1E000021050200 | 27.12MHZ | ±10PPM | 3.2X2.5mm |
| FA-238A | X1E000341031500 | 12MHZ | ±30PPM | 3.2X2.5mm |
| FA-238V | Q22FA23V0041800 | 12MHZ | ±20PPM | 3.2X2.5mm |
| SG7050VAN | X1G004281002112 | 125.00625MHZ | ±50PPM | 7.0x5.0mm |
| SG7050VAN | X1G004281003212 | 155.52MHZ | ±30PPM | 7.0x5.0mm |
| SG-310SEF | Q33310FE0016600 | 12MHZ | ±20PPM | 3.2X2.5mm |
| SG-310SCN | Q33310N70032400 | 54MHZ | ±50PPM | 3.2X2.5mm |
| SG7050EAN | X1G004291002000 | 125MHZ | ±30PPM | 7.0x5.0mm |
| SG5032VAN | X1G004261000600 | 156.25MHZ | ±50PPM | 5.0x3.2mm |
| SG5032CBN | X1G004461000700 | 156.25MHZ | ±50PPM | 5.0x3.2mm |
| SG5032CAN | X1G004451003300 | 6MHZ | ±50PPM | 5.0x3.2mm |
| SG7050CBN | X1G004491001600 | 96MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481004500 | 65.536MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481001700 | 33MHZ | ±50PPM | 7.0x5.0mm |
| SG-210STF | X1G004171004600 | 48MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171008500 | 1.5MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171003200 | 24.576MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171002700 | 16MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171004700 | 50MHZ | ±50PPM | 2.5X2.0mm |
| SG-310SCF | Q33310F70062200 | 50MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70062000 | 12.288MHZ | ±50PPM | 3.2X2.5mm |
| FA-20H | Q24FA20H0033800 | 30MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0011400 | 25MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0021700 | 32MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0012200 | 16MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0009700 | 40MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0020900 | 40MHZ | ±10PPM | 2.5X2.0mm |
| FA-128 | Q22FA1280050700 | 16MHZ | ±10PPM | 2.0X1.6mm |
| TSX-3225 | X1E000021013300 | 25MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021001900 | 16MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021064800 | 25MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021081900 | 26MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021013900 | 25MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021006500 | 19.2MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021059600 | 30MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021011900 | 16MHZ | ±10PPM | 3.2X2.5mm |
| MC-306 | Q13MC3061000400 | 32.768KHZ | ±20PPM | 8.0X3.8mm |
| MC-306 | Q13MC3061000300 | 32.768KHZ | ±20PPM | 8.0X3.8mm |
| SG-8002DC | SG-8002DC | 1MHz~125MHz | ±50ppm,±100ppm | 13.7X6.6 |
| SG-8002JA | SG-8002JA | 1MHz~125MHz | ±50ppm,±100ppm | 14.0X9.8 |
| SG-8002CA | SG-8002CA | 1MHz~125MHz | ±50ppm,±100ppm | 7.5X5.0 |
| SG-8101CB | SG-8101CB | 0.67MHz~170MHz | ±25ppm, ±50ppm,±100ppm | 5.0X3.2 |
| EG-2102CB | EG-2102CB | 100MHz~700MHz | ±50ppm, ±100ppm | 5.0X3.2 |
| EG-2121CB | EG-2121CB | 100MHz~700MHz | ±50ppm, ±100ppm | 5.0X3.2 |
| EG-2103CB | EG-2103CB | 100MHz~700MHz | ±100ppm | 5.0X3.2 |
| EG-2123CB | EG-2123CB | 100MHz~700MHz | ±100ppm | 5.0X3.2 |
| SG-770 | SG-770 | 50MHz~230MHz | ±50ppm | 7.5X5.0 |
| SG3225EEN | SG3225EEN | 25MHz~200MHz | ±25ppm | 3.2X2.5 |
| XG-2102CA | XG-2102CA | 100MHz~700MHz | ±50ppm, ±100ppm | 7.5X5.0 |
| XG-2121CA | XG-2121CA | 100MHz~700MHz | ±50ppm, ±100ppm | 7.5X5.0 |
| XG-2103CA | XG-2103CA | 100MHz~700MHz | ±50ppm, ±100ppm | 7.5X5.0 |
| XG-2123CA | XG-2123CA | 100MHz~700MHz | ±50ppm, ±100ppm | 7.5X5.0 |
| SG-310 | SG-310 | 2MHz~80MHz | ±50ppm, ±100ppm | 3.2X2.5 |
| SG-550 | SG-550 | 2MHz~48MHz | ±50ppm, ±100ppm | 5.0X3.2 |
| SG-645 | SG-645 | 2.21675MHz~135MHz | ±100ppm | 7.1X5.1 |
| SG-636 | SG-636 | 2.21675MHz~135MHz | ±100ppm | 10.5X5.8 |
| TCO-708x | TCO-708x | 1.5MHz~160MHz | ±25ppm, ±50ppm,±100ppm | 7.5X5.0 |
| TCO-710x | TCO-710x | 1.5MHz~75MHz | ±50ppm,±100ppm | 5.0X3.2 |
| SG-8002CE | SG-8002CE | 1MHz~125MHz | ±50ppm,±100ppm | 3.2X2.5 |
| SG-8002JC | SG-8002JC | 1MHz~125MHz | ±50ppm,±100ppm | 10.5X5.8 |
| SG-8002LB | SG-8002LB | 1MHz~125MHz | ±50ppm,±100ppm | 5.0X3.2 |
| SG-8003CA | SG-8003CA | 1MHz~166MHz | ±50ppm,±100ppm | 7.5X5.0 |
| SG-8003CE | SG-8003CE | 1MHz~166MHz | ±50ppm,±100ppm | 3.2X2.5 |
| SG-8101CA | SG-8101CA | 0.67MHz~170MHz | ±25ppm, ±50ppm,±100ppm | 7.5X5.0 |
| SG-8101CE | SG-8101CE | 0.67MHz~170MHz | ±25ppm, ±50ppm,±100ppm | 3.2X2.5 |
| EG-2001CA | EG-2001CA | 62.5MHz~250MHz | ±50ppm,±100ppm | 7.5X5.0 |
| EG-2021CA | EG-2021CA | 62.5MHz~250MHz | ±50ppm,±100ppm | 7.5X5.0 |
| EG-2102CA | EG-2102CA | 53.125MHz~700MHz | ±50ppm,±100ppm | 7.5X5.0 |
| EG-2121CA | EG-2121CA | 53.125MHz~700MHz | ±50ppm,±100ppm | 7.5X5.0 |
| EG-2102CB | EG-2102CB | 100MHz~700MHz | ±50ppm,±100ppm | 5.0X3.2 |
| EG-2103CB | EG-2103CB | 100MHz~700MHz | ±50ppm,±100ppm | 5.0X3.2 |
| EG-4101CA | EG-4101CA | 100MHz~700MHz | ±50ppm,±100ppm | 5.0X3.2 |
| EV1409SAN | EV1409SAN | 1000MHz~3000MHz | ±50ppm | 14.0X9.0 |
| EV1409EAN | EV1409EAN | 1000MHz~3000MHz | ±50ppm | 14.0X9.0 |
| SG-771 | SG-771 | 80MHz~175MHz | ±50ppm | 7.0X5.0 |
| SG-8003CG | SG-8003CG | 1MHz~166MHz | ±50ppm | 2.5X2.0 |
| SG-8003LB | SG-8003LB | 1MHz~166MHz | ±50ppm | 5.0X3.2 |
| 2102 | 2102CA | 100MHz ~700MHz | ±50ppm,±100ppm | 7.0X5.0 |
| XG-2121 | XG-2121 | 100MHz ~700MHz | ±50ppm,±100ppm | 7.0X5.0 |
| 2103CA | 2103CA | 100MHz ~700MHz | ±50ppm,±100ppm | 7.0X5.0 |
| XG-2123 | XG-2123 | 100MHz ~700MHz | ±50ppm,±100ppm | 7.0X5.0 |
| FA-128 | Q22FA1280001800 | 32MHZ | ±10PPM | 2.0x1.6mm |
| SG5032VAN | X1G004261003112 | 150MHZ | ±50PPM | 5.0x3.2mm |
| SG5032VAN | X1G004261002912 | 148.5MHZ | ±50PPM | 5.0x3.2mm |
| SG5032VAN | X1G004261002812 | 74.25MHZ | ±50PPM | 5.0X3.2mm |
| SG5032VAN | X1G004261002412 | 200MHZ | ±30PPM | 5.0X3.2mm |
| SG5032VAN | X1G004261002312 | 100MHZ | ±50PPM | 5.0X3.2mm |
| SG5032VAN | X1G004261002012 | 125MHZ | ±30PPM | 5.0X3.2mm |
| FA-118T | X1E000251008012 | 32MHZ | ±10PPM | 1.6x1.2mm |
| FA-118T | X1E000251007712 | 25MHZ | ±10PPM | 1.6x1.2mm |
| FA-118T | X1E000251006912 | 24MHZ | ±30PPM | 1.6x1.2mm |
| FA-118T | X1E000251006812 | 24MHZ | ±30PPM | 1.6x1.2mm |
| FA-118T | X1E000251006512 | 32MHZ | ±10PPM | 1.6x1.2mm |
| FA-118T | X1E000251006412 | 26MHZ | ±10PPM | 1.6x1.2mm |
| FA-118T | X1E000251006012 | 48MHZ | ±30PPM | 1.6x1.2mm |
| FA-118T | X1E000251005912 | 32MHZ | ±10PPM | 1.6x1.2mm |
| FA-118T | X1E000251005712 | 25MHZ | ±30PPM | 1.6x1.2mm |
| FA-118T | X1E000251005012 | 32MHZ | ±10PPM | 1.6x1.2mm |
| FA-118T | X1E000251003312 | 25MHZ | ±30PPM | 1.6x1.2mm |
| FA-118T | X1E000251003212 | 40MHZ | ±10PPM | 1.6x1.2mm |
| FA-118T | X1E000251001412 | 26MHZ | ±10PPM | 1.6x1.2mm |
| FA-118T | X1E000251001112 | 26MHZ | ±10PPM | 1.6x1.2mm |
| FA-118T | X1E000251000912 | 27.12MHZ | ±30PPM | 1.6x1.2mm |
| TSX-3225 | X1E000021080812 | 40MHZ | ±15PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021079412 | 22.5792MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021079212 | 33.333MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021077112 | 16.384MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021076212 | 48MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021074612 | 24.576MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021071412 | 22.1184MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021069612 | 16MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021066012 | 38.4MHZ | ±20PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021062412 | 20MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021062212 | 28.6363MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021062112 | 25MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021058112 | 20MHZ | ±15PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021048112 | 30MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021046912 | 18.432MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021043712 | 18.432MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021042712 | 24.576MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021042612 | 27MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021042512 | 32MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021039412 | 37.8MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021030312 | 28.6363MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021017912 | 40MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021017712 | 40MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021014612 | 26MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021014012 | 25MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021013312 | 25MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021013012 | 24MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021012812 | 24MHZ | ±10PPM | 3.2x2.5mm |
| TSX-3225 | X1E000021012612 | 24MHZ | ±10PPM | 3.2x2.5mm |
| SG-3030CM | X1B000211000112 | 32.768KHZ | +5PPM~±23PPM | 3.2x1.5mm |
| SG-3030LC | Q3102LC02000512 | 32.768KHZ | +5PPM~±23PPM | 3.6X2.8mm |
| SG-3030LC | Q3102JC01000112 | 32.768KHZ | +5PPM~±23PPM | 10.5X5.0mm |
| FA-20H | Q24FA20H0074812 | 27.12MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0073212 | 24MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0072912 | 32MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0053012 | 16MHZ | ±50PPM | 2.5x2.0mm |
| FA-20H | Q24FA20H0051212 | 16MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0043112 | 27.12MHZ | ±20PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0042812 | 27.12MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0039412 | 24MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0039012 | 25MHZ | ±20PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0038412 | 30MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0038012 | 32MHZ | ±10PPM | 2.5x2.0mm |
| FA-20H | Q24FA20H0035812 | 20MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0035712 | 24MHZ | ±30PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0034512 | 27MHZ | ±10PPM | 2.5x2.0mm |
| FA-20H | Q24FA20H0033912 | 24MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0033812 | 30MHZ | ±10PPM | 2.5x2.0mm |
| FA-20H | Q24FA20H0028912 | 26MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0024712 | 16MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0023812 | 27MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0017212 | 25MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0013912 | 30MHZ | ±30PPM | 2.5x2.0mm |
| FA-20H | Q24FA20H0012812 | 20MHZ | ±10PPM | 2.5x2.0mm |
| FA-20H | Q24FA20H0011512 | 25MHZ | ±30PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0011412 | 25MHZ | ±10PPM | 2.5x2.0mm |
| FA-20H | Q24FA20H0009212 | 24MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0002912 | 40MHZ | ±10PPM | 2.5X2.0mm |
| FA-128 | Q22FA1280040012 | 16MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280039312 | 32MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280038812 | 25MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280038712 | 24MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280036912 | 30MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280035712 | 24.576MHZ | ±50PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280035212 | 26MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280034512 | 50MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280033512 | 20MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280033212 | 40MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280031512 | 27.12MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280024412 | 24MHZ | ±15PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280023012 | 26MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280022612 | 26MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280018312 | 25MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280015012 | 48MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280014912 | 27MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280013512 | 27MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280012112 | 27MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280010112 | 40MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280009012 | 25MHZ | ±10PPM | 2.0x1.6mm |
| SG5032VAN | X1G004261003312 | 156.25MHZ | ±50PPM | 5.0X3.2mm |
| RX6110SAB | RX6110SAB | 32.768kHz | ±5ppm | 10.1X7.4 |
| RX6110SAA | RX6110SAA | 32.768kHz | ±5ppm | 10.1X7.4 |
| RX-4803SA | RX-4803SA | 32.768kHz | ±5ppm | 10.1X7.4 |
| RX-4803LC | RX-4803LC | 32.768kHz | ±5ppm | 10.1X7.4 |
| RX-4581NB | RX-4581NB | 32.768kHz | 5±23ppm | 6.3X5.0 |
| RX-4571LC | RX-4571LC | 32.768kHz | ±5ppm | 3.6X2.8 |
| RX-4045SA | RX-4045SA | 32.768kHz | ±5ppm | 10.1X7.4 |
| RX-4045NB | RX-4045NB | 32.768kHz | ±5ppm | 6.3X5.0 |
| RX-4035SA | RX-4035SA | 32.768kHz | 5±23ppm | 10.1X7.4 |
| RX-4035LC | RX-4035LC | 32.768kHz | 5±23ppm | 3.6X2.8 |
| RTC-72423 | RTC-72423 | 32.768kHz | ±20ppm ±50ppm | 16.3X12.2 |
| RTC-72421 | RTC-72421 | 32.768kHz | ±10ppm ±50ppm | 23.1X7.62 |
| RTC-7301SF | RTC-7301SF | 32.768kHz | 5±23ppm | 10.2X7.8 |
| RTC-7301DG | RTC-7301DG | 32.768kHz | 5±23ppm | 23.1X7.62 |
| RTC-4574SA | RTC-4574SA | 32.768kHz | 5±23ppm | 10.1X7.4 |
| RTC-4574JE | RTC-4574JE | 32.768kHz | 5±23ppm | 10.1X7.4 |
| RTC-4543SA | RTC-4543SA | 32.768kHz | 5±23ppm | 10.1X7.4 |
| RA4803SA | RA4803SA | 32.768kHz | 5±23ppm | 10.1X7.4 |
| RA-4574SA | RA-4574SA | 32.768kHz | 5±23ppm | 10.1X7.4 |
| RA-4565SA | RA-4565SA | 32.768kHz | 5±23ppm | 5.0X3.2 |
| SG-210STF | X1G004171003500 | 27MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171003300 | 25MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171003100 | 24MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171002900 | 20MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171002800 | 19.2MHZ | ±50PPM | 2.5X2.0mm |
| SG-210STF | X1G004171001800 | 12MHZ | ±50PPM | 2.5X2.0mm |
| SG-310SCF | Q33310F70050300 | 48M | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70058100 | 40MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70055100 | 8MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70061100 | 37.125MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70060000 | 27MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70062800 | 26MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70032100 | 25MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70022900 | 24.576MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70049000 | 24MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70051500 | 20MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70024100 | 16MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70045400 | 11.2896MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70060700 | 12MHZ | ±50PPM | 3.2X2.5mm |
| SG-310SCF | Q33310F70038600 | 4MHZ | ±50PPM | 3.2X2.5mm |
| SG5032CAN | X1G004451000800 | 50MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451000700 | 48MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451000600 | 33MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451001400 | 32MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451003000 | 28.6363MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451000500 | 27MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451000400 | 25MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451002900 | 24.576MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451000300 | 24MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451001100 | 20MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451000200 | 16MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451000100 | 12.288MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451002800 | 12MHZ | ±50PPM | 5.0X3.2mm |
| SG5032CAN | X1G004451002100 | 8MHZ | ±50PPM | 5.0X3.2mm |
| SG7050CBN | X1G004491000200 | 125MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CBN | X1G004491000100 | 100MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CBN | X1G004491002300 | 80MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481004700 | 74.250MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481002000 | 66MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481003400 | 60MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481001300 | 54MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481001200 | 50MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481001100 | 48MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481001500 | 40MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481002700 | 33.333MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481004100 | 32.768MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481000900 | 32MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481003100 | 30MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481004300 | 28.6363MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481000400 | 27MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481000300 | 25MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481001600 | 24.576MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481000200 | 24MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481015200 | 22.1184MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481000800 | 20MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481004800 | 18.432MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481002300 | 16.384MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481000700 | 16MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481002500 | 14.7456MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481002800 | 14.31818MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481009500 | 13MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481000100 | 12.288MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481000600 | 12MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481004400 | 11.0592MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481000500 | 10MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481001400 | 8MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481004000 | 7.3728MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481005100 | 4MHZ | ±50PPM | 7.0X5.0mm |
| SG7050CAN | X1G004481003900 | 3.6864MHZ | ±50PPM | 7.0X5.0mm |
| RX8010SJ | X1B000242000100 | 32.768KHZ | +5PPM~±23PPM | 7.0*6.0*2.65 |
| SG-3030CM | X1B000211000100 | 32.768KHZ | +5PPM~±23PPM | 3.2X1.5mm |
| SG7050VAN | X1G004281002000 | 125MHZ | ±30PPM | 7.0X5.0mm |
| TG-5006CG | X1G004211000300 | 26MHZ | ±2PPM | 2.5X2.0mm |
| TG-5006CG | X1G004211000100 | 26MHZ | ±2PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0010600 | 32MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0072700 | 32MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0022300 | 30MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0031500 | 26MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0019300 | 26MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0016600 | 25MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0039400 | 24MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0004400 | 16MHZ | ±10PPM | 2.5X2.0mm |
| FA-20H | Q24FA20H0068700 | 12MHZ | ±10PPM | 2.5X2.0mm |
| TSX-3225 | X1E000021016900 | 32MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021016300 | 32MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021029500 | 30MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021048100 | 30MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021015800 | 27MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021014400 | 26MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021014700 | 26MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021035200 | 25MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021026400 | 24MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021012900 | 24MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021012700 | 24MHZ | ±10PPM | 3.2X2.5mm |
| TSX-3225 | X1E000021037500 | 16MHZ | ±10PPM | 3.2X2.5mm |
| FA-128 | Q22FA1280014000 | 26MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280047000 | 26MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280030400 | 24MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280002200 | 24MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280009200 | 32MHZ | ±10PPM | 2.0x1.6mm |
| FA-128 | Q22FA1280002500 | 32MHZ | ±10PPM | 2.0x1.6mm |
| MC-306 | Q13MC3062000600 | 32.768KHZ | ±20PPM | 8.0x3.8mm |
| FC-135R | X1A000141000100 | 32.768KHZ | ±20PPM | 3.2x1.5mm |
| FC-135R | X1A000141000500 | 32.768KHZ | ±10PPM | 3.2x1.5mm |
| FC-12M | X1A000061000600 | 32.768KHZ | ±20PPM | 2.0x1.2mm |
| FC-12M | X1A000061000500 | 32.768KHZ | ±20PPM | 2.0x1.2mm |
| MC-146 | Q13MC1462000100 | 32.768KHZ | ±20PPM | 7.0x1.5mm |
| MC-146 | Q13MC1462000200 | 32.768KHZ | ±20PPM | 7.0x1.5mm |
| FC-135 | Q13FC1350000300 | 32.768KHZ | ±20PPM | 3.2x1.5mm |
| FC-135 | Q13FC1350000200 | 32.768KHZ | ±20PPM | 3.2x1.5mm |
| FC-135 | Q13FC1350000400 | 32.768KHZ | ±20PPM | 3.2x1.5mm |
| FA2016AA | FA2016AA | 16MHz ~ 54MHz | ±10ppm | 2.0X1.6 |
| XG5032HAN | XG5032HAN | 100MHz ~200MHz | ±50ppm,±100ppm | 5.0X3.2 |
| XG-1000CA | XG-1000CA | 50MHz~170MHz | ±50ppm,±100ppm | 7.0X5.0 |
| VG7050EAN | VG7050EAN | 50MHz~800MHz | ±50ppm | 7.5X5.0 |
| VG-4513CB | VG-4513CB | 100MHz~500MHz | -40℃~+85℃ | 5.0X3.2 |
| VG-4512CA | VG-4512CA | 80MHz~200MHz | ±50ppm | 7.5X5.0 |
| VG-4231CE | VG-4231CE | 3MHz~60MHz | ±30ppm,±37ppm | 3.2X2.5 |
| VG-4231CB | VG-4231CB | 1MHz~81MHz | ±50ppm | 5.0X3.2 |
| VG-4231CA | VG-4231CA | 1MHz~80MHz | ±35ppm,±50ppm | 7.5X5.0 |
| SG-8003JF | SG-8003JF | 1MHz~166MHz | ±50ppm | 7.1X4.6 |
| SG3225EAN | SG3225EAN | 73.5MHz~700MHz | ±20ppm, ±30ppm,±50ppm | 3.2X2.5 |
| SG-3030CM | SG-3030CM | 32.768kHz | ±5±23ppm | 3.2X1.5 |
| MC-30A | MC-30A | 32.768kHz | ±20ppm, ±50ppm,±100ppm | 8.0X3.8 |
| MA-406 | MA-406 | 4MHz~64MHz | ±50ppm | 11.7X4.8 |
| MA-306 | MA-306 | 14.31818MHz~41MHz | ±50ppm | 8.0X3.8 |
| FC-13A | 32.768kHz | 32.768KHz | ±20ppm, ±30ppm,±50ppm | 3.2X1.5 |
| FA2016AS | FA2016AS | 16MHz~54MHz | ±10ppm | 2.0X1.6 |
| FA2016AA | FA2016AA | 16MHz~54MHz | ±10ppm, | 2.0X1.6 |
| FA-118T | FA-118T | 24MHz~54MHz | ±10ppm, ±30ppm | 1.6X1.2 |
| EV-9100JG | EV-9100JG | 800MHz~2500MHz | ±100ppm | 13.9X9.8 |
| EV1409SAN | EV1409SAN | 1000MHz~2500MHz | ±50ppm | 14.0X9.0 |
| EG-4121 | EG-4121 | 100MHz~700MHz | ±50ppm,±100ppm | 7.0X5.0 |
| EG-2121 | EG-2121 | 100MHz~700MHz | ±50ppm,±100ppm | 5.0X3.2 |
| EG-2101CA | EG-2101CA | 62.5MHz~99.999 MHz | ±50ppm,±100ppm | 7.5X5.0 |
| EG-2021 | EG-2021 | 62.5MHz~250MHz | ±50ppm,±100ppm | 7.5X5.0 |
| EG-2002CA | EG-2002CA | 62.5MHz~170MHz | ±50ppm,±100ppm | 7.5X5.0 |
| EA-2102CB | EA-2102CB | 100MHz | ±300ppm | 5.0X3.2 |
| C-002RX | C-002RX | 32.768kHz | ±20ppm | 2.0X6.0 |
| SG-8101CG | SG-8101CG | 0.67MHz~170MHz | ±25ppm, ±50ppm,±100ppm | 2.5X2.0 |
| SG7050CAN | SG7050CAN | 1MHz~75MHz | ±50ppm | 7.5X5.0 |
| SG5032CAN | SG5032CAN | 1MHz~75MHz | ±50ppm | 5.0X3.2 |
| SG-211S*E | SG-211S*E | 2.375MHz~60MHz | ±15ppm, ±20ppm | 2.5X2.0 |
| SG-210S*H | SG-210S*H | 80MHz~170MHz | ±50ppm, ±100ppm | 2.5X2.0 |
| SG-210S*D | SG-210S*D | 50MHz~80MHz | ±50ppm, ±100ppm | 2.5X2.0 |
| SG-210S*BA | SG-210S*BA | 2MHz~60MHz | ±50ppm, ±100ppm | 2.5X2.0 |
| SG-210STF | SG-210STF | 1MHz~75MHz | ±25ppm, ± 50ppm | 2.5X2.0 |
| HG-2150CA | HG-2150CA | 1MHz~60MHz | ±15ppm, ± 20ppm | 7.5X5.0 |
| HTS-206 | HTS-206 | 32.4 kHz | ±20ppm | 2.0X6.0 |
| XG5032HAN | XG5032HAN | 100MHz~200MHz | ±50ppm, ±100ppm | 5.0X3.2 |
| SG7050EEN | SG7050EEN | 25MHz~200MHz | ±25ppm, ±50ppm,±100ppm | 7.5X5.0 |
| SG7050EBN | SG7050EBN | 100MHz~175MHz | ±50ppm | 7.5X5.0 |
| SG5032EAN/VAN | SG5032EAN/VAN | 73.5MHz~700MHz | ±20ppm, ±30ppm,±50ppm | 5.0X3.2 |
| SG7050EAN/VAN | SG7050EAN/VAN | 73.5MHz~700MHz | ±20ppm, ±30ppm,±50ppm | 7.5X5.0 |
| EG-4121CA | EG-4121CA | 100MHz~700MHz | ±50ppm | 7.5X5.0 |
| EG-2123 | EG-2123 | 100MHz~700MHz | ±100ppm | 5.0X3.2 |
| EA-2102CB | EA-2102CB | 100MHz | ± 300ppm | 5.0X3.2 |
