你这么一说,又仔细看了一眼开发板。
真的有点紫铜的颜色啊
点灯继续:
在官方例子上进行修改,添加管脚定义,添加一个delay函数,具体如下:
//----------------------------------------------------------------------------- // EFM8BB52_Blinky.c //----------------------------------------------------------------------------- // Copyright 2021 Silicon Laboratories, Inc. // http://developer.silabs.com/legal/version/v11/Silicon_Labs_Software_License_Agreement.txt // // Program Description: // // This program flashes the red/green/blue LED on the EFM8BB52 PK board about // five times a second using the interrupt handler for Timer2. // // Resources: // SYSCLK - 24.5 MHz HFOSC0 / 8 // Timer2 - 5 Hz interrupt // P1.4 - LED0 // //----------------------------------------------------------------------------- // How To Test: EFM8BB52 Explorer Kit //----------------------------------------------------------------------------- // 1) Connect the EFM8BB52 Explorer Kit to a PC using a mini USB cable. // 2) Compile and download code to the EFM8BB52 Explorer Kit board. // In Simplicity Studio IDE, select Run -> Debug from the menu bar, // click the Debug button in the quick menu, or press F11. // 3) Run the code. // In Simplicity Studio IDE, select Run -> Resume from the menu bar, // click the Resume button in the quick menu, or press F8. // 4) The LED0 should blink at approximately 5 Hz. // // Target: EFM8BB52 // Tool chain: Generic // // Release 0.1 (RN) // - Initial Revision // //----------------------------------------------------------------------------- // Includes //----------------------------------------------------------------------------- #include <SI_EFM8BB52_Register_Enums.h> #include <InitDevice.h> #include <SI_EFM8BB52_Register_Enums.h> //----------------------------------------------------------------------------- // Pin Definitions //----------------------------------------------------------------------------- //----------------------------------------------------------------------------- // SiLabs_Startup() Routine // ---------------------------------------------------------------------------- // This function is called immediately after reset, before the initialization // code is run in SILABS_STARTUP.A51 (which runs before main() ). This is a // useful place to disable the watchdog timer, which is enable by default // and may trigger before main() in some instances. //----------------------------------------------------------------------------- void SiLabs_Startup (void) { // Disable the watchdog here } SI_SBIT(LED0, SFR_P1, 4);// 这个地方定义led0为p1.4,直接命名为led0 void delay(unsigned int xms) //简单做个delay //xms代表需要延时的毫秒数 { unsigned int x,y; for(x=xms;x>0;x--) for(y=110;y>0;y--); } //----------------------------------------------------------------------------- // Main Routine //----------------------------------------------------------------------------- void main (void) { enter_DefaultMode_from_RESET(); //IE_EA = 1; // Enable global interrupts while (1) { LED0 = !LED0; delay(1000); } } // Spin forever
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
分享汽车通信和多媒体总线结构被打赏20分 | |
【我踩过的那些坑】结构堵孔导致的喇叭无声问题被打赏50分 | |
NUCLEO-U083RC学习历程38+串口通过队列的方式输出两个字符串被打赏20分 | |
【我踩过的那些坑】分享一下调试一款AD芯片的遇到的“坑”被打赏50分 | |
电流检测模块MAX4080S被打赏10分 | |
分享电控悬架的结构与工作原理(一)被打赏20分 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 |
