你这么一说,又仔细看了一眼开发板。
真的有点紫铜的颜色啊
点灯继续:
在官方例子上进行修改,添加管脚定义,添加一个delay函数,具体如下:
// EFM8BB52_Blinky.c
// Copyright 2021 Silicon Laboratories, Inc.
// http://developer.silabs.com/legal/version/v11/Silicon_Labs_Software_License_Agreement.txt
// Program Description:
// This program flashes the red/green/blue LED on the EFM8BB52 PK board about
// five times a second using the interrupt handler for Timer2.
// Resources:
// SYSCLK - 24.5 MHz HFOSC0 / 8
// Timer2 - 5 Hz interrupt
// P1.4 - LED0
// How To Test: EFM8BB52 Explorer Kit
// 1) Connect the EFM8BB52 Explorer Kit to a PC using a mini USB cable.
// 2) Compile and download code to the EFM8BB52 Explorer Kit board.
// In Simplicity Studio IDE, select Run -> Debug from the menu bar,
// click the Debug button in the quick menu, or press F11.
// 3) Run the code.
// In Simplicity Studio IDE, select Run -> Resume from the menu bar,
// click the Resume button in the quick menu, or press F8.
// 4) The LED0 should blink at approximately 5 Hz.
// Target: EFM8BB52
// Tool chain: Generic
// Release 0.1 (RN)
// - Initial Revision
// Includes
#include <SI_EFM8BB52_Register_Enums.h>
#include <InitDevice.h>
// Pin Definitions
// SiLabs_Startup() Routine
// This function is called immediately after reset, before the initialization
// code is run in SILABS_STARTUP.A51 (which runs before main() ). This is a
// useful place to disable the watchdog timer, which is enable by default
// and may trigger before main() in some instances.
void SiLabs_Startup (void)
// Disable the watchdog here
SI_SBIT(LED0, SFR_P1, 4);// 这个地方定义led0为p1.4,直接命名为led0
void delay(unsigned int xms) //简单做个delay
//xms代表需要延时的毫秒数
unsigned
int
x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
// Main Routine
void main (void)
enter_DefaultMode_from_RESET();
//IE_EA = 1; // Enable global interrupts
while (1) {
LED0 = !LED0;
delay(1000);
} // Spin forever 我要赚赏金打赏帖 |
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
