电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【EFM8BB52单片机】便携桌面天气预报器(串口调试
共31条 2/4 ‹ 1 2 3 4 › 跳转至页
2021-12-18 22:32:09     打赏
11楼
你这么一说,又仔细看了一眼开发板。
真的有点紫铜的颜色啊
2021-12-18 23:20:20     打赏
12楼
非常不错的分享
2021-12-20 10:13:23     打赏
13楼
感谢楼主分享
2021-12-20 10:26:23     打赏
14楼
不错 学习到了
2021-12-20 10:30:58     打赏
15楼
这个就是镀金的吧
只有喷锡与镀金两个选项。
2021-12-20 10:34:10     打赏
16楼
学习到了
2021-12-20 10:56:24     打赏
17楼
不错不错
2021-12-20 15:22:18   被打赏 50 分(兑奖)     打赏
18楼
点灯继续:
在官方例子上进行修改,添加管脚定义,添加一个delay函数,具体如下:
// EFM8BB52_Blinky.c
// Copyright 2021 Silicon Laboratories, Inc.
// http://developer.silabs.com/legal/version/v11/Silicon_Labs_Software_License_Agreement.txt
// Program Description:
// This program flashes the red/green/blue LED on the EFM8BB52 PK board about
// five times a second using the interrupt handler for Timer2.
// Resources:
//   SYSCLK - 24.5 MHz HFOSC0 / 8
//   Timer2 - 5 Hz interrupt
//   P1.4   - LED0
// How To Test: EFM8BB52 Explorer Kit
// 1) Connect the EFM8BB52 Explorer Kit to a PC using a mini USB cable.
// 2) Compile and download code to the EFM8BB52 Explorer Kit board.
//    In Simplicity Studio IDE, select Run -> Debug from the menu bar,
//    click the Debug button in the quick menu, or press F11.
// 3) Run the code.
//    In Simplicity Studio IDE, select Run -> Resume from the menu bar,
//    click the Resume button in the quick menu, or press F8.
// 4) The LED0 should blink at approximately 5 Hz.
// Target:         EFM8BB52
// Tool chain:     Generic
// Release 0.1 (RN)
//    - Initial Revision
// Includes
#include <SI_EFM8BB52_Register_Enums.h>
#include <InitDevice.h>
// Pin Definitions
// SiLabs_Startup() Routine
// This function is called immediately after reset, before the initialization
// code is run in SILABS_STARTUP.A51 (which runs before main() ). This is a
// useful place to disable the watchdog timer, which is enable by default
// and may trigger before main() in some instances.
void SiLabs_Startup (void)
  // Disable the watchdog here
SI_SBIT(LED0, SFR_P1, 4);// 这个地方定义led0为p1.4,直接命名为led0
void delay(unsigned int xms) //简单做个delay
//xms代表需要延时的毫秒数
unsigned
int
x,y;
for(x=xms;x>0;x--)
for(y=110;y>0;y--);
// Main Routine
void main (void)
   enter_DefaultMode_from_RESET();
   //IE_EA = 1;                          // Enable global interrupts
   while (1) {
       LED0 = !LED0;
delay(1000);
   }                        // Spin forever
2021-12-20 15:48:34     打赏
19楼
灯跑起来了,那么其他的外设有没有对应的资源呢?
别慌,都在这里
2021-12-20 16:52:43     打赏
20楼
学习学习
