一个测试读写24C64以及TM1638数码管显示、矩阵按键模块的工程,有源码。经过测试,没问题。
bit I2C_Start(void) {
delay_us(10);
I2C_SDA =1;
delay_us(10);
I2C_SCK =1;
delay_us(10);
if ( I2C_SDA == 0) return 0;
if ( I2C_SCK == 0) return 0;
I2C_SDA = 0;
delay_us(10);
I2C_SCK = 0;
delay_us(10);
return 1;
void I2C_Stop(void) {
delay_us(10);
I2C_SDA = 0;
delay_us(10);
I2C_SCK = 1;
delay_us(10);
I2C_SDA = 1;
delay_us(10);
void I2C_Ack(void) {
delay_us(10);
I2C_SDA=0;
delay_us(10);
I2C_SCK=1;
delay_us(10);
I2C_SCK=0;
delay_us(10);
void I2C_Nack(void) {
delay_us(10);
I2C_SDA=1;
delay_us(10);
I2C_SCK=1;
delay_us(10);
I2C_SCK=0;
delay_us(10);
bit I2C_Send_Byte( uchar d) {
uchar i = 8;
bit bit_ack;
while( i-- ) {
delay_us(10);
if (d & 0x80 ) I2C_SDA =1;
else I2C_SDA =0;
delay_us(10);
I2C_SCK = 1;
delay_us(10);
I2C_SCK = 0;
d = d << 1;
delay_us(10);
I2C_SDA = 1;
delay_us(10);
I2C_SCK = 1;
delay_us(10);
bit_ack = I2C_SDA;
I2C_SCK =0;
delay_us(10);
return bit_ack;
uchar I2C_Receive_Byte(void) {
uchar i = 8, d;
delay_us(10);
I2C_SDA = 1;
while ( i--) {
d = d << 1;
delay_us(10);
I2C_SCK =1;
if ( I2C_SDA ) d++;
delay_us(10);
I2C_SCK =0;
return d;
void AT24C64_W(void *mcu_address,uint AT24C64_address,uint count) {
I2C_WP=0;
while(count--) {
I2C_Start();
/*I2C_Send_Byte( 0xa0 + AT24C64_address /256 *2);*/ /* 24C16 USE */
I2C_Send_Byte( 0xa0 );
I2C_Send_Byte( AT24C64_address/256 );
I2C_Send_Byte( AT24C64_address %256 );
I2C_Send_Byte( *(uchar*)mcu_address );
I2C_Stop();
delay_ms(10); /* waiTIng for write cycle to be completed */
((uchar*)mcu_address)++;
AT24C64_address++;
I2C_WP=1;
void AT24C64_R(void *mcu_address,uint AT24C64_address,uint count) {
while(count--) {
I2C_Start();
/*I2C_Send_Byte( 0xa0 + AT24C64_address / 256 *2 );*/ /* 24C16 USE */
I2C_Send_Byte( AT24C64_address % 256 );
I2C_Start();
/*I2C_Send_Byte( 0xa1 + AT24C64_address /256 *2 );*/
I2C_Send_Byte( 0xa1 );
*(uchar*)mcu_address = I2C_Receive_Byte();
I2C_Nack();
I2C_Stop();
AT24C64_address++;
void TM1638_Write(unsigned char DATA) //写数据函数
unsigned char i;
for(i=0;i<8;i++)
CLK=0;
if(DATA&0X01)
DIO=1;
else
DIO=0;
DATA>>=1;
CLK=1;
unsigned char TM1638_Read(void) //读数据函数
unsigned char i;
unsigned char temp=0;
DIO=1; //设置为输入
for(i=0;i<8;i++)
temp>>=1;
CLK=0;
if(DIO)
temp|=0x80;
CLK=1;
return temp;
void Write_COM(unsigned char cmd) //发送命令字
STB=0;
TM1638_Write(cmd);
STB=1;
unsigned char Read_key(void)
unsigned char c[4],i,key_value=0;
STB=0;
TM1638_Write(0x42);
delay_ms(100);
for(i=0;i<4;i++)
c[i]=TM1638_Read();
STB=1; //4个字节数据合成一个字节
if(c[0]==0x04) key_value=1;
if(c[0]==0x40) key_value=2;
if(c[1]==0x04) key_value=3;
if(c[1]==0x40) key_value=4;
if(c[2]==0x04) key_value=5;
if(c[2]==0x40) key_value=6;
if(c[3]==0x04) key_value=7;
if(c[3]==0x40) key_value=8;
if(c[0]==0x02) key_value=9;
if(c[0]==0x20) key_value=10;
if(c[1]==0x02) key_value=11;
if(c[1]==0x20) key_value=12;
if(c[2]==0x02) key_value=13;
if(c[2]==0x20) key_value=14;
if(c[3]==0x02) key_value=15;
if(c[3]==0x20) key_value=16;
delay_ms(100);
return (key_value);
