● LED street lighting
共4条
AP5199平均电流LED驱动IC0-450V10A大功率LED车灯驱动IC
只看楼主 1楼
AP 5 199LED DriverDescriptionThe AP5199 is an average current mode control LED driver IC operating in a constant off-time mode. Unlike AP5160,this control IC does not produce a peak-to-average error, and therefore greatly improves accuracy, line and load regulation of the LED current without any need for loop compensation or high-side current sensing. The output LED current accuracy is ±3%. The IC is equipped with a current limit comparator for hiccup-mode output short circuit protection. The AP5199 can be powered from an 8.0 - 450V supply. A PWM dimming input is provided that accepts an External control TTL compatible signal. The output current can be programmed by an internal 275mV reference, or controlled externally through a 0 - 1.5V dimming input.Typical Application CircuitFeatures● Fast average current control● Programmable constant off-time switching● Linear dimming input● PWM dimming input● Output short circuit protection with skip mode● Ambient operating temperature -40OC to +125OC● Pin-compatible with the AP51 99Applications● DC/DC or AC/DC LED driver applications● LED backlight driver for LCD displays● General purpose constant current source● LED signage and displays● Architectural and decorative LED lighting
关键词: 降压恒流驱动IC 车灯IC 手电筒IC DC-DC
共4条
有奖活动 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
“我踩过的那些坑”主题活动——第001期 | |
高校联络员开始招募啦!有惊喜!! | |
打赏了!打赏了!打赏了! |
打赏帖 | |
多组DCTODC电源方案被打赏50分 | |
新手必看!C语言精华知识:表驱动法被打赏50分 | |
【我踩过的那些坑】杜绑线问题被打赏50分 | |
【我踩过的那些坑】晶振使用的问题被打赏100分 | |
我踩过的那些坑之混合OTL功放与落地音箱被打赏50分 |
