电子产品世界 » 论坛首页 » 综合技术 » 电源与模拟 » AP5199平均电流LED驱动IC0-450V10A大功率LED车灯驱动IC
2023-03-24 17:03:00     打赏
AP 5 199LED DriverDescriptionThe AP5199 is an average current mode control LED driver IC operating in a constant off-time mode. Unlike AP5160,this control IC does not produce a peak-to-average error, and therefore greatly improves accuracy, line and load regulation of the LED current without any need for loop compensation or high-side current sensing. The output LED current accuracy is ±3%. The IC is equipped with a current limit comparator for hiccup-mode output short circuit protection. The AP5199 can be powered from an 8.0 - 450V supply. A PWM dimming input is provided that accepts an External control TTL compatible signal. The output current can be programmed by an internal 275mV reference, or controlled externally through a 0 - 1.5V dimming input.Typical Application CircuitFeatures● Fast average current control● Programmable constant off-time switching● Linear dimming input● PWM dimming input● Output short circuit protection with skip mode● Ambient operating temperature -40OC to +125OC● Pin-compatible with the AP51 99Applications● DC/DC or AC/DC LED driver applications● LED backlight driver for LCD displays● General purpose constant current source● LED signage and displays● Architectural and decorative LED lighting
● LED street lighting
关键词: 降压恒流驱动IC     车灯IC     手电筒IC     DC-DC
