共1条
求救!!gdberver问题
只看楼主 1楼
[root@gyh foo]# arm-elf-gdb foo.gdb
GNU gdb 5.0
Copyright 2000 Free Software Foundation, Inc.
GDB is free software, covered by the GNU General Public License, and you are
welcome to change it and/or distribute copies of it under certain conditions.
Type "show copying" to see the conditions.
There is absolutely no warranty for GDB. Type "show warranty" for details.
This GDB was configured as "--host=i686-pc-linux-gnu --target=arm-elf"...
(gdb) target remote 192.168.0.100:2352
Remote debugging using 192.168.0.100:2352
Couldn't establish connection to remote target
Reply contains invalid hex digit 59
(gdb)
开发板端:
# gdbserver 192.168.0.100:2352 foo
Process foo created; pid = 32
code at 0c3a4040 - 0c3a5160, data at 0c3a5164
readchar: Got EOF
RemotRxLength more long than 5ea
e side has terminated connection. GDBserver will reopen the connection.
说明:我是先启动的gdbserver
关键词: 求救 gdberver 问题
共1条
