问题描述及复现步骤:按照官网提供的步骤解压错误,前面的安装环境和md5校验都有进行,是ok的,解压就报错。看提示是说上传的文件问题
你MD5校验值就不对
你的
2cf71e64d35eb8083a4a0fc30c256484 rk3399_linux_release_v2.5.1_20210301_split_dir/rk3399_linux_release_v2.5.1_20210301_firefly_split.file0
ab77f8cad2554ebf9600b138254a1015 rk3399_linux_release_v2.5.1_20210301_split_dir/rk3399_linux_release_v2.5.1_20210301_firefly_split.file1
a3f4d50191909e05961d47bc97e9c229 rk3399_linux_release_v2.5.1_20210301_split_dir/rk3399_linux_release_v2.5.1_20210301_firefly_split.file2
16022cc729d06a28fec30ac52885d91c rk3399_linux_release_v2.5.1_20210301_split_dir/rk3399_linux_release_v2.5.1_20210301_firefly_split.file3
565426354c01d56c7d48479dd7f3c35b rk3399_linux_release_v2.5.1_20210301_split_dir/rk3399_linux_release_v2.5.1_20210301_firefly_split.file4
313d311f1705fbfb7bfc45b7937ecf24 rk3399_linux_release_v2.5.1_20210301_split_dir/rk3399_linux_release_v2.5.1_20210301_firefly_split.file5
我Wiki的
$ md5sum rk3399_linux_release_v2.5.1_20210301_split_dir/*firefly_split*
f0e9292b3816a8f1ce0eb1eeb483ad56 rk3399_linux_release_v2.5.1_20210301_split_dir/rk3399_linux_release_v2.5.1_20210301_firefly_split.file1
c6aaa5d761d0e7917bea1cb78a0e7229 rk3399_linux_release_v2.5.1_20210301_split_dir/rk3399_linux_release_v2.5.1_20210301_firefly_split.file2
你重新下载相应的文件把,把百度网盘同名的文件删掉,不然重新下载还是原来错误的文件,因为百度网盘之前测试发现它会检索本地文件,如果同名了,他就直接替换而不下载了
网速好也可以网络下载
mkdir ~/proj/rk356x_linux_release_20211019/
cd ~/proj/rk356x_linux_release_20211019/
## 完整 SDK
repo init --no-clone-bundle --repo-url https://gitlab.com/firefly-linux/git-repo.git -u https://gitlab.com/firefly-linux/manifests.git -b master -m rk3399_linux_release.xml
# 同步
.repo/repo/repo sync -c --no-tags
.repo/repo/repo start firefly --all
