module stpx ( input wire clk , input wire rst ); reg [7:0] data [0:15] ; reg [7:0] fsm = 8'b0000_0001 ; reg [4:0] i = 0 ; reg [3:0] j = 0 ; reg [3:0] k = 0 ; reg [3:0] m = 0 ; reg [3:0] p = 0 ; reg [3:0] q = 0 ; reg [3:0] x = 0 ; reg [3:0] y = 0 ; always @(posedge clk )begin if (rst == 1)begin fsm <= 4'b0001 ; i <= 0 ; j <= 0 ; k <= 0 ; m <= 0 ; p <= 0 ; q <= 0 ; x <= 0 ; y <= 0 ; data[0] <= 3 ; data[1] <= 5 ; data[2] <= 8 ; data[3] <= 9 ; data[4] <= 10 ; data[5] <= 12 ; data[6] <= 14 ; data[7] <= 20 ; data[8] <= 95 ; data[9] <= 90 ; data[10] <= 60 ; data[11] <= 40 ; data[12] <= 35 ; data[13] <= 23 ; data[14] <= 18 ; data[15] <= 0 ; end else begin case (fsm) 8'b0000_0001 : begin for (i = 0 ; i < 8 ; i = i + 1)begin if (data[i] < data[i + 8])begin data[i] <= data[i]; data[i+8] <= data[i+8]; end else begin data[i] <= data[i+ 8]; data[i+8] <= data[i] ; end end fsm <= 8'b0000_0010 ; end 8'b0000_0010 : begin i <= 0; fsm <= 8'b0000_0100 ; end 8'b0000_0100 : begin for (i = 0 ; i < 4 ; i = i +1)begin if (data[i] < data[i+4])begin data[i] <= data[i]; data[i+4]<= data[i+4]; end else begin data[i] <= data[i+4]; data[i+4] <= data[i] ; end end for (j = 8 ; j < 12 ; j = j + 1 )begin if (data[j] < data[j+4])begin data[j] <= data[j]; data[j+4] <= data[j+4]; end else begin data[j] <= data[j+4]; data[j+4] <= data[j]; end end fsm <= 8'b0000_1000 ; end 8'b0000_1000 : begin fsm <= 8'b0001_0000 ; i <= 0; j <= 0; end 8'b0001_0000 : begin for (i = 0 ; i < 2 ; i = i + 1)begin if (data[i] < data[i +2])begin data[i] <= data[i]; data[i+2]<= data[i+2]; end else begin data[i] <= data[i+2]; data[i+2]<= data[i] ; end end for (j = 4 ; j< 6 ; j = j + 1)begin if (data[j] < data[j +2])begin data[j] <= data[j]; data[j+2]<= data[j+2]; end else begin data[j] <= data[j+2]; data[j+2]<= data[j] ; end end for (k = 8 ; k< 10 ; k = k + 1)begin if (data[k] < data[k +2])begin data[k] <= data[k]; data[k+2]<= data[k+2]; end else begin data[k] <= data[k+2]; data[k+2]<= data[k] ; end end for (m = 12 ; m < 14 ; m = m + 1)begin if (data[m] < data[m + 2])begin data[m] <= data[m] ; data[m+2] <= data[m+2]; end else begin data[m] <= data[m+2]; data[m+2] <= data[m]; end end fsm <= 8'b0010_0000; end 8'b0010_0000 : begin fsm <= 8'b0100_0000 ; i <= 0 ; j <= 2 ; k <= 4 ; m <= 6 ; p <= 8 ; q <= 10 ; x <= 12 ; y <= 14 ; end 8'b0100_0000 : begin for (i = 0 ; i < 15 ; i = i +2)begin if (data[i] < data[i+1])begin data[i] <= data[i]; data[i+1] <= data[i+1]; end else begin data[i] <= data[i+1]; data[i+1] <= data[i] ; end end fsm <= 8'b1000_0000; end 8'b1000_0000 : begin i <= 0 ; j <= 0 ; k <= 0 ; m <= 0 ; p <= 0 ; q <= 0 ; x <= 0 ; y <= 0 ; end default : begin fsm <= 8'b0000_0001 ; end endcase end end endmodule ________________________________________________________________________________________ `timescale 1ns/1ns module tb_stpx (); reg clk = 0 ; reg rst = 0 ; initial begin clk = 0; rst = 1 ; #200 rst = 0 ; end always #10 clk = ~clk; stpx stpx_inst( .clk (clk) , .rst (rst) ); endmodule
共3条
【换取手持数字示波器】手搓丐版verilog双调排序
只看楼主 1楼
关键词: verilog 双调排序
共3条
有奖活动 | |
硬核工程师专属补给计划——填盲盒 | |
“我踩过的那些坑”主题活动——第002期 | |
【EEPW电子工程师创研计划】技术变现通道已开启~ | |
【EEPW在线】E起听工程师的声音! | |
高校联络员开始招募啦!有惊喜!! | |
送您一块开发板,2025年“我要开发板活动”又开始了! |
