你好。我正在尝试在 psco6 (CY8CKIT-062-BT-WIFI) 上使用 DMA 将阵列传输到 SPI 外围设备。
数组长度是一个很大的任意数字,不适合 2D 传输。比方说 643 字节。
我的想法是将其分成两个描述符并将它们链接起来。即第一个描述符传输 10x64 字节,第二个描述符传输 3 字节。(我不确定是否有其他方法。)
我遇到的问题是它无法启动第二个描述符。这是我正在尝试使用的代码:
#define txDma_ENABLED 1U#define txDma_HW DW0#define txDma_CHANNEL
2U#define txDma_IRQ cpuss_interrupts_dw0_2_IRQn/* Interrupt priority for
TXDMA */#define TXDMA_INTERRUPT_PRIORITY (7u)volatile
bool tx_dma_done = false;cy_stc_dma_descriptor_t txDma_Descriptor_1 =
{ .ctl = 0UL, .src=0UL, .dst = 0UL, .xCtl = 0UL, .yCtl =
0UL, .nextPtr = 0UL,};cy_stc_dma_descriptor_t txDma_Descriptor_0 = {
0UL, .nextPtr = 0UL,};const cy_stc_dma_descriptor_config_t
txDma_Descriptor_0_config = { .retrigger = CY_DMA_RETRIG_IM,
.interruptType = CY_DMA_DESCR_CHAIN, .triggerOutType =
CY_DMA_1ELEMENT, .channelState = CY_DMA_CHANNEL_DISABLED,
.triggerInType = CY_DMA_1ELEMENT, .dataSize = CY_DMA_BYTE,
.srcTransferSize = CY_DMA_TRANSFER_SIZE_DATA, .dstTransferSize =
CY_DMA_TRANSFER_SIZE_WORD, .descriptorType = CY_DMA_2D_TRANSFER,
.srcAddress = NULL, .dstAddress = NULL, .srcXincrement = 1,
.dstXincrement = 0, .xCount = 1, .srcYincrement = 0,
.dstYincrement = 0, .yCount = 1, .nextDescriptor = 0UL,};const
cy_stc_dma_channel_config_t txDma_channelConfig = { .descriptor
= txDma_Descriptor_0, .preemptable = false, .priority = 3,
.enable = false, .bufferable = false,};const uint8_t
small_buffer[10]={0xA1,0xB2,0xC3};uint32_t configure_tx_dma(uint8_t*
tx_buffer){ cy_en_dma_status_t dma_init_status; const
cy_stc_sysint_t intTxDma_cfg = { .intrsrc=txDma_IRQ,
.intrPriority = 7u }; /* Initialize descriptor */
dma_init_status = Cy_DMA_Descriptor_Init(
txDma_Descriptor_0, txDma_Descriptor_0_config);
Cy_DMA_Descriptor_SetXloopSrcIncrement( txDma_Descriptor_0, 1);
Cy_DMA_Descriptor_SetYloopSrcIncrement( txDma_Descriptor_0, 64);
Cy_DMA_Descriptor_SetXloopDataCount( txDma_Descriptor_0, 64);
Cy_DMA_Descriptor_SetYloopDataCount( txDma_Descriptor_0, 10);
Cy_DMA_Descriptor_SetNextDescriptor(
txDma_Descriptor_0, txDma_Descriptor_1); dma_init_status =
txDma_Descriptor_1, txDma_Descriptor_0_config);
Cy_DMA_Descriptor_SetXloopSrcIncrement( txDma_Descriptor_1, 1);
Cy_DMA_Descriptor_SetYloopSrcIncrement( txDma_Descriptor_1, 3);
Cy_DMA_Descriptor_SetXloopDataCount( txDma_Descriptor_1, 3);
Cy_DMA_Descriptor_SetYloopDataCount( txDma_Descriptor_1, 1);
Cy_DMA_Descriptor_SetNextDescriptor( txDma_Descriptor_1, 0UL); if
(dma_init_status!=CY_DMA_SUCCESS) { return INIT_FAILURE;
} dma_init_status = Cy_DMA_Channel_Init(txDma_HW,
txDma_CHANNEL, txDma_channelConfig); if
} /* Set source and destination for descriptor 1 */
Cy_DMA_Descriptor_SetSrcAddress( txDma_Descriptor_0, tx_buffer);
Cy_DMA_Descriptor_SetDstAddress( txDma_Descriptor_0, (void *)
SCB6->TX_FIFO_WR); Cy_DMA_Descriptor_SetSrcAddress(
txDma_Descriptor_1, small_buffer); Cy_DMA_Descriptor_SetDstAddress(
txDma_Descriptor_1, (void *) SCB6->TX_FIFO_WR); /* Initialize
and enable the interrupt from TxDma */ Cy_SysInt_Init(
intTxDma_cfg, tx_dma_complete);
NVIC_EnableIRQ((IRQn_Type)intTxDma_cfg.intrSrc); /* Enable DMA
interrupt source. */ Cy_DMA_Channel_SetInterruptMask(txDma_HW,
txDma_CHANNEL, CY_DMA_INTR_MASK); /* Enable DMA block to start
descriptor execution process */ Cy_DMA_Enable(txDma_HW); return
INIT_SUCCESS;}void tx_dma_complete(void){ /* Check tx DMA status */
if ((CY_DMA_INTR_CAUSE_COMPLETION !=
Cy_DMA_Channel_GetStatus(txDma_HW, txDma_CHANNEL))
(CY_DMA_INTR_CAUSE_CURR_PTR_NULL != Cy_DMA_Channel_GetStatus(txDma_HW,
txDma_CHANNEL))) { /* DMA error occurred while TX operations
*/ //handle_error(); } tx_dma_done = true; /* Clear
tx DMA interrupt */ Cy_DMA_Channel_ClearInterrupt(txDma_HW,
txDma_CHANNEL);}void spi_dma_transfer(){
Cy_DMA_Channel_SetDescriptor(txDma_HW, txDma_CHANNEL,
txDma_Descriptor_0); Cy_DMA_Channel_Enable(txDma_HW, txDma_CHANNEL);}
在psco6上使用DMA将阵列传输到SPI外围设备,为什么无法启动第二个描述符?
关键词: psco6 SPI 描述符 阵列
1. 描述符链配置问题:请确保第一个描述符的链结束符(bit[15])设置为0,而第二个描述符的链结束符设置为1。
2. 描述符的有效性问题:请确保每个描述符的有效位(bit[31])都被设置为1,以确保DMA引擎可以正确处理它们。
3. DMA配置问题:请确保正确配置了DMA引擎相关的寄存器,包括描述符地址、描述符数目和DMA通道。
此外,您还可以尝试使用中断方式来处理每个描述符的传输完成事件,以便及时处理第二个描述符的传输。
对于您提到的不适合2D传输的问题,您可以尝试使用多个描述符来传输数据,如您所示的将数组分成两个描述符。另外,您还可以使用循环模式来重复传输同一个描述符,从而实现大数组的传输。
| 一种有效完成脚本程序测试的方法被打赏¥28元 | |
| 开箱一块k230被打赏¥33元 | |
