这个问题如何解决
//系统数据显示void sys_data_show(void){ while(1)
{ //未查阅
if(sys_ctrl.find==0)
{ //未进入设置闹钟模式
if(sys_ctrl.set_alarm_mode==0)
{ //显示时间
lcd1602_show_nums(6,0,sys_ctrl.hour,2,0x80);
lcd1602_show_nums(9,0,sys_ctrl.min,2,0x80);
lcd1602_show_nums(12,0,sys_ctrl.sec,2,0x80);
//心率显示
lcd1602_show_nums(3,1,sys_ctrl.heart,3,0); //血氧显示
lcd1602_show_nums(12,1,sys_ctrl.oxygen,3,0);
//时间调节位置闪烁
switch(sys_ctrl.set_time_mode)
{ case 1://时
lcd1602_show_string(6,0," ");
delay_ms(50);
lcd1602_show_nums(6,0,sys_ctrl.hour,2,0x80); break; case 2://分
lcd1602_show_string(9,0," ");
delay_ms(50);
lcd1602_show_nums(9,0,sys_ctrl.min,2,0x80); break; case 3://秒
lcd1602_show_string(12,0," ");
delay_ms(50);
lcd1602_show_nums(12,0,sys_ctrl.sec,2,0x80); break;
} //进入闹钟设置模式
else
{ //显示助眠时间
lcd1602_show_nums(7,0,sys_ctrl.alarm_time[0][0],2,0x80);
lcd1602_show_nums(10,0,sys_ctrl.alarm_time[0][1],2,0x80); //显示起床时间
lcd1602_show_nums(7,1,sys_ctrl.alarm_time[1][0],2,0x80);
lcd1602_show_nums(10,1,sys_ctrl.alarm_time[1][1],2,0x80);
//时间调节位置闪烁
switch(sys_ctrl.set_alarm_mode)
{ case 1://助眠时
lcd1602_show_string(7,0," ");
delay_ms(50);
lcd1602_show_nums(7,0,sys_ctrl.alarm_time[0][0],2,0x80); break; case 2://助眠分
lcd1602_show_string(10,0," ");
delay_ms(50);
lcd1602_show_nums(10,0,sys_ctrl.alarm_time[0][1],2,0x80); break; case 3://起床时
lcd1602_show_string(7,1," ");
delay_ms(50);
lcd1602_show_nums(7,1,sys_ctrl.alarm_time[1][0],2,0x80); break; case 4://起床分
lcd1602_show_string(10,1," ");
delay_ms(50);
lcd1602_show_nums(10,1,sys_ctrl.alarm_time[1][1],2,0x80); break;
} //正在查阅
else
{ //显示心率最小和最大值
lcd1602_show_nums(8,0,sys_ctrl.heart_lh[0],3,0x80);
lcd1602_show_nums(12,0,sys_ctrl.heart_lh[1],3,0x80); //显示血氧最小和最大值
lcd1602_show_nums(8,1,sys_ctrl.oxygen_lh[0],3,0x80);
lcd1602_show_nums(12,1,sys_ctrl.oxygen_lh[1],3,0x80);
break;
}//系统数据设置void sys_data_set(void){
u8 key=0; static u8 oneflag=0;
key=key_scan(0); //设置时间
if(key==KEY3_PRESS)
{ //未进入设置闹钟模式
TR1=0;//关闭定时器
sys_ctrl.set_time_mode++; if(sys_ctrl.set_time_mode>=4)sys_ctrl.set_time_mode=1;
} //闹钟设置模式,确定
else
oneflag=0;
sys_ctrl.set_alarm_mode=0;
sys_open_show();//开机界面显示
TR1=1;//开启定时器
} //加
else if(key==KEY1_PRESS)
{ //时间设置模式
{ case 1://时
sys_ctrl.hour++; if(sys_ctrl.hour>23)sys_ctrl.hour=0; break; case 2://分
sys_ctrl.min++; if(sys_ctrl.min>59)sys_ctrl.min=0; break; case 3://秒
sys_ctrl.sec++; if(sys_ctrl.sec>59)sys_ctrl.sec=0; break;
//闹钟设置模式
{ case 1://助眠时
sys_ctrl.alarm_time[0][0]++; if(sys_ctrl.alarm_time[0][0]>23)sys_ctrl.alarm_time[0][0]=0; break; case 2://助眠分
sys_ctrl.alarm_time[0][1]++; if(sys_ctrl.alarm_time[0][1]>59)sys_ctrl.alarm_time[0][1]=0; break; case 3://起床时
sys_ctrl.alarm_time[1][0]++; if(sys_ctrl.alarm_time[1][0]>23)sys_ctrl.alarm_time[1][0]=0; break; case 4://起床分
sys_ctrl.alarm_time[1][1]++; if(sys_ctrl.alarm_time[1][1]>59)sys_ctrl.alarm_time[1][1]=0; break;
} //正常模式下,查阅血氧心率信息
if(sys_ctrl.set_time_mode==0 && sys_ctrl.set_alarm_mode==0)
sys_ctrl.find=!sys_ctrl.find; //查阅
if(sys_ctrl.find==1)
lcd1602_clear();
lcd1602_show_string(0,0," Heart->000-000");
lcd1602_show_string(0,1,"Oxygen->000-000");
} //退出查阅
else
} //减
else if(key==KEY2_PRESS)
{ //时间设置模式
{ case 1://时
sys_ctrl.hour--; if(sys_ctrl.hour<0)sys_ctrl.hour=23; break; case 2://分
sys_ctrl.min--; if(sys_ctrl.min<0)sys_ctrl.min=59; break; case 3://秒
sys_ctrl.sec--; if(sys_ctrl.sec<0)sys_ctrl.sec=59; break;
} //闹钟设置模式
{ case 1://助眠时
sys_ctrl.alarm_time[0][0]--; if(sys_ctrl.alarm_time[0][0]<0)sys_ctrl.alarm_time[0][0]=23; break; case 2://助眠分
sys_ctrl.alarm_time[0][1]--; if(sys_ctrl.alarm_time[0][1]<0)sys_ctrl.alarm_time[0][1]=59; break; case 3://起床时
sys_ctrl.alarm_time[1][0]--; if(sys_ctrl.alarm_time[1][0]<0)sys_ctrl.alarm_time[1][0]=23; break; case 4://起床分
sys_ctrl.alarm_time[1][1]--; if(sys_ctrl.alarm_time[1][1]<0)sys_ctrl.alarm_time[1][1]=59; break;
sys_ctrl.alarm_flag=0;//解除闹铃
} //确定
else if(key==KEY4_PRESS)
{ //时间设置模式
if(sys_ctrl.set_time_mode!=0)
sys_ctrl.set_time_mode=0;
TR1=1;//开启定时器
} //闹钟设置模式
else
TR1=0;//关闭定时器
if(oneflag==0)//只显示1次界面
oneflag=1;
lcd1602_clear();
lcd1602_show_string(0,0,"Sleep->00:00");
lcd1602_show_string(0,1,"Alarm->00:00");
sys_ctrl.set_alarm_mode++; if(sys_ctrl.set_alarm_mode>=5)sys_ctrl.set_alarm_mode=1;
}//应用控制系统void appdemo_show(void){
u8 i=5;
sys_parm_init();//系统参数初始化
lcd1602_init();
time1_init(); while(i--)
{ //血氧心率获取
sys_ctrl.heart=pcf8591_read_adcvalue(1);
sys_ctrl.heart=cal_map(sys_ctrl.heart,0,255,0,200);
sys_ctrl.heart_lh[0]=sys_ctrl.heart;//初始值作为最小值
sys_ctrl.heart_lh[1]=sys_ctrl.heart;//初始值作为最大值
sys_ctrl.oxygen=pcf8591_read_adcvalue(0);
sys_ctrl.oxygen=cal_map(sys_ctrl.oxygen,0,255,0,200);
sys_ctrl.oxygen_lh[0]=sys_ctrl.oxygen;//初始值作为最小值
sys_ctrl.oxygen_lh[1]=sys_ctrl.oxygen;//初始值作为最大值
delay_ms(100);
sys_open_show();//系统开机界面显示
TR1=1;//开启定时器
while(1)
sys_data_get();//系统数据获取
sys_data_show();//系统数据显示
sys_data_set();//系统数据设置
sys_fun_ctrl();//系统功能控制
}//定时器1中断函数void time1(void) interrupt 3 { static u8 i=0;
TH1=0XDC; //给定时器赋初值,定时10ms
TL1=0X00;
i++; if(i>=100)//1秒到
i=0;
sys_ctrl.sec++; if(sys_ctrl.sec>=60)//1分
sys_ctrl.sec=0;
sys_ctrl.min++; if(sys_ctrl.min>=60)//1小时
sys_ctrl.min=0;
sys_ctrl.hour++; if(sys_ctrl.hour>=24)sys_ctrl.hour=0;
