电子产品世界 » 论坛首页 » 嵌入式开发 » 软件与操作系统 » 瑞萨已适配的硬件定时器驱动分析
共10条 1/1 1 跳转至
瑞萨已适配的硬件定时器驱动分析
2024-12-31 20:24:26     打赏
      通过前面的分析,我们已经大致知悉了硬件定时器通用实现模板,但这种理解是否正确,以及瑞萨完全实现了硬件定时器所需要的功能,我们并不了解,这部分只能通过查看瑞萨目前实现的硬件定时器代码才能清楚。
源码分析
注册入口
#ifndef TMR_DEV_INFO_CONFIG
#define TMR_DEV_INFO_CONFIG                     \
        .maxfreq = 400000000,                   \
        .minfreq = 1562500,                     \
        .maxcnt  = 0XFFFFFFFF,                  \
        .cntmode = HWTIMER_CNTMODE_UP,          \
#endif /* TIM_DEV_INFO_CONFIG */
static struct ra_hwtimer ra_hwtimer_obj[BSP_TIMERS_NUM] =
#ifdef BSP_USING_TIM0
    [BSP_TIMER0_INDEX] = TIMER_DRV_INITIALIZER(0),
#endif
#ifdef BSP_USING_TIM1
    [BSP_TIMER1_INDEX] = TIMER_DRV_INITIALIZER(1),
#endif
static const struct rt_hwtimer_ops _ops =
    .init = timer_init,
    .start = timer_start,
    .stop = timer_stop,
    .count_get = timer_counter_get,
    .control = timer_ctrl,
static const struct rt_hwtimer_info _info = TMR_DEV_INFO_CONFIG;
static int rt_hw_hwtimer_init(void)
    int result = RT_EOK;
    for (int i = 0; i < sizeof(ra_hwtimer_obj) / sizeof(ra_hwtimer_obj[0]); i++)
        ra_hwtimer_obj[i].tmr_device.info = &_info;
        ra_hwtimer_obj[i].tmr_device.ops  = &_ops;
        if (rt_device_hwtimer_register(&ra_hwtimer_obj[i].tmr_device, ra_hwtimer_obj[i].name, &ra_hwtimer_obj[i]) == RT_EOK)
            LOG_D("%s register success", ra_hwtimer_obj[i].name);
        else
            LOG_E("%s register failed", ra_hwtimer_obj[i].name);
            result = -RT_ERROR;
    return result;
INIT_BOARD_EXPORT(rt_hw_hwtimer_init);
     从实现上看,注册函数并未对硬件定时器的硬件部分做任何操作,仅仅是对驱动内部参数赋了初始值并通过rt_device_hwtimer_register在系统中注册了硬件定时器,这也符合上层驱动要求暴露init接口的做法。
初始化入口
static void timer_init(struct rt_hwtimer_device *timer, rt_uint32_t state)
    RT_ASSERT(timer != RT_NULL);
    struct ra_hwtimer *tim;
    tim = (struct ra_hwtimer *)timer->parent.user_data;
    if (state)
        fsp_err_t fsp_err = FSP_SUCCESS;
        fsp_err = R_GPT_Open(tim->g_ctrl, tim->g_cfg);
        if (fsp_err != FSP_SUCCESS)
            LOG_E("%s init fail", tim->name);
     从实现上看,目前瑞萨的代码并未实现解初始化部分,也就是说,如果应用上要实现低功耗的需求,可能就需要自行实现解初始化的部分。
启动入口
static rt_err_t timer_start(rt_hwtimer_t *timer, rt_uint32_t pr, rt_hwtimer_mode_t opmode)
    RT_ASSERT(opmode != RT_NULL);
    fsp_err_t err = FSP_SUCCESS;
    /* set timer count */
    R_GPT_CounterSet(tim->g_ctrl, 0);
    /* set timer period register */
    err = R_GPT_PeriodSet(tim->g_ctrl, pr);
    if (err != FSP_SUCCESS)
        return -RT_ERROR;
    /* set timer to one cycle mode */
    err = R_GPT_Start(tim->g_ctrl);
    return (err == FSP_SUCCESS) ? RT_EOK : -RT_ERROR;
      启动入口主要是初始值设置并启动定时器。
中断处理入口
static void timer_one_shot_check(void)
    IRQn_Type irq = R_FSP_CurrentIrqGet();
    /* Recover ISR context saved in open. */
    gpt_instance_ctrl_t *p_instance_ctrl = (gpt_instance_ctrl_t *) R_FSP_IsrContextGet(irq);
    /* If one-shot mode is selected, stop the timer since period has expired. */
    if (TIMER_MODE_ONE_SHOT == p_instance_ctrl->p_cfg->mode)
        p_instance_ctrl->p_reg->GTSTP = p_instance_ctrl->channel_mask;
        /* Clear the GPT counter and the overflow flag after the one shot pulse has being generated */
        p_instance_ctrl->p_reg->GTCNT = 0;
        p_instance_ctrl->p_reg->GTCCR[0U] = 0;
        p_instance_ctrl->p_reg->GTCCR[1U] = 0;
        /* Clear pending interrupt to make sure it doesn't fire again if another overflow has already occurred. */
        R_BSP_IrqClearPending(irq);
void timer0_callback(timer_callback_args_t *p_args)
    /* enter interrupt */
    rt_interrupt_enter();
    if (TIMER_EVENT_CYCLE_END == p_args->event)
        rt_device_hwtimer_isr(&ra_hwtimer_obj[BSP_TIMER0_INDEX].tmr_device);
        timer_one_shot_check();
    /* leave interrupt */
    rt_interrupt_leave();
#endif
void timer1_callback(timer_callback_args_t *p_args)
        rt_device_hwtimer_isr(&ra_hwtimer_obj[BSP_TIMER1_INDEX].tmr_device);
#endif
     具体的功能是在中断处理中调用rt_device_hwtimer_isr回调,通知上层硬件定时器事件发生,并检查定时器设置是否是单次触发,如果是单次触发,则内部停用定时器。
停止入口
static void timer_stop(rt_hwtimer_t *timer)
    struct ra_hwtimer *tim = RT_NULL;
    /* stop timer */
    R_GPT_Stop(tim->g_ctrl);
     停止入口是停用定时器并清空计数值,但个人认为其实停用计数值没有啥必要,因为这个启用时又会重新清0,而不使用时,这个计数值也不会被使用。
获取计数值入口
static rt_uint32_t timer_counter_get(rt_hwtimer_t *timer)
    timer_info_t info;
    if (R_GPT_InfoGet(tim->g_ctrl, &info) != FSP_SUCCESS)
        return -RT_ERROR;
    return info.period_counts;
     获取计数值接口,并没有什么特殊的部分,就是从瑞萨自己的硬件适配层接口中获取实际的计数值并上报。
控制入口
const rt_uint32_t PLCKD_FREQ_PRESCALER[PLCKD_PRESCALER_MAX_SELECT] =
#ifdef SOC_SERIES_R7FA6M3
    PLCKD_PRESCALER_120M,
    PLCKD_PRESCALER_60M,
    PLCKD_PRESCALER_30M,
    PLCKD_PRESCALER_15M,
    PLCKD_PRESCALER_7_5M,
    PLCKD_PRESCALER_3_75M,
    PLCKD_PRESCALER_1_875M,
#endif
static rt_err_t timer_ctrl(rt_hwtimer_t *timer, rt_uint32_t cmd, void *arg)
    rt_err_t result = RT_EOK;
    RT_ASSERT(arg != RT_NULL);
    switch (cmd)
    case HWTIMER_CTRL_FREQ_SET:
        rt_uint8_t index = 0;
        rt_uint32_t freq = *((rt_uint32_t *)arg);
        for (rt_uint8_t i = 0; i < PLCKD_PRESCALER_MAX_SELECT; i++)
            if (freq <= PLCKD_FREQ_PRESCALER[i])
                index = i;
        tim->g_ctrl->p_reg->GTCR_b.TPCS = index;
    break;
    default:
        result = -RT_ENOSYS;
    break;
    return result;
     控制接口只实现了HWTIMER_CTRL_FREQ_SET,也就是定时器的工作频率设定。
总结
     至此,瑞萨的硬件定时器实现已经分析完毕,从实现代码上看,我们可以发现以下信息:
            1.瑞萨的硬件定时器,并没有实现解初始化部分
            2. 瑞萨实现的控制入口,仅仅实现了设置工作频率入口,其他直接上报不支持
       这些未实现的部分,在使用瑞萨代码时需要注意区分。
关键词: 瑞萨     适配     硬件     定时器     实现
2024-12-31 22:42:32     打赏
2024-12-31 22:43:59     打赏
2024-12-31 22:45:31     打赏
2024-12-31 22:54:04     打赏
瑞萨真棒!
我倒是计划2025年的DIY重点转向瑞萨
2025-01-01 00:25:12     打赏
2025-01-01 09:45:07     打赏
说实话,现在对于RTOS来说,还是使用FreeRTOS。
2025-01-01 10:06:11     打赏
2025-01-02 08:41:58     打赏
学习了。
2025-01-02 19:18:52     打赏
我倒是觉得做嵌入式开发很难一劳永逸
也确实有点累
共10条 1/1 1 跳转至
站长统计
有奖问卷
英飞凌400V CoolSiC™重新定义高性能电源设计的功率密度和效率,含有奖小问卷,限前200名工程师!
