电子产品世界 » 论坛首页 » 嵌入式开发 » MCU » 【MAX32625PICO开发板】驱动MAX30102
2025-05-18 09:07:56     打赏
MAX30102的开源库非常多,移植到MAX32625上,主要是编写他的几个接口函数,这一篇将详细介绍如何实现。
【工程文件添加】
在github下找到一个开源的MAX30102的驱动,在驱中有MAX30100.c、blood.c、algorithm.c文件以及他的.h,将他添加到Keil工程中:
【IIC接口文件适配】
1、IIC接口文件在max30100.c中,IIC_Write_Byte、IIC_Read_Byte、IIC_Read_Array为基础接口。移植就是修改这三个函数。
2、Max32625可以实现IIC硬件驱动,由于本次使用为与OLED共用的I2C0(max32625只引出来了mxc_I2C0),因此硬件的初始化不需要在这里提供,先初始化OLED就可以了。
硬件I2C读写的接口在i2cm.c中实现,函数原型为:
 * @defgroup i2cm_blocking I2CM Blocking Functions
 * @brief      Read I2CM data. Will block until transaction is complete.
 * @note       Command is an optional feature where the master will write the @c
 *             cmd_data before reading from the slave. If command is undesired,
 *             set the @c *cmd_data parameter to NULL and pass 0 for the @c
 *             cmd_len parameter.
 * @note       If there is a command, the master will send a repeated start
 *             sequence before attempting to read from the slave.
 * @note       This function blocks until the transaction has completed.
 * @param      i2cm      Pointer to the I2CM registers, see #mxc_i2cm_regs_t.
 * @param      addr      I2C address of the slave.
 * @param      cmd_data  Data to write before reading.
 * @param      cmd_len   Number of bytes to write before reading.
 * @param      data      Where to store the data read.
 * @param      len       Number of bytes to read.
 * @return     Number of bytes read if successful, error code if unsuccessful.
int I2CM_Read(mxc_i2cm_regs_t *i2cm, uint8_t addr, const uint8_t *cmd_data,
    uint32_t cmd_len, uint8_t* data, uint32_t len);
 * @brief      Write data to a slave device.
 *             cmd_data before writing the @c data to the slave. If command is
 *             not needed, set the @c cmd_data  to @c NULL and set @c cmd_len to
 *             0. If there is a command, the master will send a repeated start
 * @param      cmd_data  Data to write before writing data.
 * @param      cmd_len   Number of bytes to write before writing data.
 * @param      data      Data to be written.
 * @param      len       Number of bytes to Write.
 * @return     Number of bytes writen if successful or an @ref MXC_Error_Codes
 *             "Error Code" if unsuccessful.
int I2CM_Write(mxc_i2cm_regs_t *i2cm, uint8_t addr, const uint8_t *cmd_data,
/**@} end of i2cm_blocking functions */
3、具体实现代码如下:
uint8_t IIC_Write_Byte(uint8_t device_addr,uint8_t register_addr,uint8_t data)
	uint8_t send_data[2];
	send_data[0] = register_addr;
	send_data[1] = data;
	return I2CM_Write(MXC_I2CM0, device_addr, NULL, 0, send_data, 2);
uint8_t IIC_Read_Byte(uint8_t device_addr,uint8_t register_addr)
	uint8_t data;
	I2CM_Read(MXC_I2CM0, device_addr, &register_addr, 1, &data, 1);
	return data;
uint8_t IIC_Read_Array(uint8_t device_addr,uint16_t register_addr,uint8_t *Data,uint16_t Num)
	uint8_t data[Num*2];
	uint8_t i=0;
	uint8_t addr;
	addr = (uint8_t)register_addr;
	I2CM_Read(MXC_I2CM0, device_addr, &addr, 1, data, Num*2);
	while(Num)
		*Data= data[i*2]<<8 | data[i*2+1];
		Data ++;
		Num--;
【测试】
修改好上面三个接口函数,在main中执行复位max30102,然后进行配置:max30102_config,再在大循环里执行blood_loop就行实现Max30102的读取与分析。
关键词: MAX32625PICO     MAX30102
