一、点亮FPB-RA0E1板两个LED灯
板子上的两颗led灯一个是P008,另一个是P009,电路图如下:
e2 studio 建立工程。在FSP Configurations-Pins中将P008和P009脚的Mode选成Output mode(initial low),详见下图。
点亮两个LED灯的工程代码:
#include "hal_data.h"
FSP_CPP_HEADER
void R_BSP_WarmStart(bsp_warm_start_event_t event);
FSP_CPP_FOOTER
void hal_entry(void)
while(1)
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_08, BSP_IO_LEVEL_HIGH);
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_00_PIN_09, BSP_IO_LEVEL_HIGH);
#if BSP_TZ_SECURE_BUILD
/* Enter non-secure code */
R_BSP_NonSecureEnter();
#endif
if (BSP_WARM_START_RESET == event)
#if BSP_FEATURE_FLASH_LP_VERSION != 0
R_FACI_LP->DFLCTL = 1U;
#endif
if (BSP_WARM_START_POST_C == event)
R_IOPORT_Open (&IOPORT_CFG_CTRL, &IOPORT_CFG_NAME);
#if BSP_CFG_SDRAM_ENABLED
R_BSP_SdramInit(true);
#endif
FSP_CPP_HEADER
BSP_CMSE_NONSECURE_ENTRY void template_nonsecure_callable ();
FSP_CPP_FOOTER
#endif
点亮两个LED灯效果见下图:
二、使LED灯闪烁
将主循环部分代码改为:
while(1)
R_BSP_SoftwareDelay(100, BSP_DELAY_UNITS_MILLISECONDS); // NOLINT
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_03, BSP_IO_LEVEL_LOW);
R_IOPORT_PinWrite(&g_ioport_ctrl, BSP_IO_PORT_01_PIN_03, BSP_IO_LEVEL_HIGH);
LED灯闪烁效果图如下:
