电子产品世界 » 论坛首页 » 综合技术 » 物联网技术 » 【MAX7800】eclipsemaxiSDK添加用户代码与文件参与编译
2025-06-19 14:37:57     打赏
在eclipse MaxiSDK中,如何添加用户的代码到工程中,使用的IDE如下:
我是第一次使用这个IDE,偿试添加自己的工程文件,我偿试直接添加到工程根目录时,是可以不用配置工程,然后就可以参与编译了,如果添加了自己的文件夹,然后折腾了好久没有成功。
最后我找到了Makefile里面有说明如下:
# Set up search paths, and auto-detect all source code on those paths.
# The following paths are searched by default, where "./" is the project directory.
# |- *.h
# |- *.c
# |-include (optional)
#   |- *.h
# |-src (optional)
#   |- *.c
# Configuration Variables:
# - VPATH : Tell this Makefile to search additional locations for source (.c) files.
# 			You should use the "+=" operator with this option.
#			Ex:  VPATH += your/new/path
# - IPATH : Tell this Makefile to search additional locations for header (.h) files.
# - SRCS : Tell this Makefile to explicitly add a source (.c) file to the build.
# 			This is really only useful if you want to add a source file that isn't
#			on any VPATH, in which case you can add the full path to the file here.
#			Ex:  SRCS += your/specific/source/file.c
# - AUTOSEARCH : Set whether this Makefile should automatically detect .c files on
#				VPATH and add them to the build.  This is enabled by default.  Set
#				to 0 to disable.  If autosearch is disabled, source files must be
#				manually added to SRCS.
#				Ex:  AUTOSEARCH = 0
# Where to find source files for this project.
然后在下面就有如下面的Makefile的配置:
VPATH += .
VPATH += src
VPATH := $(VPATH)
# Where to find header files for this project
IPATH += .
IPATH += include
IPATH := $(IPATH)
AUTOSEARCH ?= 1
ifeq ($(AUTOSEARCH), 1)
# Auto-detect all C/C++ source files on VPATH
SRCS += $(wildcard $(addsuffix /*.c, $(VPATH)))
SRCS += $(wildcard $(addsuffix /*.cpp, $(VPATH)))
endif
# Collapse SRCS before passing them on to the next stage
SRCS := $(SRCS)
为此,我图简单,在根目录下面添加一个src与一个include文件夹,将我自己的.c拷贝进src,将头文件添加进include下面,然后执行编译就可以了。
【小结】
我在工程设置,添加了头文件的路径,然后还是报错找不到头文件,因此,还需要在makefile中添加,才能参与编译。
如果工程不是很复杂,那简单的这样处理就行了,如果有再复杂的工程,那么还得在makefile中添加编译才行。
关键词: MAX7800     eclipse     maxiSDK     编
