电子产品世界 » 论坛首页 » 活动中心 » 板卡试用 » 【MAX78000FEATHER】AES安全模块真随机数发生器使用
2025-10-05 12:01:28     打赏
【简介】
从芯片的框图中AES模块中集成TRNG 模块来产生真随机数服务。
以下是文档中对真随机数发生器的描述
我们使用如下代码验证真随机数发生器的功能。
 * @file        main.c
 * @brief      True Random Number Generator (TRNG) example
 * @details
 * Copyright (C) 2022-2023 Maxim Integrated Products, Inc. (now owned by
 * Analog Devices, Inc.),
 * Copyright (C) 2023-2024 Analog Devices, Inc.
 * Licensed under the Apache License, Version 2.0 (the "License");
 * you may not use this file except in compliance with the License.
 * You may obtain a copy of the License at
 *     http://www.apache.org/licenses/LICENSE-2.0
 * Unless required by applicable law or agreed to in writing, software
 * distributed under the License is distributed on an "AS IS" BASIS,
 * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
 * See the License for the specific language governing permissions and
 * limitations under the License.
#include <stdio.h>
#include <stdint.h>
#include <string.h>
#include "mxc_device.h"
#include "nvic_table.h"
#include "trng.h"
volatile int wait;
volatile int callback_result;
/***** Globals *****/
uint8_t var_rnd_no[16] = { 0 };
void TRNG_IRQHandler(void)
    MXC_TRNG_Handler();
void Test_Callback(void *req, int result)
    wait = 0;
    callback_result = result;
void print(char *stuff)
    int i, j, size = 4;
    for (i = 0; i < 4; ++i) {
        for (j = 0; j < 4; ++j) {
            printf("0x%02x ", stuff[i * size + j]);
        printf("\n");
    return;
void Test_TRNG(int asynchronous)
    printf(asynchronous ? "\nTest TRNG Async\n" : "\nTest TRNG Sync\n");
    int num_bytes = 16;
    memset(var_rnd_no, 0, sizeof(var_rnd_no));
    MXC_TRNG_Init();
    if (asynchronous) {
        wait = 1;
        NVIC_EnableIRQ(TRNG_IRQn);
        MXC_TRNG_RandomAsync(var_rnd_no, num_bytes, &Test_Callback);
        while (wait) {}
    } else {
        MXC_TRNG_Random(var_rnd_no, num_bytes);
    print((char *)var_rnd_no);
    MXC_TRNG_Shutdown();
int main(void)
    printf("\n\n********** TRNG Example **********\n");
    Test_TRNG(0);
    Test_TRNG(1);
    printf("\n********** Test Complete **********\n");
    return 0;
上述代码运行后产同步和中断方式产生四组随机数打印输出如下
