【简介】
在车载领域LIN通讯在整车的网路中经常会被使用,S32K3 芯片可以通过 lpuart 配置为LIN来实现LIN通讯功能。配置LIN功能前我们需要先配置硬件的端口为UART功能。
按照本地的硬件原理图在S32DS 中配置对应的端口为LPUART 功能。
在S32DS 配置工具中加入LIN 驱动。
配置开启LPUART0 的中断
生成代码后LIN的驱动文件已经被加入到工程中。
本地添加如下的代码测试LIN 发送功能。
* \file lin_driver.c *
* \brief *
* <table> *
* <tr><th>Date <th>Version *
* <tr><td>2026/04/07 <td>1.0.0 *
* </table> *
* Include header files *
#include "Lpuart_Lin_Ip.h"
#include <string.h>
#include <stdlib.h>
#include "data_trace.h"
#if (1 == CFG_FUNC_AUTO_INIT)
#include "func_init.h"
#endif
* LOCAL MACROS
#define DBG_ENABLE
#define DBG_TAG "LIN"
#define DBG_LEVEL DBG_LOG
#define DBG_COLOR
#include <rtdbg.h>
#define LIN_SEND_PID (0x1A)
#define LIN_RECV_PID (0x2B)
#define SEND 0
#define RECV 1
#define BUFFER_SIZE (8U)
* LOCAL CONSTANTS
* LOCAL FUNCTIONS
* LOCAL VARIABLES
static uint32_t LinSendCounter = 0;
static uint32_t LinRecvCounter = 0;
static uint8 LpuartTxBuff[BUFFER_SIZE] = {1,2,3,4,5,6,7,8}; /*The data to be send out*/
static uint8 *RxBuff; /*The point to receive the data*/
static Lpuart_Lin_Ip_PduType LinLpuartPdu[] =
.Pid = (uint8)LIN_SEND_PID,
.Cs = LPUART_LIN_IP_ENHANCED_CS,
.SduPtr = LpuartTxBuff,
.Drc = LPUART_LIN_IP_FRAMERESPONSE_TX,
.Dl = (uint8)BUFFER_SIZE
.Pid = (uint8)LIN_RECV_PID,
.SduPtr = NULL, /* This value should have been the Rx buffer.But it is not used by the driver. */
.Drc = LPUART_LIN_IP_FRAMERESPONSE_RX,
* LOCAL TYPEDEFS (STRUCTURES, UNIONS, ENUMS)
* LOCAL FUNCTION PROTOTYPES
* GLOBAL VARIABLES
* GLOBAL CONSTANTS
* GLOBAL FUNCTIONS
void LinMasterCallback(uint8 Instance, Lpuart_Lin_Ip_StateStructType *LpuartStateStruct)
switch (LpuartStateStruct->CurrentEventId)
/* transmission ok */
case LPUART_LIN_IP_TX_COMPLETED:
/*add user code after LIN master completed transmission*/
LinSendCounter++;
LOG_I("LIN transmission completed %ld.", LinSendCounter);
break;
/* receiving ok */
case LPUART_LIN_IP_RX_COMPLETED:
/*add user code after LIN master completed receiving*/
LinRecvCounter++;
LOG_I("LIN reception completed %ld.", LinRecvCounter);
trace_byte_stream(RxBuff, 8, 0);
break;
default:
/* do nothing */
break;
static int lin_init(void)
Lpuart_Lin_Ip_StatusType ret;
/* Init LIN master */
ret = Lpuart_Lin_Ip_Init(Lpuart_Lin_Ip_Sa_pxHwConfigPB_0.Instance, &Lpuart_Lin_Ip_Sa_pxHwConfigPB_0);
if(ret == LPUART_LIN_IP_STATUS_SUCCESS)
LOG_I("LIN init OK.");
else
LOG_E("LIN init failed %x.", ret);
return 1;
unsigned int lin(char argc, char **argv)
uint32 TimeoutValue = 4*400000U;
uint8 *DummyBuffer;
volatile Lpuart_Lin_Ip_TransferStatusType LpuartMasterStatus = LPUART_LIN_IP_STATUS_OPERATIONAL;
if(argc == 2 && strcmp(argv[1], "init") == 0)
lin_init();
else if(argc == 2 && strcmp(argv[1], "send") == 0)
/* Start of the sending frame from Lpuart Master*/
Lpuart_Lin_Ip_SendFrame(Lpuart_Lin_Ip_Sa_pxHwConfigPB_0.Instance, &LinLpuartPdu[SEND]);
/*Wait for the transmission done */
do
LpuartMasterStatus = Lpuart_Lin_Ip_GetStatus(Lpuart_Lin_Ip_Sa_pxHwConfigPB_0.Instance, (const uint8 **)&DummyBuffer);
while ((LPUART_LIN_IP_STATUS_TX_OK != LpuartMasterStatus) && (TimeoutValue-- > 1));
else if(argc == 2 && strcmp(argv[1], "recv") == 0)
Lpuart_Lin_Ip_SendFrame(Lpuart_Lin_Ip_Sa_pxHwConfigPB_0.Instance, &LinLpuartPdu[RECV]);
/*Wait for the receiving done */
do
/*The Rx buffer is obtained here*/
LpuartMasterStatus = Lpuart_Lin_Ip_GetStatus(Lpuart_Lin_Ip_Sa_pxHwConfigPB_0.Instance, (const uint8 **)&RxBuff);
while ((LPUART_LIN_IP_STATUS_RX_OK != LpuartMasterStatus) && (TimeoutValue-- > 1));
else
PRINTF("Invalid command. Usage: lin init|send|recv\n");
return 0;
本地出发 lin 的初始化和 发送接口函数执行成功,并在LIN slave端成功接收到消息数据。
LIN 接收0X2B 的数据帧从slave 节点接收数据。
上述log 和LIN trace 的数据也是能够匹配的。
本地LIN 收/发 穿插验证trace 上的数据和本地收发的也是保持一致的。
