电子产品世界 » 论坛首页 » 行业应用 » 汽车电子 » 【S32K3XX】模块缩略语整理
【S32K3XX】模块缩略语整理
2026-05-30 12:25:10   被打赏 50 分(兑奖)     打赏
【简介】
S32K3 芯片中涵盖的IP 和特性还是很多的,经常遇到些芯片的功能缩写需要反复查看手册查找,本贴基于此为基础整理下S32K3芯片中的缩略语概念整理。
功能模块
缩略语
含义
备注
SafetyEDCError Detection Code检查总线传输中的数据错误
XBICCrossbar Integrity Checker监控 Crossbar 数据流
ERM Error Reporting Module
SCST Structural Core Self-Test (Premium software)SCST和SAF是收费软件
FCCUFault Collection and Control Unit
ECCError-Detection-Correction-Codes检测并校正内存中的单比特错误,多比特错误则触发异常。
SECDEDSingle Error Correction, Double Error Detection
eMCEMS32SAF extended microcontroller error manager
EIM
Error Injection Module
SPD Safety Peripheral Driver (Standard software and it’s a sub-set of SAF)
NCFNon-Critical Fault非关键性故障
SPFMSingle-point fault metric
BistBuilt-in self-test
PowerPORPower-On Reset
LVR  Low voltage reset
PMC Power Management Controller
Cortex-M
SCB System Control Block
An address region in the System Control Space, used for key feature control and configuration associated with the exception model.
DCB  Debug Control Block
A region in the System Control Space that is assigned to registers that support debug features.
CMSISCortex Microcontroller Software Interface Standard
ISRInterrupt service routine
TCMTightly coupled memory
IP
FARFlash Address Remapping
MSIMessage signal interface
MISO
Main In, Secondary Out
MOSI
Main Out, Secondary In
MISCIPCFInter-Platform Communication Framework
RTM    Release To Manufacturing
2026-05-31 17:12:46     打赏
谢谢分享。
