电子产品世界 » 论坛首页 » DIY与开源设计 » 电子DIY » 【FRDMRW612系列】3、按键中断
【FRDMRW612系列】3、按键中断
2026-07-17 15:16:46   被打赏 25 分(兑奖)     打赏
【软件环境】
MCUXPresso IDE 25.6
【工程配置】
从数据手册中,可以得到可以供用的是wakeup按键。为了增加可观性,我再添加另一个LED:
图形化配置后如下:
更新源代码后,可以看到如下代码:
void BOARD_InitPins(void)
/* Enables the clock for the GPIO0 module */
GPIO_PortInit(GPIO, 0);
gpio_pin_config_t gpio0_pinM2_config = {
.pinDirection = kGPIO_DigitalInput,
.outputLogic = 0U
gpio_interrupt_config_t gpio0_pinM2_int_config = {
.mode = kGPIO_PinIntEnableEdge,
.polarity = kGPIO_PinIntEnableLowOrFall
/* Initialize GPIO functionality on pin PIO0_11 (pin M2)  */
GPIO_PinInit(GPIO, 0U, 11U, &gpio0_pinM2_config);
GPIO_SetPinInterruptConfig(GPIO, 0U, 11U, &gpio0_pinM2_int_config);
GPIO_PinEnableInterrupt(GPIO, 0U, 11U, (uint32_t)kGPIO_InterruptA);
/* Initialize FC3_USART_DATA functionality on pin GPIO_24 (pin E5) */
IO_MUX_SetPinMux(IO_MUX_FC3_USART_DATA);
/* Initialize GPIO11 functionality on pin GPIO_11 (pin M2) */
IO_MUX_SetPinMux(IO_MUX_GPIO11);
可以看到对GPIO_0、GPIO_1已经初始化输出模式。GPIO_11为输入模式。
2、rw612的GPIO输出操作
 * @brief Sets the output level of the one GPIO pin to the logic 1 or 0.
 * @param base    GPIO peripheral base pointer(Typically GPIO)
 * @param port   GPIO port number
 * @param pin    GPIO pin number
 * @param output  GPIO pin output logic level.
 *        - 0: corresponding pin output low-logic level.
 *        - 1: corresponding pin output high-logic level.
static inline void GPIO_PinWrite(GPIO_Type *base, uint32_t port, uint32_t pin, uint8_t output)
base->B[port][pin] = output;
根据sdk中示例,我添加测试代码如下:
 * Copyright (c) 2013 - 2015, Freescale Semiconductor, Inc.
 * Copyright 2016-2017, 2024 NXP
 * All rights reserved.
 * SPDX-License-Identifier: BSD-3-Clause
#include "fsl_device_registers.h"
#include "fsl_debug_console.h"
#include "board.h"
#include "app.h"
 * Definitions
 * Prototypes
 * Variables
volatile uint32_t g_systickCounter;
volatile bool g_InputSignal = false;
 * Code
 * @brief Interrupt service fuction of switch.
void GPIO_INTA_IRQHandler(void)
    /* clear the interrupt status */
    GPIO_PinClearInterruptFlag(GPIO, 0, 11, 0);
    /* Change state of switch. */
    g_InputSignal = true;
    SDK_ISR_EXIT_BARRIER;
void SysTick_Handler(void)
    if (g_systickCounter != 0U)
        g_systickCounter--;
void SysTick_DelayTicks(uint32_t n)
    g_systickCounter = n;
    while (g_systickCounter != 0U)
 * @brief Main function
int main(void)
    char ch;
    /* Init board hardware. */
    BOARD_InitHardware();
    PRINTF("MCUX SDK version: %s\r\n", MCUXSDK_VERSION_FULL_STR);
    GPIO_PinEnableInterrupt(GPIO, 0, 11, 0);
    EnableIRQ(GPIO_INTA_IRQn);
    PRINTF("hello world.\r\n");
    /* Set systick reload value to generate 1ms interrupt */
    if (SysTick_Config(SystemCoreClock / 1000U))
        while (1)
    while (1)
        SysTick_DelayTicks(100U);
        GPIO_PinWrite(GPIO, 0, 0, 1);
        GPIO_PinWrite(GPIO, 0, 0, 0);
        if(g_InputSignal)
            GPIO_PortToggle(GPIO, 0, (1U << 1));
这里我们需要注意,虽然在初始化了按键GPIO_11,但还是需要使用:
来打开GPIO_11的中断,并使能GPIO_INTA_IRQn。
【下载验证】
下载好到开发板后,可以看到开板上的蓝色RGB灯以100ms的频率闪烁了。
同时按下wake按键后可以转另一个RGB灯。
【总结】
通过mcuxpresso ide的图形化配置,可以快速实现对GPIO output、OUTPUT的操作。
关键词: FRDMRW612     按键     中断
