平台:
s3c4510b+am29lv160db
uCLinux + romfs + MTD + netflash
flash分了两个区:1.bootloader(128K); 2.kernel&rootfs
根文件系统是romfs,没有采用jffs2,启动正常,下面是log:
Loading Image From Disk ............... Done
Linux version 2.4.22-uc0 (root@localhost.localdomain) (gcc version 2.95.3 20010315 (release)(ColdFire patches - 20010318 from http://fiddes.net/coldfire/)(uClinux XIP and shared lib patches from http://www.snapgear.com/)) #2262 三 10月 12 16:17:08 CST 2005
Processor: Samsung S3C4510B revision 6
Architecture: SNDS100
On node 0 totalpages: 2048
zone(0): 0 pages.
zone(1): 2048 pages.
zone(2): 0 pages.
Kernel command line: root=/dev/rom0
Calibrating delay loop... 12.44 BogoMIPS
Memory: 8MB = 8MB total
Memory: 6156KB available (1685K code, 174K data, 40K init)
Dentry cache hash table entries: 1024 (order: 1, 8192 bytes)
Inode cache hash table entries: 512 (order: 0, 4096 bytes)
Mount cache hash table entries: 512 (order: 0, 4096 bytes)
Buffer cache hash table entries: 1024 (order: 0, 4096 bytes)
Page-cache hash table entries: 2048 (order: 1, 8192 bytes)
POSIX conformance testing by UNIFIX
Linux NET4.0 for Linux 2.4
Based upon Swansea University Computer Society NET3.039
Initializing RT netlink socket
Starting kswapd
JFFS2 version 2.1. (C) 2001 Red Hat, Inc., designed by Axis Communications AB.
MPG430: install module......Done
Video source : TI 5150
TI 5150 video decoder configuration done
Samsung S3C4510 Serial driver version 0.9 (2001-12-27) with no serial options enabled
ttyS00 at 0x3ffd000 (irq = 5) is a S3C4510B
ttyS01 at 0x3ffe000 (irq = 7) is a S3C4510B
Blkmem copyright 1998,1999 D. Jeff Dionne
Blkmem copyright 1998 Kenneth Albanowski
Blkmem 1 disk images:
0: F6D10-1B750F [VIRTUAL F6D10-1B750F] (RO)
RAMDISK driver initialized: 16 RAM disks of 1024K size 1024 blocksize
Samsung S3C4510 Ethernet driver version 0.1 (2002-02-20) <mac@os.nctu.edu.tw>
eth0: 00:0d:21:00:03:e7
homicam flash device: 200000 at 1000000
Amd/Fujitsu Extended Query Table v1.0 at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling fast programming due to code brokenness.
Creating 2 MTD partitions on "Homicam flash device":
0x00000000-0x00020000 : "bootloader (128KB)"
mtd: Giving out device 0 to bootloader (128KB)
0x00020000-0x00200000 : "kernel & rootfs (1.875MB)"
mtd: Giving out device 1 to kernel & rootfs (1.875MB)
NET4: Linux TCP/IP 1.0 for NET4.0
IP Protocols: ICMP, UDP, TCP
IP: routing cache hash table of 512 buckets, 4Kbytes
TCP: Hash tables configured (established 512 bind 512)
NET4: Unix domain sockets 1.0/SMP for Linux NET4.0.
VFS: Mounted root (romfs filesystem) readonly.
Freeing init memory: 40K
Shell invoked to run file: /etc/rc
Command: hostname Samsung
Command: /bin/expand /etc/ramfs.img /dev/ram0
Command: mount -t proc proc /proc
Command: mount -t ext2 /dev/ram0 /var
Command: mkdir /var/config
Command: mkdir /var/tmp
Command: mkdir /var/log
Command: mkdir /var/run
Command: mkdir /var/lock
Command: mkdir /var/empty
Command: cat /etc/motd
Welcome to
____ _ _
/ __| ||_|
_ _| | | | _ ____ _ _ _ _
| | | | | | || | _ \| | | |\ \/ /
| |_| | |__| || | | | | |_| |/ \
| ___\____|_||_|_| |_|\____|\_/\_/
|_|
For further information check:
